EZRUN s10 Problem    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> EZRUN s10 Problem
Page: [1]
Login
EZRUN s10 Problem - 2/8/2011 3:10 AM
ebackus1
Score: 100
Last Login: 3/4/2011
Status: offline
I purchased a Redcat Volcano epx pro about a month ago and upgraded to 2s lipo by zippy. I used a programming card to attempt to change the setting of the ESC ( EZRUN s10)but it will not go past program function #5 before it cycles back to #1. According to the hobbywing site I should be able to access #1-10. Does anyone know what could be wrong my ESC? Any help would be greatly appreciated.
Hide Signatures
       Post #: 1
RE: EZRUN s10 Problem - 2/8/2011 6:10 PM
brew99
Score: 100
Last Login: 7/19/2011
Status: offline
I don't have a s10 but do have the 35A-SL.   #5 and above are indicated by a long flash, so might you be confusing the long and short flashes on the ESC?   I don't use a programmer card, so rely on the led on the ESC to indicate what level it is at during programming.
Hide Signatures
(in reply to ebackus1)
       Post #: 2
RE: EZRUN s10 Problem - 2/8/2011 9:02 PM
rccrazer
Score: 100
Last Login: 5/16/2013
Status: offline
 if your using a program card then you will need to upgrade your programing. i use the advanced program card and it does EVERYTHING! i actually ditched my mamba max for the hobbywings.
Hide Signatures
       Post #: 3
RE: EZRUN s10 Problem - 2/9/2011 12:06 AM
ebackus1
Score: 100
Status: offline
I was able to the higher numbers before using manual programming but now it will not go past 5 with manual or programming card.  Under program function 4 I am only able to go to #4 before it cycles back to #1.  I know hobbywing make a good product, just not sure what is going on.
Hide Signatures
(in reply to brew99)
       Post #: 4
RE: EZRUN s10 Problem - 12/28/2012 5:15 AM
scott63b
Score: 100
Last Login: 1/12/2013
Status: offline
from what i have understood in the flow chart and programing (;look Closely) the E8 goes 1 thru 10
The E10 and other models that are listed for  that ESC only go 1 thru 4. watch for differences on chart from E8 controller to e10 controller.
Hide Signatures
       Post #: 5
RE: EZRUN s10 Problem - 12/30/2012 1:51 AM
jroptop
Score: 100
Last Login: 3/10/2013
Status: offline
OH BOY,I also bought my son the Volcano EXP PROand has the S10 ESC and I purchased the Hobbywing programming card along with a Lipo battery from Hobbyparts also but havent got it yet.Im assuming im gonna have the same issues?????????????
Hide Signatures
(in reply to scott63b)
       Post #: 6
RE: EZRUN s10 Problem - 12/30/2012 1:58 AM
nitrosportsandrunner
Score: 296
Last Login: 5/24/2013
Status: offline
hum, pretty sure ive used the program card on a s-10 without issue.
manual programming is possible, but it sucks. Now way to know for certain if you got it right.
_____________________________
Redcat Mirage Pro, Tornado EPX Pro, SC10, TTR Phoenix XB. Redcat Racing Dealer.
Hide Signatures
(in reply to jroptop)
       Post #: 7
RE: EZRUN s10 Problem - 12/30/2012 2:01 AM
jroptop
Score: 100
Status: offline
Ive done the manual programming and yeah it does suck,but possible,just have to keep track of the flashes corrisponding to the function.I will report back once I get the program card.
Hide Signatures
(in reply to nitrosportsandrunner)
       Post #: 8
RE: EZRUN s10 Problem - 1/1/2013 1:02 AM
jroptop
Score: 100
Status: offline
quote:
ORIGINAL: nitrosportsandrunner
Well,used the program card today on theVolcano EXP Pro and sure enough I canonly go up to program #6 and wont allow me to go further,I also used it ona Caldera 10E and had NO issues with programmingthrough all 12 programs.
Hide Signatures
       Post #: 9
RE: EZRUN s10 Problem - 1/1/2013 2:23 AM
Score: 296
Status: offline
quote:
ORIGINAL: jroptop
so the caldera must have the ezrun 35a, and the pro's have the s-10.
Someone said the s-10 was a 60amp, dont know if thats true tho.
But it seems sure that it doesnt have as many program features as the 35a.
IMO, as long as you can adjust the punch control and brake force thats all you really need....well, all I need anyway.
Hide Signatures
       Post #: 10
RE: EZRUN s10 Problem - 1/1/2013 2:34 AM
jroptop
Score: 100
Status: offline
Thats basically what I did,level 1 on the punch and left the brake force the same.What I do plan on doing is the little tips you suggested as far as moving the tierods in closer to the hub,the bits of fuel line on the dogebones hopefully will eliminate most of the wheels wobbling top to bottom.Thanks again for you informative feedback!
quote:
ORIGINAL: jroptop
Hide Signatures
       Post #: 11
RE: EZRUN s10 Problem - 1/1/2013 2:39 AM
jroptop
Score: 100
Status: offline
I wonder if the ESC are interchangable between the Volcano EXP pro and the Caldera 10e?
< Message edited by jroptop -- 1/9/2013 12:40 AM >
Hide Signatures
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.566RCU1
