pete913
ND, USA Status: offline
I just don't see why anyone would think that gas models are either more expensive than glow, or more dangerous. What's the cost of a new YS 120 compared to a G45? Nor sure myself, but I'd bet the YS is more expensive. Actually, when you start adding up all the field equipment for glow power, all of which is unnecessary on a gasser, the gasser looks considerably cheaper to me, never mind the fuel cost. An 8 lb .60 glow model hitting you in the head is gonna kill you just as dead as a full scale airplane, so I don't follow the danger issue either. Fire is also a non issue. Alcohol mixed with nitro is less flammable than gasoline? In your dreams. Only difference there is that you can see a gasoline flame, alcohol burns without a visible flame, so in that respect, I'd say gas was safer if anything. Sure, bigger planes can get more expensive, but that's not always true either. I can scratch build one heck of a big gasser for the cost of a typical high end glow powerd ARF, and I don't have to wonder what's under the covering, cause I built every stick of it myself.
