Real Flight G5 Wireless Controller?
Are there any wireless controllers with full fligh control capability that work with RF G5, the cord bugs me?
Thank you.
Thank you.
RE: Real Flight G5 Wireless Controller?
If you fly Futaba take a look here www.simstream.co.uk you will still need to connect your realflight tx and put it out of sight behind your pc.
ORIGINAL: ModelGuard.Com
Thanks.
You wont need a review, basically SimStream is a wiring harness. It uses the new Futaba WTR-7 wireless trainer unit. All electronics used are supplied by Futaba, so as with all things Futaba, it just works.
Keep in mind that the transmitter you want to run the sim with must be a Futaba FASST transmitter.
I really like the idea, but the one wrinkle for users of RF, is that you still have to have access to the RF Interlink controller to be able to press the reset button to validate the controller[&o]
Pete
Pete
Yes with RealFlight you would have to press the reset at the beginning of each flying session, this would only need doing once at the start, after that you can use auto-reset.
With Phoenix and reflex you would not need the dummy Tx connected.
LAST week or so fo 20 % discount offer by the way.
www.simstream.co.uk
[youtube]http://www.youtube.com/watch?v=G35c81FnV24[/youtube]
www.simstream.co.uk
