RE: Skymaster 1:6 A10 Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Skymaster 1:6 A10 Build
Page: <<   < prev  13 14 [15] 16 17 18 19 20 21 22   next >   >>
Login
RE: Skymaster 1:6 A10 Build - 8/8/2011 7:40 PM
Gonzalo38
Score: 100
Last Login: 6/20/2013
Status: offline
By the way.... our builder is the same, so he nows has experience with Michele's A-10
_____________________________
My Gallery http://www.rcuniverse.com/community/profile.cfm?section=gallery&memid=314761
Hide Signatures
(in reply to JetsRC)
       Post #: 351
RE: Skymaster 1:6 A10 Build - 8/8/2011 9:24 PM
gonzalom
Score: 100
Status: offline
Hey Michael,
I refused to put Bush as a pilot on my A10.... you see I am a Chilean who lives in California as a Democrat! I have to visit you guys one of these days!
Michael I should have a conference call with you and Gonzalo to hear more about your first flights with the A10!
I am planning to order the pilot from http://www.maffscav.de/ as Matthias have done most of my pilots in the past with customize uniforms!
I can't wait to hear more about your A10s back to work on mine!
Gonzalo
Hide Signatures
       Post #: 352
RE: Skymaster 1:6 A10 Build - 8/8/2011 9:37 PM
JetsRC
Score: 100
Last Login: 6/17/2013
Status: offline
Gonzalo, you are welcome anytime here... we will have some pisco sour ready for you...
I see what you mean about the bush pilot, but it is so well made...
JetsRC / Skymaster Jets / Xtreme Jets / Jet Central
www.jetsrc.com
Hide Signatures
(in reply to gonzalom)
       Post #: 353
RE: Skymaster 1:6 A10 Build - 8/8/2011 10:42 PM
Gonzalo38
Score: 100
Status: offline
Pisco Sour ? I'm in........
Hide Signatures
       Post #: 354
RE: Skymaster 1:6 A10 Build - 8/10/2011 1:35 AM
Gonzalo38
Score: 100
Status: offline
quote:
ORIGINAL: Likai
y
Here is the gsolution to lock the main gear on up- position and prevent the main gear pull out by high +G load. It is very simple, a small air cylinder and ply wood mounting bracket, that's all. There is a spring in the cylinder to pull the cylinder rod return for unlocking and an air tube connect to the cylinder supplies air pressure for up-locking. So this is a failsafe design, if air pressure is out, the main gear will unlocking and down automatically.
The air line of this up-locking cylinder is connected to the air line of close-side of nose gear door cylinder, so no extra control valve and sequence setting are needed. This is meaning when nose gear door is closed, the main gear up-locking is actived in the same time.
My A-10 arrived with the up-locking cylinders but they are not spring type. Actually, they are like a normal cylinder with two outlets instead of one. This means that I have to connect them to the open and close side of the nose gear door cylinder ?
Hide Signatures
(in reply to Likai)
       Post #: 355
RE: Skymaster 1:6 A10 Build - 8/10/2011 1:49 AM
Gonzalo38
Score: 100
Status: offline
This was the first day of work on my A-10.
All extensions are done and UAT's, fuel solenoids/pumps and air valve are installed. I wouldn't be surprised that tomorrow all the servos are installed since before I left, there were already three of them ready.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Gonzalo38)
       Post #: 356
RE: Skymaster 1:6 A10 Build - 8/10/2011 2:12 AM
JackD
Score: 100
Status: offline
quote:
ORIGINAL: JetsRC
Now... Gonzalo is a Peruvian Chilean. I want to see how he reacts to the Pisco debate!!!!! is it peruvian or chilean??? haha
Jack Gerardo Diaz
BVM Rep, Team Horizon, Team Jet Central
Hide Signatures
       Post #: 357
RE: Skymaster 1:6 A10 Build - 8/10/2011 2:19 AM
Gonzalo38
Score: 100
Status: offline
Jack....... it doesn't matter if Pisco is Peruvian or Chilean. The only important thing is to drink it Cheers.
Hide Signatures
(in reply to JackD)
       Post #: 358
RE: Skymaster 1:6 A10 Build - 8/10/2011 2:41 AM
gonzalom
Score: 100
Status: offline
The debate about the Pisco it's quite simple! Pisco=Peru! is just simple math!
Gonzalo38, my lock systems has the 2 outlets too as you described and the spring which it is inside. You should connect the lock as you do with your doors air system. When I simulate a loss of pressure then you see the spring active, quite nice and secure.
I am dying to see how your A10’s goes with the Cheetahs? Are you guys planning to modify the exhausts.... as they are made more for a P80? It might be OK but check if the diam of the exhaust are OK.
So far I am very incline to get 2 new JetCat P-140rx for mine perhaps Cheetahs or Merlins 140 are a nice option too.
Gonzalo
Hide Signatures
       Post #: 359
RE: Skymaster 1:6 A10 Build - 8/13/2011 1:25 PM
snobird
Score: 100
Last Login: 6/19/2013
Status: offline
Gonzalom, my A-10 with the Cheetahs is all ready to go, heading to the New England Jet Rally next weekend.. using the exhaust pipes as supplied by SM. will post some pictures later.
Hide Signatures
       Post #: 360
RE: Skymaster 1:6 A10 Build - 8/14/2011 3:13 AM
ECalderon
Score: 100
Status: offline
Hi
Here are some picture of Michels Durand's A-10 that was maidened this weekend. It has two JC Cheetahs and it flys awsome. Probably will be posting video soon.
Regards
Eduardo
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to snobird)
       Post #: 361
RE: Skymaster 1:6 A10 Build - 8/14/2011 3:20 AM
JetsRC
Score: 100
Status: offline
Hi guys, ok this Friday I did the maiden of my A-10, did a couple of flights and today a few more. Wow this jet is amazing, very impressive in the air and it fly's very well.
I installed 2 cheetah's for power, this is more than enough, regular flight needed only half power and I only went full power on big verticals.
CG I went with 145mm, at this point it flew very stable and it was a no issue on stalls on specially on landing, it was rock solid.
IN general a great jet, I just love it and I am sure I will have some great fun with this one.
Here is a video, it is a preliminary and the aspect is all wrong but it gives the idea on todays flight, later I will post a better one.
On thing to keep in mind. The elevators need to be slightly up to level flight and the recomended travel on the ailerons y too much and the A-10 is too sensitive on this value, just put a little less.
Video: http://www.youtube.com/watch?v=FiiwMmEcsWI
Michel
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by JetsRC -- 8/15/2011 12:09 AM >
www.jetsrc.com
Hide Signatures
       Post #: 362
RE: Skymaster 1:6 A10 Build - 8/14/2011 3:22 AM
JetsRC
Score: 100
Status: offline
Nice pics Eduardo, thanks...
www.jetsrc.com
Hide Signatures
       Post #: 363
RE: Skymaster 1:6 A10 Build - 8/14/2011 3:55 AM
gonzalom
Score: 100
Status: offline
Hi Michael,
Outstanding! a big CONGRATULATIONS to you! I spoke early Friday with my tocayo Gonzalo and he told that you guys where ready to maiden on that day.
When you have the time please share with us your setting regarding ATV's expos etc including how much up or down elevator for the flaps on landing.
Love the video! and what a superb landing you did! Did you used the provided exhausts on the A10 for the Cheetahs? Using most of the flight 1/2 power I wonder for how long thoese tanks will go.
Thank you so much for sharing with us!
Gonzalo
Northern California
P.S. That Bush pilot looks very good and did a great job landing! remarkable!!
Hide Signatures
       Post #: 364
RE: Skymaster 1:6 A10 Build - 8/14/2011 9:12 AM
MNModels
Score: 100
Status: offline
Michel,
Congratulations!
Morné
MNModels
Skymaster & Xtremejets
Hide Signatures
       Post #: 365
RE: Skymaster 1:6 A10 Build - 8/14/2011 10:41 AM
Ali
Score: 135
Status: online
Awesome flying Michel.
Al''''s Hobbies. Airworld. BVM, Tams, Jet Cat, AMT, Skymaster, FEJ, pull over, Tomahawk, Skygate, C-ARF, Jet-Teng,Kingtech
Hide Signatures
(in reply to MNModels)
       Post #: 366
RE: Skymaster 1:6 A10 Build - 8/15/2011 12:21 AM
JetsRC
Score: 100
Status: offline
Thanks guys, the jet is a lot of fun to fly.
Gonzalo, I used the standard pipe, no problems so far.
Regarding some settings:
CG 145, I heard that 150 was a bit tail heavy so I went a bit forward. The jet flew very nice like this and I intend to leave it here. It is very stable and confortable on landing.
On throws I went with SM recomendations, but too much for my taste on ailerons so I lowered that a bit.
For expos I used 35% more or less, this depends a lot on personal preference. Remember on Futaba radios this is -35%
For flaps I went as much as what the servo with a 2" arm will give me. I found that when aplying flaps te jet floats very nice with no strange things.
After a 6 minute flight I still have about 1/3 of fuel in the tanks. I will probably go for 7 minutes in the future... for now 6 minutes leaves me with enough fuel to have a few go arounds until I get used to the A-10.
With the 2 cheetahs power managment is important, the jet as a lot of extra power with this 2 turbines so if you go this way be sure not to go on full throttle all the time...
Next step is flying with all bombs on...
I just updated the video with some extra footage and the correct aspect ratio... check it out...
Michel
www.jetsrc.com
Hide Signatures
(in reply to Ali)
       Post #: 367
RE: Skymaster 1:6 A10 Build - 8/15/2011 5:31 PM
pilot tw
Score: 103
Status: offline
Hi, Mihel
Congratulation! for your maiden for A-10.,
Will you be there Jet power 2011?? before you told me , that you will be there,
Best regards
Anton
owner - Skymaster Jet
X-Treme Jets
Hide Signatures
       Post #: 368
RE: Skymaster 1:6 A10 Build - 8/15/2011 5:35 PM
pilot tw
Score: 103
Status: offline
Hi, all
we now building the A-10 RTF at SM factory by Professional Builder, here are some pictures.,
Best regards
Anton
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
X-Treme Jets
Hide Signatures
(in reply to pilot tw)
       Post #: 369
RE: Skymaster 1:6 A10 Build - 8/15/2011 5:45 PM
pilot tw
Score: 103
Status: offline
more pictures.....
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
X-Treme Jets
Hide Signatures
       Post #: 370
RE: Skymaster 1:6 A10 Build - 8/18/2011 8:43 AM
thunderbolt90
Score: 100
Last Login: 1/27/2013
Status: offline
Hello Every one,
Alex48, how many lead have you in the nose with the two merlin 140 ?, i'm very interresting by this A10 skymaster and probably with two jetcat P100 and without pylon and ordonance , do you think it possible to dry weight 22 kg in this setting ?
Congratulation for your work, it's perfect .
Eric .
Hide Signatures
       Post #: 371
RE: Skymaster 1:6 A10 Build - 8/18/2011 8:07 PM
schroedm
Score: 103
Status: offline
Eric,
I think Al had 0.5lbs of lead in the nose.
Also, I would say you could make 22kg with ought the pylons and ordnance (they are surprisingly heavy)
Rgds,
Mark
Hide Signatures
(in reply to thunderbolt90)
       Post #: 372
RE: Skymaster 1:6 A10 Build - 8/18/2011 8:10 PM
schroedm
Score: 103
Status: offline
Michel,
Did you run the tailpipes supplied in the kit? Did you test for the power off climbing scenario?? Just wondered if you had changing pitch trims and were seeing the same issues?
I'm 95% sure I'm about to attack mine and get it going. I just don't want to go through the effort and find it has odd flying tendencies (especially when the Mibo is supposed to be an amazing flyer).
I would be interested to hear just what the difference is between the SM and A-10 flying wise. They're so similar in size and weight that I would hope they're almost the same?????
Cheers,
Mark
Hide Signatures
(in reply to schroedm)
       Post #: 373
RE: Skymaster 1:6 A10 Build - 8/18/2011 10:57 PM
wxman2
Score: 100
Status: offline
I am starting to put a build list together for a Skymaster A10; is there any reason why not to go with this Slymaster product?
John
Hide Signatures
       Post #: 374
RE: Skymaster 1:6 A10 Build - 8/19/2011 8:49 AM
thunderbolt90
Score: 100
Status: offline
Ok Mark,
It's great .
Are you a opinion about the difference between the Skymaster and the flyeaglejet 1/6.25, quality , fly , landing gear ect ..
When i sure, i make my order in early september .
Regards .
Eric
Hide Signatures
(in reply to wxman2)
       Post #: 375
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.969RCU1
