Aerofly 5 for Mac violent wing drop problem    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Flight Simulator Software >> Ikarus AeroFly Pro and Aerofly Pro Deluxe >> Aerofly 5 for Mac violent wing drop problem Page: [1]
Login
Aerofly 5 for Mac violent wing drop problem - 2/2/2011 5:59 PM
Dustflyer
Score: 100
Last Login: 5/16/2013
Status: offline
I recently installed the Mac version of Aerofly 5 on my brand new iMac. It seems like the big 3D models fly very differently from the ones on my old Aerofly Pro Deluxe installed on my Dell Windows laptop. On the new Mac version, the big Extra, and Edge tend to drop a wing quite violently when slowing up for a harrier or transitioning into a hover. If you don't catch it just right, the airplanes will just snap right over. The Giles in my old Aerofly Pro would just mush into the manuever pretty much like a foamie or modern giant scale 3D plane. I have the Game Commander for Aerofly 5 and have upgraded it to version 5.5. Did I miss something in the setup? I fly a 33% SD Models Yak, and even it is way more docile than the airplanes in Aerofly 5.
Addendum: The Extra 260 does not seem to have the problem. The other giant scale 3D machines are pretty bad. You cannot pull into a wall without a snap one way or the other.
< Message edited by Dustflyer -- 3/8/2011 6:06 PM >
_____________________________
I love the smell of jet fumes in the morning!
Hide Signatures
       Post #: 1
RE: Aerofly 5 for Mac violent wing drop problem - 2/6/2011 4:51 PM
rajul
Score: 105
Last Login: 5/18/2013
Status: offline
I have flown the large scale aerobatic models in AF5 including the Extra, Edge, and Katana ("competition" type, not "standard") and they seem to hold well in all 3D maneuvers including walls, and transitions into hovering without dropping a wing. With a proper entry speed and by smoothening out your throws with expo, it should be fine. BTW, I'm using my own programmable radio and not the gamecommander. I find it much easier to tune the throws, dual rates, expos on my radio.
Having said that, the large 3D models ("competition" types) are set up to fly differently from the ones in AFPD and they do have a slightly higher tendency to snap. The planes in AFPD were "too soft" according to competition pilots, so the AF5 developers gave the "competition" models an earlier stall behaviour in AF5. This especially improved the snaps. Anyhow, this stall behavior is unexpected for the beginner pilots (often mistaken for some 'aileron input' in a tight loop or very slow approach). So for beginner pilots, the "standard" models are recommended. For each model you can select either the "competition" or "standard" model type in the load model menu.
You can reduce the snap tendency by editing the model but I would do this as a last resort: go to the model editor and adjust the lift curve for both the AirfoilTip and AirfoilRoot. Increase the AttachedRange and StallRange, and reduce Cl0 to make the 'hump' in the green lift curve smaller. This will make the stall softer or even non-existent, and going into the wall or harrier is just as easy as pulling the the stick back. Compare these parameters in the "competition" and "standard" models and you'll see the differences.
Mike Marks
RCU Moderator
Aerofly Support Representative http://www.aerofly.com/index.html
Hide Signatures
(in reply to Dustflyer)
       Post #: 2
RE: Aerofly 5 for Mac violent wing drop problem - 2/7/2011 1:51 AM
Dustflyer
Score: 100
Status: offline
Thanks for the reply. I may wind up making those adjustments. I think they went a little too far in the Mac version with regard to stall behavior. While I am no pro, I'm far from a beginner. I fly an old 33% SD Yak weighing 23 pounds, but even it doesn't have the kind of early stall behavior as the giant scale models in Aerofly Mac.
I'll have to go back and compare the "competition" and "standard" models. Maybe it's me, but I thought they both had the problem.
Seems like they left the Extra 260 alone with regard to that issue.
On the other hand, maybe a more "snap happy" simulation is good training!
Hide Signatures
(in reply to rajul)
       Post #: 3
RE: Aerofly 5 for Mac violent wing drop problem - 2/7/2011 10:51 AM
rajul
Score: 105
Status: offline
It's better to create a new model and not mess with the stock models (competition and standard). Here's some notes on editing:
If you want to do editing with testing, the following procedure is recommended:
1. Save Model as ... and give it a name and description you like.
2. Edit some values, click "Test"
if you like the changes, save the model
if you don't, reload the last saved model or remember which parameter you changed and try other values.
After editing some parts/parameters (without clicking "Test") clicking "revert part" brings back the parameter values as they were ON OPENING THE EDITOR. The button is meant to be used if a part/value got messed up while editing. Especially in engine or Aerodynamic interactive plots. If you "Test" once, you cannot go back.
Mike Marks
RCU Moderator
Hide Signatures
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.281RCU1
