RichardGee
CA, USA Status: offline
DWR, Well, it's back to the drawing board for me and this #@%&$@@!!! Gee Bee . It's going to require 2.5 pounds on the firewall/dome to get it to balance at 75mm from LE... and this is after mounting Rx and ignition batteries, ignition and voltage regulators on the back of engine dome, adding cowl baffles and engine dome reinforcement !!! Had I known this was going to be the case with CG, I NEVER would have installed the radio tray and servos where recommended in the 'manual' This is quite disappointing, I must say, and baffling since I pretty much followed the instructions (as poor as they are) to the letter and, of course, have a DA150 on the nose. I found that just a Great Planes pilot bust makes a HUGE difference in CG, but cannot possibly imagine the plane w/o a pilot in the cockpit. My next steps will be to substitute 6 cell 7.2v NiCads (RC CAR style batteries) for the LiPos. These are heavy monsters that will deliver more than enough power, while also serving a useful purpose - nose weight. I believe I will also need to move at least the rudder servo and Rx and the piezo gyro WAY forward - which entails remaking all my servo extensions, rudder pull/pull, TW control and all the various cable anchors I have installed... WHAT A MAJOR PAIN!!!! I could also drill some lightening holes in the rudder front (inside fuse)... Not sure how this happened... makes me wonder if the manufacture of my particular Gee Bee resulted in heavy aft end fuse and other components...
_____________________________
RC Modeling is for truly talented individuals... for everyone else, there's video games.
