Best price on a Triton Charger?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Best price on a Triton Charger?
Page: [1]
Login
Best price on a Triton Charger? - 8/7/2003 12:41:56 AM
Which_way_is_up-RCU
Status: offline
Who's got the best price on a Triton Charger? Does GP threaten their dealers with price fixing? Why is every dealer I found through a Yahoo search selling the charger for exactly the same price, $129?
       Post #: 1
Best price on a Triton Charger? - 8/7/2003 2:11:31 AM
cruzomatic
Status: offline
check the For Sale section, some one is selling a like new one for 89.00
(in reply to Which_way_is_up-RCU)
       Post #: 2
Best price on a Triton Charger? - 8/7/2003 2:18:08 AM
SilverComet
Status: offline
They definitely don't fix prices, because I've seen ones for $130 :
       Post #: 3
Best price on a Triton Charger? - 8/7/2003 2:18:53 AM
SilverComet
Status: offline
meant to say $139
       Post #: 4
Best price on a Triton Charger? - 8/7/2003 8:34:09 AM
sideshow
Status: offline
I am reasonably sure that GP, along with Horizon, has a minimum advertised price (MAP) policy. You can sell it for less...but you can't advertise for less. That's why some of the ads will say "call for the best price".
_____________________________
Bob Convery
       Post #: 5
RE: Best price on a Triton Charger? - 10/8/2003 3:05:38 AM
guver
Status: offline
I was selling tritons here for $89.00 but having trouble with the new market place (does too much for my little peabrain) posting here to test my e-mail notification which I'm not getting.
       Post #: 6
RE: Best price on a Triton Charger? - 12/25/2003 6:39:29 AM
RebarDWG
Status: offline
i got my triton at towerhobbies for $119
Famous last words,
Hey watch this!!
(in reply to guver)
       Post #: 7
RE: Best price on a Triton Charger? - 12/25/2003 2:17:31 PM
moodier
Status: offline
Have one now from Tower paid $129 which is $129 more than it is worth!!Back to using my old Accu-Cycle at least it works.Sent it back once they sent new one no better than other one.Only use on Ni-Cads never get a consistent charge.I would surely look at posts re;chargers and think seriously before buying a Triton!Good Luck!
(in reply to RebarDWG)
       Post #: 8
RE: Best price on a Triton Charger? - 12/25/2003 3:32:06 PM
guver
Status: offline
How was your Triton acting up? I've had excellent results with mine. Do you want to sell cheap?
(in reply to moodier)
       Post #: 9
RE: Best price on a Triton Charger? - 12/26/2003 5:11:37 AM
moodier
Status: offline
Was thinking would try to get them to take it back don't know if will have any luck.They replaced it once already!Mainly use it for NiCads.try to use the disc-chge cycle.may dis 700Ma but only put back 100Ma.That kind of thing loose faith in it.Have tried changineg that setting that goes up to 15 think it says to set about 7 but at 12 can get it to place more charge.aLso don't like the fact will only charge one battery.Use the Accu-cycle as in spite of its shortcomings charges 2 batteries and then goes to trickle.Haven't had opportunity to see if it will charge Li-Pos etc but want to try electrics but if can't handle Ni-Cads don't know about the others.I think there instructions are very poor found more help on the RCU site where Red discuss how to use it but even following his directions don't have much luck.Again sometimes it will work fine on a battery too.Have to get in gear and get after tower to try to get it figured out or get another new one to try.Have been temporarily distracted trying to get a Trackerll radio working or at least figured out,but that is another story!!Glad yours is working good,think I need a book Triton for Dummies then if I can get a Trackerll for dummies should be in good shape!
(in reply to guver)
       Post #: 10
RE: Best price on a Triton Charger? - 12/26/2003 2:41:52 PM
Captain351
Status: offline
I've heard a lot of complaining here in this forum about the Triton and still don't get it . I have not had one problem with this charger that wasn't my own fault. The latest version of the manual took away any any questions I had about how to use this charger. The last page of this new manual is the most informative part of the whole manual.
http://www.electrifly.com/manuals/gpmm3150-manual-v1_1.pdf
I think a lot of people are just confused by the menu system they seem to want a separate button for each function. If you can't program a VCR you should probably stay away from this charger.
       Post #: 11
RE: Best price on a Triton Charger? - 12/26/2003 11:04:07 PM
JasonF
Status: offline
Watch out for those crummy charge leads Hobbico is selling. They have poor connections at the banana plugs. Just hook your battery up to a DVM and wiggle where the wire enters, you'll see the voltage go all over the place. Leads like this will give a Triton fits.
(in reply to Captain351)
       Post #: 12
RE: Best price on a Triton Charger? - 12/26/2003 11:29:29 PM
VULTCH
Status: offline
My Triton works great. I have the accucycle plus which is good but nowhere near what the Triton can do. What type of power supply are you using? You need one which is highly filtered.
(in reply to JasonF)
       Post #: 13
RE: Best price on a Triton Charger? - 12/28/2003 1:06:30 AM
Panzlflyer
Status: offline
Ditto on the Leads.
I think that a lot of the complaints start there.
There are several of us using it here and no complaints. As it is a "sensing unit" the wiring has to be good or it will terminate the charge.
(in reply to VULTCH)
       Post #: 14
RE: Best price on a Triton Charger? - 12/28/2003 4:52:49 AM
moodier
Status: offline
My unhappiness with the triton does revolve around incinsistent charging.This sounds like what you fellows are mentioning in re;to the leads.WHat doyou use for leads instead of the Tower ones?These leads seem to work on the Accu-Cycle!Just did a Disc-Charge.on a charged up 900Ma battery.When done showed a charge of 90Ma,I would think it should have been around the 900 figure,yet checked battery with a loaded meter showed 100% charge?
(in reply to Panzlflyer)
       Post #: 15
RE: Best price on a Triton Charger? - 12/28/2003 11:51:43 PM
Wildmann
Status: offline
Most people in the battery realm feel that the accucycle is a paper weight..
I feel the same way
when charging any battery can you adjust what you are charging your pack at..
if you cannot then you need to find a charger that does
If you are only charging little 4.8 flight packs that are Nicad you still need to charge at a C factor
to ensure saftey of your equiptment and people flying with you.
The triton does both that
But I feel also that you should alway charge on a C factor over night with a Ddvc or something close then use your triton to top off your Cells esp on teh Bigger Six Volt Nicad Packs you will see a Pack wich lasts longer.
If you are using any other type battery cell like Nimh Or LIPO it is the only charger I would use.
Most NiMh Second Generation Cells Have to be charged on At C or you can do damage
and Lipo has there Percent or they can heat up and be damaged or Go on Fire.
These are thing to think about ..
