ezrun brushless motor .....HELP!!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> 1/16th, 1/18th, Mini & Micro RC Cars >> ezrun brushless motor .....HELP!! Page: [1]
Login
ezrun brushless motor .....HELP!! - 2/6/2011 1:31 AM
ohlott
Score: 100
Last Login: 4/11/2011
Status: offline
 I have a ezrun brushless combo that I got new..hooked it up today to a tamtech frog...and the wires from the engine started to get really hot and smoke. Why? Running 1600 mah battery with traxxs connectors.
Thanks for the help/
< Message edited by ohlott -- 2/6/2011 3:11 AM >
Hide Signatures
       Post #: 1
RE: ezrun brushless motor .....HELP!! - 2/6/2011 2:04 AM
The_Shark
Score: 494
Last Login: 6/11/2013
Status: offline
.. maybe you have the power plugged into the trigger line or something (not real familiar in the naming) the two outside wires are swappable, however the center wire must be mated with the correct wire (the center wire) hopefully its still useable, but smoke is usually fatal.
_____________________________
Signature
(Max. 125 chars. 2 lines max)
Hide Signatures
(in reply to ohlott)
       Post #: 2
RE: ezrun brushless motor .....HELP!! - 2/6/2011 2:44 AM
SyCo_VeNoM
Score: 626
Last Login: 6/19/2013
Status: offline
pics of the setup would help rule out a wiring issue
Chances are either the setup was too high KV for the RC. Smaller BL motors are usually EXTREMELY high in KV rating, and need to be geared very low.
Or you wired it wrong. Almost want to doubt this one seeing I swore all the lower amperage EZ-runs are pre-wired.
Or you got a bad setup. Lets face it bad ones do get through (and before anyone says SEE CHEAP I've heard of way more castle products bursting into flames than HW)
With great speed comes greater repair bills.
Look at my garage for my model list.
Hide Signatures
(in reply to The_Shark)
       Post #: 3
RE: ezrun brushless motor .....HELP!! - 2/6/2011 3:39 AM
ohlott
Score: 100
Status: offline
Here are a few pictures...also the motor is a 7800kv with a 18t gear.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to SyCo_VeNoM)
       Post #: 4
RE: ezrun brushless motor .....HELP!! - 2/6/2011 4:19 AM
rubber_junkie
Score: 100
Last Login: 4/22/2012
Status: offline
I feel you've overgeared it, how long a run had?
nt18+mt,blaze,mini t,M18 pro,recoil,Gpv1,crt.5 pro,hyper mini stE,hyper8 proE,revo BB,mtx3,ts4n pro,ntc3ft,ft tc4,Er-1,MI09s
Hide Signatures
       Post #: 5
RE: ezrun brushless motor .....HELP!! - 2/6/2011 4:24 AM
ohlott
Score: 100
Status: offline
I just ran it for a few seconds and the motor wires got really hot and started to melt the casing off. So I shold use a lower gear?  What size?
thanks
Hide Signatures
(in reply to rubber_junkie)
       Post #: 6
RE: ezrun brushless motor .....HELP!! - 2/6/2011 4:28 AM
rubber_junkie
Score: 100
Status: offline
if just few sec's an that happened something binding in tranmission and/or mesh to tight?
Hide Signatures
       Post #: 7
RE: ezrun brushless motor .....HELP!! - 2/7/2011 1:58 AM
ohlott
Score: 100
Status: offline
Found the problem the screws that hold the motor on were a tad to long and were hitting the coil inside the motor. Put some spacers on the screws and good to go.
thanks for all your help.
Hide Signatures
       Post #: 8
RE: ezrun brushless motor .....HELP!! - 2/8/2011 12:53 AM
rubber_junkie
Score: 100
Status: offline
nice 1!
Hide Signatures
       Post #: 9
RE: ezrun brushless motor .....HELP!! - 2/14/2011 12:37 AM
studysession
Score: 105
Last Login: 4/24/2013
Status: offline
quote:
ORIGINAL: rubber_junkie
That is my first guess as well. I don't think the gearing is to high if all it was couple of sec's.
My CNC Website:
http://celticmachining.com
My CNC blog:
http://cncinside.com
Hide Signatures
       Post #: 10
studysession
Score: 105
Status: offline
quote:
ORIGINAL: ohlott
Glad you got it working.
My CNC Website:
My CNC blog:
Hide Signatures
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.266RCU1
