RE: Weatronics    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Weatronics
Page: <<   < prev  1 [2]
Login
RE: Weatronics - 11/9/2012 4:13 PM
HarryC
Score: 100
Last Login: 6/19/2013
Status: offline
quote:
ORIGINAL: H�rek
I don`t have the data, but it was sendt to Weatronic for analysis.
Weatronic said one of the reasons could be pilot error, I doubt that since it spiraled very steep from 300 M.
It`s a ''talker'', and no one I know use Weatronics in jets here anymore, before this incident.
As Mike said, the system logs so much info that there is a very high probability of finding out if anything was wrong with the radio. It is not difficult for the user to check, it's easy to see lots of blank lines instead of Rx frame counts. So unless there were blank or 0 frame counts for an extended period, it's most likely that something else went wrong. There are lots and lots of other things that can go wrong like a servo going faulty, battery problems, pilot error/disorientation, structural failure and so on. It used to be very easy to blame the radio instead of our own mistakes or structural failure, the Wea gives you the data to decide if it really was the tx/rx or if the problem was somewhere else. If that owner can't point to lots of blank/0 frame counts, I can't see how he can blame the Weatronic?
Hide Signatures
(in reply to Falcon 64)
       Post #: 26
RE: Weatronics - 11/9/2012 4:37 PM
Falcon 64
Score: 100
Status: offline
I don`t know so much about it really, other than the two other causes aside with the pilot error could be fault in the transmitter (a new Futaba 12 FG wich performs flawlessly without the module), or the flat-cable with four leads. Those was the three possible reasons Weatronic concluded to be the reason. Not the module, not the system nor the receiver.
I`m sure I could provide the datas for your own judgement, I`m only underlining the fact that there is no such thing as a 100% secure link to the plane.
If any brand claim it is, it`s a reason itself to be sceptic I think. And I`m not a martor in this case, It`s just my oppinion it has to be said that there are issues and incidences happening nomatter wich RF-link we use. For some it works outstanding, for others it becomes a nightmare.
But I do know the owner is not finished with the case, meaning testing the flat-cable one leader at a time to see if the datas will repeat as the occoured in the log.
_____________________________
Avonds F-16 1:6,8 . Skymaster F-16 1:6 .
Flyeagle F-16 1:4,6
Hide Signatures
(in reply to HarryC)
       Post #: 27
RE: Weatronics - 11/9/2012 6:00 PM
Falcon 64
Score: 100
Status: offline
Check your cable..!
http://www.youtube.com/watch?v=wpzSS62TGpo
Flyeagle F-16 1:4,6
Hide Signatures
       Post #: 28
RE: Weatronics - 11/9/2012 7:50 PM
sidgates
Score: 100
Status: offline
I have had my Micro receiver and the Tx module in a Futaba 9c for over 2 yrs and no malfunction except I can not use PCM modulation. No malfunction with PPM. I don't like the cable design but I would not feel comfortable using the cable after it was subjected to the multiple bends as shown in the video. Mine is potted with glue and taped to the handle so it is less likely to be flexed.
SidGates
Web: http://www.sidgates.us
Hide Signatures
       Post #: 29
RE: Weatronics - 11/12/2012 12:34 AM
RUFTER
Score: 104
Status: online
quote:
ORIGINAL: H�rek
A new 12FG as in FASST modulation only?
I have seen what that can do, my friend nearly lost a Mibo A-10 with that combination. He abandonned the Wea system and I took his Wea equipment, I needed a DV4 to convert my Graupner MC32. Guess what, works like a charm!
In my opinion a 12FG with FASST modulation on Weatronic is a big NO-NO.
Regards, Bart.
Team Harofly
Hide Signatures
       Post #: 30
RE: Weatronics - 11/12/2012 1:16 AM
Edgar Perez
Score: 100
Status: offline
12FG using PPM with Weatronic for many years. 12 channels and no issues.
Edgar Perez
Puerto Rico
Hide Signatures
(in reply to RUFTER)
       Post #: 31
RE: Weatronics - 11/12/2012 1:26 AM
ddennison
Score: 103
Status: offline
one more question if anyone can help?
I have several 12-22 gyro III gps 2.4 receivers running. I am looking to get another one but I usually run them on LiMn 7.4 V. The LiMN is going away and one option is a LiFePo 9.9V (3 cell).
1.Can I run the 12-22 on the 3 cell LiFePo? 6.6V is too low on 2 cells I believe to run the system.
2. Does the HV version only deal with the servo voltage (6 or 7.4) or the supply voltage for the receiver?
I would like to get going with my order and would like to make that the 12-22 (non-HV) option can run with LiFePo at 9.9 volts?
Dave
Hide Signatures
(in reply to Edgar Perez)
       Post #: 32
RE: Weatronics - 11/12/2012 9:29 AM
HarryC
Score: 100
Status: offline
Dave, the manual actually states you must use 3S if using life batteries with the 12-22 non-HV. The rx operating voltage is up to 10V.
Hide Signatures
(in reply to ddennison)
       Post #: 33
RE: Weatronics - 11/12/2012 6:17 PM
RSO
Score: 100
Status: online
I think you know we're running 3-cell A123 on ours. Just be sure your Jetcat ECU is upgraded for them.
Jerry
Hide Signatures
       Post #: 34
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.438RCU1
