RE: Black Horse Models FW190 A8 70    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Black Horse Models FW190 A8 70
Page: <<   < prev  1 2 3 4 [5] 6 7   next >   >>
Login
RE: Black Horse Models FW190 A8 70 - 7/12/2012 11:57 PM
kahloq
Score: 125
Last Login: 5/25/2013
Status: offline
quote:
ORIGINAL: TimBle
they are way too long for the BH FW 190
True..which just signifies one more out of scale aspect to the BH. It flies well tho.
Hide Signatures
(in reply to TimBle)
       Post #: 101
RE: Black Horse Models FW190 A8 70 - 9/24/2012 12:56 AM
RBean
Score: 115
Status: offline
Hobby People had this thing on sale for $299. I couldn't resist and my finger clicked "Order". I'm planning on installing a DLE 30 and Spring Air retracts with Wheels as large as possible for our grass flying field. I will give up a little scale accuracy to have a good flying airplane. I had a warbird, Top Flite kit built P-40 which was very scale and heavy which flew like crap. It was so much work to fly that it was just not fun. After 120 flights without a crash, I don't know how, I decommissioned the plane and put the hardware else where.
Hide Signatures
(in reply to kahloq)
       Post #: 102
RE: Black Horse Models FW190 A8 70 - 9/24/2012 1:06 AM
handyman 220
Score: 100
Status: offline
The $299 price is what attracted me also. I liked it when it first came out, but wasn't going to pay $499 for it. It is a nice semi-scale plane for the sale price, I think you will be quite happy with it. I'm not sure how good the included retracts are, but you stated you are putting in Spring Airs anyhow.
_____________________________
Do it right the first time, or not at all!
Hide Signatures
(in reply to RBean)
       Post #: 103
RE: Black Horse Models FW190 A8 70 - 9/24/2012 3:31 AM
flycatch
Score: 118
Status: offline
Retracts are S***. I replace them with electrics.
Hide Signatures
(in reply to handyman 220)
       Post #: 104
RE: Black Horse Models FW190 A8 70 - 9/25/2012 1:02 AM
predman
Score: 100
Status: offline
I have one of these planes powered w a dle 20cc and it flies perfect with that. I like the plane but it is cheaply made, the retracts are starting to get real wobbly after about ten flights, no hard landings. I have had ram planes and the quality of them is much better than bh, and so is the price. I would rather have the esm over the bh.
Hide Signatures
(in reply to RBean)
       Post #: 105
RE: Black Horse Models FW190 A8 70 - 9/25/2012 6:25 AM
kahloq
Score: 125
Status: offline
Not an A model, but its still a 190. ESM 82.5" with rimfire 65 on 12s. A few things left to do tho
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to predman)
       Post #: 106
RE: Black Horse Models FW190 A8 70 - 9/25/2012 8:24 AM
w1nd6urfa
Score: 100
Status: offline
That's lovely kahloq !
I wonder is the paint scheme and markings accurrate, shouldn't there be a stripe in the aft fuselage?
A designer knows he has achieved perfection when there is nothing left to take away (Antoine de Saint-Exupery)
Hide Signatures
       Post #: 107
RE: Black Horse Models FW190 A8 70 - 9/26/2012 3:53 AM
kahloq
Score: 125
Status: offline
quote:
ORIGINAL: w1nd6urfa
Yes there should be. I just havent painted them on yet. Should be a white and black dual stripe.
Hide Signatures
(in reply to w1nd6urfa)
       Post #: 108
RE: Black Horse Models FW190 A8 70 - 9/28/2012 3:58 AM
predman
Score: 100
Status: offline
Ok had enough of the crappy stock retracts, put on some Robarts and now I'll have some piece of mind knowing they will work like they should.
Hide Signatures
       Post #: 109
RE: Black Horse Models FW190 A8 70 - 9/28/2012 5:17 AM
sharam
Score: 105
Status: offline
 Which Robarts did you use?  I have tried the eflite retracts with the original struts but no joy!
Trex 700 OS105 Vbar
Logo Xxtreme 800
Hide Signatures
       Post #: 110
RE: Black Horse Models FW190 A8 70 - 9/28/2012 7:30 AM
predman
Score: 100
Status: offline
Ill have to check, bought them from someone at the club. I used the stock struts w the Robarts retracts, testing tommorow and ill report how it goes. So far they are much sturdier w no slop, and were real easy to install. I just had to cut a very little wood in the retract mount and they dropped in.
Hide Signatures
(in reply to sharam)
       Post #: 111
RE: Black Horse Models FW190 A8 70 - 9/29/2012 6:08 PM
sharam
Score: 105
Status: offline
Guys, I find the CG as described in the manual, a little tail heavy.  The plane tends to want to bounce on landing and porpoise in the air.  Does any one else feel this way?  As I have moved the CG forward, the plane handles better and settles in more nicely on landing.  I would appreciate any thoughts with folks who have many flights on this airframe.  Most comments on this thread seem to say that the CG is right where the manual says.
I am running a Saito FG-30 gas on this model and the combo is fantastic - great sound, power, and looks!
Trex 700 OS105 Vbar
Logo Xxtreme 800
Hide Signatures
       Post #: 112
RE: Black Horse Models FW190 A8 70 - 9/29/2012 6:44 PM
flycatch
Score: 118
Status: offline
quote:
ORIGINAL: sharam
First thing is to do the math. Won't be the first time the numbers are off. In the case of this model the numbers are correct. I set mine at 27%. If your using the supplied landing gear assembly replace it with an aftermarket. I installed a set of modified "Robart" oleo struts and you should also replace the tires with "Robart" low bounce units. Last but not least land on the mains for wheel landings. This plane flies and looks great.
Hide Signatures
       Post #: 113
RE: Black Horse Models FW190 A8 70 - 10/1/2012 6:26 PM
sharam
Score: 105
Status: offline
Here is a video of the FW-190.  Engine is a Saito FG-30 (four stroke gas)!  I love the sound of that engine!
http://www.youtube.com/watch?v=ek0exqdmOB4&feature=g-all-u
Landing gear is the original struts used with eflite 120 size retracts.  One side is a bit problematic and I need to make some adjustments - one retract just doesn't lock up well and binds a bit.
Some trimming going on in the early part of the flight!  A little down elev, right rudder, and some aileron trim as well.
Flight time was about 7 minutes but I still had fuel to go for another 10+ minutes!
My friends got to fly the plane as well so you have at least three different people at the sticks!
Trex 700 OS105 Vbar
Logo Xxtreme 800
Hide Signatures
       Post #: 114
RE: Black Horse Models FW190 A8 70 - 10/1/2012 8:48 PM
RBean
Score: 115
Status: offline
sharam,
Great video. I just got mine in from Hobby People. Planning on using a DLE 30 which I already have and 85 degree Spring Air retracts which I already have. I think I will be able to use the kit struts. I agree the stock retracts don't look like they will hold up very well, especially on our grass runway. It looks like 4" wheels will fit so I will try to use them as I already have a pair.
Hide Signatures
       Post #: 115
RE: Black Horse Models FW190 A8 70 - 10/4/2012 7:11 AM
predman
Score: 100
Status: offline
Ok heres mine in the air! Great flyer, DLE 20 up front.
Click for fullsize
Hide Signatures
(in reply to RBean)
       Post #: 116
RE: Black Horse Models FW190 A8 70 - 10/10/2012 5:01 PM
RBean
Score: 115
Status: offline
Ive just about got this thing ready to go. Used a DLE30 as that is what I had. I had to move the cowl 1/2 inch forward to have enough room. I want to use a three blade prop. Found a 17-8 three blade but can't find the correct shaped spinner in 3.25" diameter in uncut or three blade. I used Spring Air retracts with the stock struts. 4" wheels. CG is 135mm back instead of 140mm as in instruction. Control throws set as per instructions. Total dry weight 12.4 lbs. which should be ok. I have a KMP Hurricane this size at 13.1 lbs and a CMP Zero 71" wing span at 15.9 lbs and they fly ok. Also have 74 degree trunions ordered from Spring Air to convert gear to look more scale but they are not in yet. I'm also going to block part of the cowl intake. Flaps 15 degrees 1/2 and 35 degrees full.
Any advice before the test flight regarding this plane?
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 117
RE: Black Horse Models FW190 A8 70 - 10/10/2012 5:23 PM
sharam
Score: 105
Status: offline
 RBean,
Looks great.
My CG is at 135.  My flaps also are set up like yours.  I blocked the air intake as well to better streamline the airflow.
DLE 30 should be plenty of power!  Good luck on your maiden!
Trex 700 OS105 Vbar
Logo Xxtreme 800
Hide Signatures
(in reply to RBean)
       Post #: 118
RE: Black Horse Models FW190 A8 70 - 10/14/2012 5:06 AM
RBean
Score: 115
Status: offline
Had the maiden flight today. A bit windy with off and on shifting cross wind. Took off ok, only about 25 ft at half throttle at most. It needed right ailron trim and down trim. Seemed very touchy in pitch. Retracted gear with little trim change. Flew around to trim some more. Put gear down and half flaps, maybe a little pitch up. Slowed down and had a good landing a quite a slow speed. I'm going to reduced the elevator control throws and add more negative expo. Not sure if I want to move the cg further forward or not yet. I never got over half throttle as it was twitcyh enough at slower speeds. Its a worst cross wind forcast for tomorrow so maybe later this week. I think this plane will fly fine, just needs a little tweiking. The DLE 30 is plenty of power. Turning a 18-8 two blade prop at 8,300 rpm.
Hide Signatures
       Post #: 119
RE: Black Horse Models FW190 A8 70 - 10/14/2012 5:37 AM
flycatch
Score: 118
Status: offline
Either your thrust line is off or you tail heavy. How much rt air trim a little or alot? Do you have coupling for elevator and flap mixing?
Hide Signatures
(in reply to RBean)
       Post #: 120
RE: Black Horse Models FW190 A8 70 - 10/14/2012 4:43 PM
RBean
Score: 115
Status: offline
It took 5 or 6 clicks of right trim and some down trim. Looked at elevators and they are straight. No noticable down deflection. Have not put in any mixes yet re flaps extention. If its still too touchy in pitch, I'll move one battery forward some but not much. Don't want to make it nose heavy and increase landing speed.
Hide Signatures
(in reply to flycatch)
       Post #: 121
RE: Black Horse Models FW190 A8 70 - 10/14/2012 5:19 PM
flycatch
Score: 118
Status: offline
quote:
ORIGINAL: RBean
Is the plane tunring or rolling to the left. If it is rolling then you have either a horizontal empanage misalignment or wing alignment. The wing and stabilizer must be aligned to oneanother. I just purchased a H9 Taylorcraft ARF and the fuselage was built with the mounting platform of the tail group incorrectly. I ended up shimming the left side to level the horizontal stabilizer. Not saying it is in the empanage it could also be in the wing saddle. The wing and stab must be aligned to oneanother. If it turns to the left I would check the vertical stabilizer for alignment. I addressed the CG issue and that is a matter of choice but I initially always start at 27%. The plane should not be pitch sensitive unless you have deviated from the factory setting by increasing the elevator throw. I fly mine with no expodential with the CG at 27%. There is a UTube posting of this plane powered by the same engine you are using and it ended up crashing due to an aft CG. I had the left airleron servo tray break free from its' mount just after take off and had no problem bringing it back safley using rudder only. This told me that it is a very stable airframe and would bring the pilot home safley. Check out my post on this site for my review of its' maiden.
Hide Signatures
(in reply to RBean)
       Post #: 122
RE: Black Horse Models FW190 A8 70 - 10/15/2012 4:13 PM
RBean
Score: 115
Status: offline
I found elevators not quite even. I adjusted. Also reduced control throws and added negative expose. Plane flew great. Did all the war bird manuvors, no problems. Plane was stable at full throttle and slowed nicely for landing. I put in 2 per cent up elevators with gear down and 5 per cent down elevators with flaps down. Seems to be about right. Still needs some right trim but not as much. No tendencey to snap out of tight turns or pull ups. No trying to roll right with throttle reduced. No more mixes needed. Lands nice for a warbird. Take offs are easy, only a little right rudder needed. I angled the gear forward with 1/8 inch ply on rear gear flange. Taxis ok on grass and no nosing over on take off. The DLE 30 is plenty of power, but not grossly over powered. This plane is a keeper.
I want to do something about the shiny finish. Some folks say use Scotch Brite on it. Also I want to put the nazi swastika on the vertical fin. I'm sure this was left off intentionally because it is illegal in Germany where some off these are imported. The some light weathering, exhaust stains and gun smoke smoke streaks etc.
Hide Signatures
       Post #: 123
RE: Black Horse Models FW190 A8 70 - 10/15/2012 4:28 PM
flycatch
Score: 118
Status: offline
Appears you have it dialed in. I also added the swastika for added realism. Have you considered adding a cockpit interior. I installed a Ty manufactured one and it takes if further torward the realism factor.
Hide Signatures
(in reply to RBean)
       Post #: 124
RE: Black Horse Models FW190 A8 70 - 10/15/2012 5:05 PM
sharam
Score: 105
Status: offline
A coat of Lustercoat flat spray works perfectly to take off the shine.  (Tower Hobbies)
Trex 700 OS105 Vbar
Logo Xxtreme 800
Hide Signatures
(in reply to RBean)
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.719RCU1
