AFPD Platinum Edition Problems    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Flight Simulator Software >> Ikarus AeroFly Pro and Aerofly Pro Deluxe >> AFPD Platinum Edition Problems Page: [1]
Login
AFPD Platinum Edition Problems - 1/29/2011 4:58 AM
imsofaman
Score: 100
Last Login: 10/9/2012
Status: offline
I purchased the Platinum edition with the interface wire. I use a DX7. I plug the cable in.....it recognizes it....but not the transmitter. I tried a Stereo to Mono adapter....did not work. The only way the transmitter is recognized is to pull the plug almost all the way out. Can you please help me? My MAC is brand new with 8gig. Could I just buy the transmitter interface to replace my cable?
Any help would be appreciated.
Dave
______________
_____________________________
Viva Juan De La Cierva!
Hide Signatures
       Post #: 1
RE: AFPD Platinum Edition Problems - 1/29/2011 5:00 AM
rajul
Score: 105
Last Login: 6/17/2013
Status: offline
Dave, please post a photo of all the cables that you have including the stereo-mono adapter cable
Mike Marks
RCU Moderator
Aerofly Support Representative http://www.aerofly.com/index.html
Hide Signatures
(in reply to imsofaman)
       Post #: 2
RE: AFPD Platinum Edition Problems - 1/29/2011 5:06 AM
imsofaman
Score: 100
Status: offline
OK...give me a minute...
Hide Signatures
(in reply to rajul)
       Post #: 3
RE: AFPD Platinum Edition Problems - 1/29/2011 5:12 AM
imsofaman
Score: 100
Status: offline
OK...here it is.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 4
RE: AFPD Platinum Edition Problems - 1/29/2011 5:16 AM
imsofaman
Score: 100
Status: offline
I saw where someone on line used a stereo to mono jack and theirs worked. I tried it and no luck.
Hide Signatures
       Post #: 5
RE: AFPD Platinum Edition Problems - 1/29/2011 5:24 AM
rajul
Score: 105
Status: offline
Dave, you can't use the audio mono-stereo converter. The internal connections are not compatible. You need to get the Ikarus y-adapter cable as per the connection diagram below for JR/Spektrum radios. Do you need the part number and info on where you can buy it from?
Click for fullsize
Mike Marks
RCU Moderator
Hide Signatures
       Post #: 6
RE: AFPD Platinum Edition Problems - 1/29/2011 5:27 AM
imsofaman
Score: 100
Status: offline
I saw the jack with Futaba square plug. I did not think I needed that....
Hide Signatures
(in reply to rajul)
       Post #: 7
RE: AFPD Platinum Edition Problems - 1/29/2011 5:36 AM
imsofaman
Score: 100
Status: offline
Sorry....it has 2 connectors to one jack
Click for fullsize
Hide Signatures
       Post #: 8
RE: AFPD Platinum Edition Problems - 1/29/2011 5:37 AM
rajul
Score: 105
Status: offline
The part number for the y-adapter is #31036. You could get it from the following:
http://www.aerofly-5.com/purchase.htm
This JR/Spektrum adapter is also designed for Aerofly and is lower in cost:
http://www.fxaeromodels.com/product_info.php?cPath=141&products_id=1659
Mike Marks
RCU Moderator
Hide Signatures
       Post #: 9
RE: AFPD Platinum Edition Problems - 1/29/2011 5:39 AM
rajul
Score: 105
Status: offline
quote:
ORIGINAL: imsofaman
This will not work either. It is for older Futaba and Hitec radios, definitely not for JR/Spektrum
Mike Marks
RCU Moderator
Hide Signatures
       Post #: 10
RE: AFPD Platinum Edition Problems - 1/29/2011 5:40 AM
imsofaman
Score: 100
Status: offline
Thanks so much for your help!!!!
Dave
Hide Signatures
       Post #: 11
RE: AFPD Platinum Edition Problems - 1/29/2011 5:42 AM
rajul
Score: 105
Status: offline
You're most welcomed Dave
Mike Marks
RCU Moderator
Hide Signatures
       Post #: 12
RE: AFPD Platinum Edition Problems - 1/29/2011 3:59 PM
imsofaman
Score: 100
Status: offline
One more question: Is it possible to purchase the transmitter interface? Will that work also? If there is a part number for that, I would like one of those also.
Dave
Hide Signatures
(in reply to rajul)
       Post #: 13
RE: AFPD Platinum Edition Problems - 1/30/2011 12:32 AM
rajul
Score: 105
Status: offline
Dave, I would personally recommend that you use your own programmable radio so that you will be able to use all the programmable functions such as program mixes, dual rates, etc. plus you get the feel of the actual radio you use in the field. What you have now, the usb interface version, is the best
Mike Marks
RCU Moderator
Hide Signatures
       Post #: 14
RE: AFPD Platinum Edition Problems - 1/30/2011 3:31 AM
imsofaman
Score: 100
Status: offline
OK Mike....I am excited that my problem will be solved with the adapter wire. Thanks for the awesome advice.
OK....one more question: What is the small female jack on the inter face cord? Also....do I need to down load a patch or anything? I saw where some guys were asking about it. Not sure why they need it but I am curious. I have a brand new Mac with 8 gigs.
Thanks for your time.
Dave
Hide Signatures
(in reply to rajul)
       Post #: 15
RE: AFPD Platinum Edition Problems - 1/30/2011 3:34 AM
rajul
Score: 105
Status: offline
Could you point out with an arrow on the photo which specific jack you're referring to?
What is the version number printed on your main AFPD disk?
Mike Marks
RCU Moderator
Hide Signatures
       Post #: 16
RE: AFPD Platinum Edition Problems - 1/30/2011 4:03 AM
imsofaman
Score: 100
Status: offline
Version 1.11.07.25
The female jack above the wires.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to rajul)
       Post #: 17
RE: AFPD Platinum Edition Problems - 1/30/2011 4:10 AM
imsofaman
Score: 100
Status: offline
Refresh the browser as I added some things.
Hide Signatures
       Post #: 18
RE: AFPD Platinum Edition Problems - 1/30/2011 5:25 AM
rajul
Score: 105
Status: offline
That jack is for non-JR radios where you don't need the short colored cable.
There is a 1.11.7.31 mac patch which you can download here http://www.aerofly.com/afpd/downloads.html#afpdmacosx Follow the installation instructions
Mike Marks
RCU Moderator
Hide Signatures
       Post #: 19
RE: AFPD Platinum Edition Problems - 1/30/2011 4:20 PM
imsofaman
Score: 100
Status: offline
OK...need the patch and will download.
Are you saying I dont need the colored cord? I use a DX7 not JR. Are you saying I should plug it in the female jack and not use the cord?
Sorry for the dumb questions....just want to be clear.
Thanks for your patience,
Dave
Hide Signatures
(in reply to rajul)
       Post #: 20
RE: AFPD Platinum Edition Problems - 1/30/2011 11:18 PM
rajul
Score: 105
Status: offline
JR and Spektrum (DX7) need the colored cable
Mike Marks
RCU Moderator
Hide Signatures
       Post #: 21
RE: AFPD Platinum Edition Problems - 1/31/2011 12:31 AM
imsofaman
Score: 100
Status: offline
I must thank you again for your patience in helping me. Nothing better than awesome customer service!!!
So, for now, I will just pull the plug half way out and play the sim with my DX7. The cable I ordered via your link, should arrive soon.
Dave
Hide Signatures
(in reply to rajul)
       Post #: 22
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.484RCU1
