RichardGee
CA, USA Status: offline
I too noticed the upper tail former having been installed "crooked" - in reality, it looks to me like they lined it up with the molded in rudder offset, but this does indeed make out of whack with the lower rudder former. I ended up drilling new holes, top and bottom to make the rudder hinge fit properly. I also broke away the lower rudder hinge mount, as it was WAY off line from the top one, and reglued it in better alignment. I had to do additional mods on the upper rudder former to bring the fiberglass fuse into line so that there was a more equal space on either side of the rudder itself. If you're beginning to get the idea that this "so-called ARF" is allot of work, well, you got the right idea. I am not terribly disappointed because the bottom line is that there is no more accurate Gee Bee R2 on the market - not now, not ever. If they could eliminate the seams caused by the molding process, this plane would be near perfect. BUT, as Delmar says, "compromises must be made." He also responded - as he was admonished to "be careful" as he entered the Gee Bee for his first flight.... "If I were careful I never would have built a Gee Bee." That ALWAYS cracks me up.
_____________________________
RC Modeling is for truly talented individuals... for everyone else, there's video games.
