Bill Vargas
CA, USA Status: offline
Kevin, 7. General Model Aircraft Requirements (Note: for event-specific requirements such as wing area, weight, engine displacement, etc., please refer to the individual event listings.) 7.1. Conventional design. Aircraft used in RC Pylon events shall be of conventional design with forward wing, aft horizontal stabilizer, and a single engine mounted in front. No deltas or other tailless designs shall be allowed. An aircraft shall be considered tailless if the ratio of its wingspan to its overall length is greater than 2:1. The “overall length” of the aircraft, for purposes of this measurement, is the distance from the front of the propeller to the trailing edge of the rearmost movable tail surface. BV
_____________________________
If it ain't leaking oil, then something's wrong,,, USMC, RETIRED!
