RE: Yellow Aircraft Mako Build Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Skygate CARF, Viperjet - RTF
Seller:  snobird
Details:   $9,600.00   |  6/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Yellow Aircraft Mako Build Thread
Page: <<   < prev  1 2 3 4 5 [6]
Login
RE: Yellow Aircraft Mako Build Thread - 6/14/2011 3:00 PM
YellowAircraft
Score: 196
Last Login: 6/18/2013
Status: offline
Jim,
Thanks! No, this plane was built for a customer, and I'm going to fix the CG and get it properly trimmed out then ship it off.
Gunradd,
YOU WERE RIGHT. There, I said it! I don't have any explanation for it, and as the field rep, it's a little awkward to not be the one with the best information on this, but it is what it is. What I can't figure out is why that CG worked fine on the last one....
As you discovered, the landing was SCARY tail-heavy. It was barely controllable on the landing, and I'm sure that if I hadn't goosed the power at the last minute there, it would have stalled and pancaked in. The good news is that there is a lot of battery weight in the tail to make the CG. Some of that gets to move forward, and some of it gets to come out.
I'm going to set up some expo, too, for the second flight. The pitch and roll were really sensitive, but I think the CG will relax some of that.
The total flight was 4:40, with the timer set for 3:30. I'll know later how much juice was left in the packs.
_____________________________
Yellow Aircraft, JetCat Engines and Turn Key Jets
yellowaircraftplanesdotcom
Hide Signatures
(in reply to gunradd)
       Post #: 126
RE: Yellow Aircraft Mako Build Thread - 6/14/2011 3:25 PM
SCALECRAFT
Score: 119
Last Login: 6/19/2013
Status: offline
Great job Shuan.
So what was the AUW, Kv and amp draw at full throttle. My BVM with dynemax/scorpion630 kv with 12s at full throttle draws 70amps. However, someone at the air field said impossible to draw so little amps. I am going to check with a clamp amp meter again instead of the Astro watt meter. It's amp reading may be limited to 70amp. ???
I have noticed many high amp/watt systems here. The interesting thing is that the peak numbers only last for the first few seconds of peak battery life. After that the power drops off.
I, personally am now looking to see what the average amp/watt rating is during the 4-6 min flight. The CC120HV data logging (if accurate) is a valuable tool.
Again, nice job on the whole project.
Steve
Hide Signatures
       Post #: 127
RE: Yellow Aircraft Mako Build Thread - 6/15/2011 4:31 AM
YellowAircraft
Score: 196
Status: offline
Steve,
Thanks very much. It's actually a fun plane to build, and although this one took me a little longer than I quoted, I enjoyed the project. I really enjoyed the flight (other than the landing). I doubt if yours is drawing so few amps, though. XPS says I'll be drawing 90 at full throttle. I got a lot of run time out of my ground tests. Over six minutes mixed throttle. I've got to tame down the ailerons and fly this puppy again with the correct (thank you, Gunradd) CG so I can deliver it RTF.
Hide Signatures
(in reply to SCALECRAFT)
       Post #: 128
RE: Yellow Aircraft Mako Build Thread - 6/15/2011 5:16 AM
Ron101
Score: 116
Status: offline
Nice job Shawn,
nice to see you playing with electrics even if it's for work
She flew really nice and sounded good too... your going to have a happy customer
Ron
"It''''s not personal, Sonny. It''''s strictly business."
Hide Signatures
(in reply to YellowAircraft)
       Post #: 129
RE: Yellow Aircraft Mako Build Thread - 6/27/2011 8:39 PM
YellowAircraft
Score: 196
Status: offline
Hi,
So here's an even worse video (and this guy doesn't have a good excuse like the last guy) of the second flight with the proper CG.
Lots of crosswind, but a good outing either way. What would you estimate the takeoff distance as?
Hide Signatures
(in reply to Ron101)
       Post #: 130
RE: Yellow Aircraft Mako Build Thread - 6/28/2011 2:35 AM
FalconWings
Score: 121
Status: offline
Thats the coolest foamie Ive seen!
The "new" Dynamax performs so much better than the "original" one
Buying Jet Legend? Read here: http://www.rcuniverse.com/forum/m_11372496/mpage_1/key_/tm.htm
Hide Signatures
       Post #: 131
RE: Yellow Aircraft Mako Build Thread - 6/28/2011 4:55 AM
P. Richards
Score: 105
Status: offline
Nice job Shaun nice build and nice flight with the C of G worked out...
P. Richards aka SwatTeam
Hide Signatures
       Post #: 132
RE: Yellow Aircraft Mako Build Thread - 6/28/2011 12:56 PM
YellowAircraft
Score: 196
Status: offline
Hi,
Thanks, guys. Foamie?
Hide Signatures
(in reply to P. Richards)
       Post #: 133
RE: Yellow Aircraft Mako Build Thread - 6/28/2011 1:20 PM
tp777fo
Score: 103
Status: offline
Nice job Shaun. Electrics have sure come a long way in such a short time. That looks like a perfect combination.
Tom Perry
In Dog beers, I only had one!
Hide Signatures
       Post #: 134
RE: Yellow Aircraft Mako Build Thread - 6/28/2011 2:28 PM
gunradd
Score: 120
Status: offline
Shawn it looked great!
Looks like its pretty light.
How did you end up fitting the batteires inside?
Loving my Kingtech Turbine!
Hide Signatures
(in reply to tp777fo)
       Post #: 135
RE: Yellow Aircraft Mako Build Thread - 6/28/2011 5:27 PM
SDCrashmaster
Score: 121
Last Login: 6/13/2013
Status: offline
Shaun,
Who is that slight person doing the flying?
Wow...that was the most amazing thing in the vid for me!
Yeah, I use mixing... Balsa & Dirt. ©
Hide Signatures
       Post #: 136
RE: Yellow Aircraft Mako Build Thread - 6/28/2011 8:48 PM
FalconWings
Score: 121
Status: offline
quote:
ORIGINAL: YellowAircraft
Hi,
Damn right! but a cool one!
(If you dont believe me, open up the wing panel)
Hide Signatures
       Post #: 137
RE: Yellow Aircraft Mako Build Thread - 6/28/2011 9:50 PM
YellowAircraft
Score: 196
Status: offline
Aww,
You're calling my F-16 a FOAMIE because it's got a foam wing core? It's got carbon cloth over the core, so can we call it a CARBONIE? How about a BALSIE to honor the balsa skins?
Hide Signatures
(in reply to FalconWings)
       Post #: 138
RE: Yellow Aircraft Mako Build Thread - 6/28/2011 10:21 PM
gunradd
Score: 120
Status: offline
So I guess yellowF18 twin is a foamie then also?
Does the F22 have foam core?
Hide Signatures
       Post #: 139
RE: Yellow Aircraft Mako Build Thread - 6/29/2011 12:27 AM
FalconWings
Score: 121
Status: offline
Nahh the foamie thingy is because of the hair dryer inside of it. :-)
Hide Signatures
       Post #: 140
RE: Yellow Aircraft Mako Build Thread - 6/29/2011 12:34 AM
YellowAircraft
Score: 196
Status: offline
quote:
ORIGINAL: FalconWings
D'OH!
Hide Signatures
       Post #: 141
RE: Yellow Aircraft Mako Build Thread - 3/1/2012 3:27 PM
BusdriverSA
Score: 100
Last Login: 4/15/2012
Status: offline
Yellow Aircraft,
I sent you a PM regarding the Mako with a small turbine instead of EDF (such as the P-60SE), please will you check and come back to me as soon as you can. Thanks.
BusdriverSA
Hide Signatures
       Post #: 142
RE: Yellow Aircraft Mako Build Thread - 3/2/2012 5:03 AM
jedijingle
Score: 100
Last Login: 6/4/2013
Status: offline
Busdriver,
Shaun is in production on a play right now and will likely be tied up on that for about 2 weeks.  Im sure he will chime in here, but it may take him a bit longer to respond.  Quick note, this bird flys great on a small turbine, the trick is finding room for the fuel.  A centerline wet tank works well, but finding one is tuff to do.  The BVM was the perfect wet tank (user modded of course).  Hope this helps.  Cheers.
Duct tape is like the force, It has light side and it has a dark side, and it binds the universe together.
Hide Signatures
(in reply to BusdriverSA)
       Post #: 143
RE: Yellow Aircraft Mako Build Thread - 3/2/2012 5:12 AM
SCALECRAFT
Score: 119
Status: offline
Is the BVM belly tank not available any more?
Steve
Hide Signatures
(in reply to jedijingle)
       Post #: 144
RE: Yellow Aircraft Mako Build Thread - 3/2/2012 6:15 AM
FalconWings
Score: 121
Status: offline
I have a 1/8 scale F-16 centerline wet tank, I think it handles 50 oz.
It is NIB, PM me if interested. Really good stuff!
David
Hide Signatures
       Post #: 145
RE: Yellow Aircraft Mako Build Thread - 3/2/2012 8:43 AM
BusdriverSA
Score: 100
Status: offline
jedijingle,
Thanks for leting me know - I'll wait patiently for Shaun. I guess we all have to work to earn money to support our habit....errr... hobby!
Thanks for the offer Falconwings, the centreline tank is not my favourite attachment to the F16. I'm fairly handy with basic GRP moulding so I may try to build some wing tanks rather for the extra fuel. Is it true the saddle tanks are only 24Ozs capacity - in total? Shaun's site says 24, the 'other' site says 42, so not sure which...
Cheers!
Hide Signatures
       Post #: 146
RE: Yellow Aircraft Mako Build Thread - 3/4/2012 7:14 AM
jedijingle
Score: 100
Status: offline
Busdriver I think the yellow conformals for the f16 are 32oz or 42.  You need to remember these were designed of DF and 32 oz was a perfect amount of fuel.  Youre going to be hard pressed to fuel in the wings on this bird.  The wings are thinnnnnnnn.   I think jettech makes conformals also at about 60 to 72 oz, but that is a BUNCH of nose weight at take off.  YOu maybe able to mold some custon tanks.  I think the jet techs have to go inbefore the intake due to their size, which makes them non servicible once installed.  Hope this Helps.  John
Hide Signatures
       Post #: 147
RE: Yellow Aircraft Mako Build Thread - 3/4/2012 7:21 AM
jedijingle
Score: 100
Status: offline
Busdriver I think the yellows combined between the two conformals are 48 oz.   I was thinking of the yellow f18s being 32.
Hide Signatures
       Post #: 148
RE: Yellow Aircraft Mako Build Thread - 3/4/2012 7:45 AM
YellowAircraft
Score: 196
Status: offline
John,
Thanks for the help.
Busdriver,
Did you get my message the other day? Let me know.
Hide Signatures
       Post #: 149
RE: Yellow Aircraft Mako Build Thread - 3/4/2012 11:54 AM
BusdriverSA
Score: 100
Status: offline
Thanks Jedi, I was actually talking about making some underwing 'drop' tanks like the full size, not fitting the tanks in the wings themselves...though the thought did cross my mind! I'm not sure how the plumbing for the underwing tanks would work or if the fuel pump would be able to draw fuel from so 'far' off. So I might still have to consider the underbelly tank or the jettech/mueller ones in the end...good thing the F16 has some nice big horizontal stabs for trimming.
Shaun, yes I did get your email and I did reply too, but I have re-sent it to be sure. Please let me know if you get it or not. Otherwise maybe we should just use PM's from here if we battle with normal mail. Thanks, hope the show is going well.
Cheers!
Hide Signatures
       Post #: 150
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.656RCU1
