King Tiger in the Snow - with Exhaust
MN
Here's more of the KT in winter camo running thru the snow. The clip focuses on showing the exhaust smoker.
Note: I make the smokers - want it known up front that I'm involved with the smoker represented here. Hope it's OK to post this way....
The smoker has proportional output and is smaller than a stock HL unit. Its an easy install in an HL Tiger and the Tamiya KT, and probably in most other HL's and Tamiya's. It will be available from RCTankWars in a week or two. More detail on that website soon.
Here's the clip....
[youtube]http://www.youtube.com/watch?v=EAaeK9gbNu8[/youtube]
Here's the clip....
MN
RE: King Tiger in the Snow - with Exhaust
The new smoker should work with HL, Tamiya and ElMod (if an HL smoker works proportional with ElMod, the new smoker will work proportional with ElMod) Phil at RCTW will be confirming soon.
A teaser pic- and smaller than an HL smoker....
It's looking very good to me ...I see that you're using a voltage regulator for the idle ; probably 5 Volts ....
When you say " proportional " , do you mean variable fan speed and constant heater power ; or variable fan speed and variable heater power ????
AB, CANADA
Up until now the space inside a tank has always been to valuable to waste on a poor performing smoker. However if this unit is solid then I can see making room for one in the future. With cold weather I wonder what a kind of result you would get with a high density water vapor phase. That is what produces most of the "smoke" from exhaust in the winter.
MN
Strmnd,
The v-reg is there mostly to standardize smoke output level with the varying V inputs different users have, and to stabilize V as batteries run down. The mass of the heater doesn't respond fast enough to make proportional heater V very effective, so fan speed provides theproportional output. Unit is also manually/mechanically adjustable for output level because personal preferences for smoke level vary, along with wind, indoor/outdoor use, etc.
YHR,
The smoker is smaller than the HL unit - uses space pretty efficiently. The recommended fluid is glycol/water "fog juice", which does, as you say, make a "fog" rather than smoke.The KT vid is glycol/water fog juice. Oil based fluid can be used, but oil makes a nasty mess (and smell) and the residue that collects around the exhausts softened paint on my models. The oil residue can't be easily cleaned up. The "fog juice" also can leave residue, but it hasn't hurt my paint and wipes off completely with just a damp cloth. I'm sold on glycol smoke juice vs.oil based stuff (some of which may even damage plastic).
There is an impession tht fog juice is expensive. There are cheaper oils, etc., but an hour of smoker run time on glycol fog juice costs only about 30 cents and it won't damage your tank.
Hope tankers like this smoker....
YHR,
Strmnd,
The v-reg is there mostly to standardize smoke output level with the varying V inputs different users have, and to stabilize V as batteries run down. The mass of the heater doesn't respond fast enough to make proportional heater V very effective, so fan speed provides the proportional output. Unit is also manually/mechanically adjustable for output level because personal preferences for smoke level vary, along with wind, indoor/outdoor use, etc.
You're right about the response time of the heater ; I came to the same results when I was making my 2 levels output smoke unit ....
I run my modified H.L. mini smoker for around 1 hour before refueling ( using a 14 Ohms resistor and a Glycerin - alcohool fluid )
Judging by the dimmensions of your design ; your running time should be similar to mine ....
YHR is right about the importance of the small size of the unit ; I'm ready to post my last video of the smoking gun for witch I had to fit a mini smoker inside my Panzer IV turret ....
I wish you success with the new design ...
MN
The smoker si now available at
http://www.rctankwars.com/Products.asp
The proportional output feature does not currently work with ElMod. Working on it....
MN
ORIGINAL: yellowshaker
Yea, I have to say, that thing looks amazing brother! Smoke unit seems to work perfectly with the tamiya system. Any chance it'll work on elmod?
Unfortunately, even though the smoker will work in basic output mode with ElMod,the proportional feature does not work. Working on it....
DanL
MN
Smoker filling vid -
Heres' the "how-to" for filling the new SuperSmoker. It's a calibrated fill from outside the hull.
[youtube]http://www.youtube.com/watch?v=K6LhzvidjLg[/youtube]
DanL
DanL
Dan , I was watching your smoker filling video more closely and I focused on the step when you suck some liquid from the smoker to check if it is empty or not ....
Am I right to conclude that the refill probe goes all the way down inside your smoker ???
If so , what would happen if you remove the cap screw on the refill tube and let your smoker run low on fluid ???
Would smoke starts to exit through the refill tube like it does in my smokers ????
You know that I've been using my refill tubes as fuel gauges for a while now ...
Whenever I see smoke coming out the refill tube , I know I have around 1/16 " of fluid left in my unit ; and it's time to refill....
I then use a mini syringe full of fluid to refill to the optimal level without having to worry about overfilling ...And I don't worry about the unit until I see smoke coming out the refill tube again ...
You pointed out a while ago ,on this forum ; that the maintenance required to operate a smoke unit is often a " turn off " for tankers ....
I believe that if your smoker could be operated that way ; it would be a welcome ease of maintenance as well ...
This posting is not meant as a criticism , but merely as a suggestion to help ...
Regards Norm...
MN
Norm,
Thanks for the suggestion - don't feel it's criticism at all. Actually, I appreciate your attention and feedback - you are pretty much the master at all this (eg the smokong gun work...)
The fill tube is a very good way to signal low level, and then following with a measured refill. Not sure it would work on this design though - I haven't seen smoke come from the fill tube at any time. The tube has only about a 1/16"ID and is long enough to be routedand pulledout thru thehull for filling. The base is about 1/4" from the bottom of the reservoir, but buried in densely packed fiberglass. My thinking was that a "fill-up" to really saturate the FG bed, then a suction to pull out the excess would give max saturation of the bed from top to bottom. I think that this design is a good one, but certainly not likely the only or bestone- still a lot of experimentation and ideas to pursue.
Definitelya hobby pursuit - the time and materials cost, tools andjigs, solder, wire, shrink tube etc etcdon't make it worth doing really, except that I greatly enjoy playing around with this stuff and it seems that a decent smoker is wanted by quite a few tankers.
I'll pay more attention to the fill tube smoke approachto see if it will work on this design- it really sounds good. Seems it could/should work.
The biggest issue seems tochoose a smoke output level - some want a lot, some want very little. I tried to build that in with a way to adjust airflow. Will be interesting to see if users get the range of smoke they might want.
I saw your smoking gun work. The latest results were really awesome.
I'll PM my email - would be fun to discuss the smoker tech details. I'm really surprised at the level of design challenge - it continues to be fun....
MN
Just built a large scale smoker for a 1/8th scale T-34. Anxious to see it installed in the guys tank. Here's a short clip. Smoke output will look a lot different when rigged through tank exhausts.
[youtube]http://www.youtube.com/watch?v=f5yoxwyn9Ik[/youtube]
DanL
DanL
