RE: Hostetler Cessna 150/152    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Rcexl Opto Gas Engine Kill Switch ***FREE SHIPPING***
Seller:  swgiantscalemodels
Details:   $13.29   |  5/5/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> RE: Hostetler Cessna 150/152
Page: <<   < prev  1 2 3 4 [5] 6 7 8 9 10   next >   >>
Login
RE: Hostetler Cessna 150/152 - 11/25/2012 9:42 PM
smithfj
Last Login: 5/18/2013
Status: offline
I see where there hasn't been to many posts lately and I'm hoping someone can answer a question on the fuselage build. I recieved my plans last Friday and since then I have been cutting metal patterns for all the ribs. I was a tin knocker for 21 year sin the Air Force and another 20 in a shop one town up from me. So using light gauge aluminum flashing stock is a great way to make patterns for things like ribs.
I guess I got off track. My question concerns FB. The fuselage side view plan has a note that basically says FB runs from F1 to F5,except door area, and is 1/4 inch thick. If I read that right it's telling me the sheeted sides of the interior will be 7/16 thick from the firewall to F5. If so that seems like over kill to me. Would like to know what you did. Other than that, I haven't run in to to many other problems yet. Of course changes are being made to accomadate newer hardware and electronics.
Thanks for your help.
Frank Smith
Hide Signatures
(in reply to 4570jackjack)
       Post #: 101
RE: Hostetler Cessna 150/152 - 11/26/2012 11:30 AM
sebo
Status: offline
Keep everything from the back of the trailing edge of the wing all the way through the tail as light as possible....I wish I would have.  Had to add weight to the front end.
Hide Signatures
(in reply to willig10)
       Post #: 102
RE: Hostetler Cessna 150/152 - 11/26/2012 4:17 PM
kitman09
Last Login: 5/17/2013
Status: offline
hi, just got one about 70% done, what engine are you guys running on these planes.
Hide Signatures
(in reply to sebo)
       Post #: 103
RE: Hostetler Cessna 150/152 - 11/26/2012 7:40 PM
smithfj
Status: offline
If I can keep the weight down I plan on using a DLE 55. It pulls my 1/4 scale PT-19 around nicely and it weighs 32 lbs. Got an email from Wendell Hostetler which answered my FB question I asked in the previous post.
Frank
Hide Signatures
(in reply to kitman09)
       Post #: 104
RE: Hostetler Cessna 150/152 - 11/26/2012 9:48 PM
sebo
Status: offline
Saito 300 Twin dual carb....
Hide Signatures
       Post #: 105
RE: Hostetler Cessna 150/152 - 12/4/2012 5:28 PM
kitman09
Status: offline
would a 53cc twin, at 5.5hp be enough for this plane. not looking for a power house as i will be flying scale with mild acrobactics.
Hide Signatures
(in reply to sebo)
       Post #: 106
RE: Hostetler Cessna 150/152 - 12/4/2012 6:36 PM
Pelle Gris
Status: offline
I fly a 37lb Hostetler Tri-Pacer powered by a G-62. Plenty of power, so your 50cc should power a similar size 150 nicely.
Takeoff is a tad above 50% throttle, and cruise a bit below.
_____________________________
Best Regards
Tinus Nielsen
Hide Signatures
       Post #: 107
RE: Hostetler Cessna 150/152 - 12/11/2012 3:05 PM
smithfj
Status: offline
I have been working on fuselage for a while and this is where I'm at. Yep, a Texas Tail dragger set-up but being built for tri gear and skis. Put all the hard points in for the water ski set up as I can get to them now. Will run 3/16th rods out of the fuselage for attachment of the ski struts. I used nose gear brackets for the rod to come through and out the sides. We'll see how it works someday.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to Pelle Gris)
       Post #: 108
RE: Hostetler Cessna 150/152 - 12/11/2012 10:43 PM
4570jackjack
Status: offline
That looks very good. I like the Texas Tail Dragger  set up.
Hide Signatures
(in reply to smithfj)
       Post #: 109
RE: Hostetler Cessna 150/152 - 12/11/2012 10:47 PM
4570jackjack
Status: offline
I have one on the building table. so far is seems like an easy build.
Hide Signatures
       Post #: 110
RE: Hostetler Cessna 150/152 - 12/11/2012 10:58 PM
sebo
Status: offline
I like the holes that you drilled in the box that holds the formers........wish I would have done that.
Hide Signatures
       Post #: 111
RE: Hostetler Cessna 150/152 - 12/11/2012 11:14 PM
smithfj
Status: offline
I took a piece of brass tubing 1/2 inch diameter and put a wooden dowel in the upper end to chuck in the drill press. Holes come out clean that way. I also drill two small hole on each side of the tubing about an inch up from the cutting edge to poke out the plugs. Works like a champ for small holes too.
Frank
Hide Signatures
(in reply to sebo)
       Post #: 112
RE: Hostetler Cessna 150/152 - 12/12/2012 1:08 AM
TLH101
Status: offline
I am getting ready to start a build of these 150s. I have been planning to build this model for at least a dozen years and just this past weekend, I purchased a kit with the glass parts and main gear. It's an old Custom Cutters kit. I will be going electric with mine, so I will be looking for a lot weight savings. From what I have seen over the years, there is lot a places to drop a few grams on this airframe, so should be doable.
I need to finish my 1/4 scale SpaceWalker first, but it's about ready to paint.
< Message edited by TLH101 -- 12/16/2012 6:15 PM >
Terry
"Old Fart" in training. (not to be an R/Cer, but to be an "Old Fart")
Hide Signatures
       Post #: 113
RE: Hostetler Cessna 150/152 - 12/15/2012 11:24 PM
smithfj
Status: offline
Right now I'm debating wether I want to use 1/8 balsa for all the sheeting or drop down to 3/32 balsa. I plan to use shear webbing on the fore and aft wiing spars so I'm sure I could use 3/32 there. I would use 1/8 on the fuselage to former 5 and drop down to 3/32 aft of that. One reason being that 3/32 is cheaper than 1/8. Just a thought for now as I still have the wings to frame up.
Frank
Hide Signatures
(in reply to TLH101)
       Post #: 114
RE: Hostetler Cessna 150/152 - 12/15/2012 11:42 PM
Edwin
Status: offline
I made the mistake years back of using too thin for sheeting and sanded too much. My finger punched through the sheeting in about 5 different places. Just something to think about.
Edwin
Hide Signatures
       Post #: 115
RE: Hostetler Cessna 150/152 - 12/16/2012 12:10 PM
TomCrump
Status: offline
quote:
ORIGINAL: smithfj
Frank
On my Hostetler 195 fuselage, I used 1/8 sheeting, from the firewall to the rear of the cabin area. I then switched to 3/32, as it went around the "corners" easier, when I sheeted the rear fuselage.
On the wings, I stayed with 1/8.
Tom C
Hide Signatures
       Post #: 116
RE: Hostetler Cessna 150/152 - 12/16/2012 6:18 PM
TLH101
Status: offline
Well, after lots of study and contemplation, I just don't think this will be a good candidate for electric. At least, not without some major engineering, to shed weight, without losing any strength. So if anyone is interested, let me know and maybe we can put a deal together.
Terry
Hide Signatures
(in reply to TomCrump)
       Post #: 117
RE: Hostetler Cessna 150/152 - 12/16/2012 7:09 PM
smithfj
Status: offline
Tom,
I like your idea. I strapped taped the front end of the fuselage and it's a tad over 36 inches around it. I do think I'll stick with the 1/8 on the wing and be safe about that. If I can figure a way to stagger my splices aft of the cabin area I'll use 3/32 in the aft section. I do like the 1/8 up front as it help dampen some engine vibrations.
Frank
Hide Signatures
       Post #: 118
RE: Hostetler Cessna 150/152 - 12/17/2012 9:20 AM
TomCrump
Status: offline
Frank, I didn't stagger my joints, but I gave extra "purchase" area for the sheeting to glue down to. I then gradually tapeed my 1/8 down to 3/32.
Tom C
Hide Signatures
       Post #: 119
RE: Hostetler Cessna 150/152 - 12/17/2012 1:41 PM
smithfj
Status: offline
Sound like a good plan to me Tom. I may just do that. Starting on the wing today. Need those to align stab and finish up the center fuselage area.
Frank
Hide Signatures
       Post #: 120
RE: Hostetler Cessna 150/152 - 12/27/2012 9:12 AM
slevin1
Last Login: 5/9/2013
Status: offline
Could you please post some pics of you cutting out the wood on the fuse for the doors. Thanks.
Saul
Hide Signatures
       Post #: 121
RE: Hostetler Cessna 150/152 - 1/1/2013 2:20 PM
smithfj
Status: offline
Saul, Sorry for not posting sooner. I really haven't sheeted my doors yet and I didn't take to many pictures. The one obove just shows the opening and it's really not finished either. I did make the door frames to match the opening and shimmend around it with 1/32 ply spacers to get the clearance for opening and closing. If the doors are built to fit the framing (before sheeting the fuselage) then your 1/8 door sheets should match. That's my thinking any way. I plan on cutting the window openings after the doors are sheeted and gluing in the glazings.
All you fellow model builders and fliers have agreat New Year.
Frank
Hide Signatures
(in reply to slevin1)
       Post #: 122
RE: Hostetler Cessna 150/152 - 1/1/2013 3:58 PM
slevin1
Status: offline
Thank you.
Saul
Hide Signatures
       Post #: 123
RE: Hostetler Cessna 150/152 - 1/2/2013 12:03 PM
TomCrump
Status: offline
quote:
ORIGINAL: smithfj
Frank
That's pretty much how i make my doors ans openings. It's worked for me so far.
These are pics of my 1/4 Cessna 165.
Click for fullsize
Click for fullsize
Tom C
Hide Signatures
       Post #: 124
RE: Hostetler Cessna 150/152 - 1/2/2013 2:37 PM
smithfj
Status: offline
Tom's idea is what I'm shooting for. If you look at the picture of the fuselage above you can see the door frame sitting in the opening. I haven't finished the frame though. Got one wing sheeted and rough sanded and haven't fitted the aileron or flap yet. I want to get the other wing panel to this point so I can do my fuselage center section, mount the stab and fin before I start sheeting. Want to run my aft contol linkages before sheeting while it's easier to get on the fuselage for bracing. It's a big bird but I think I'll like it when done. As long as it doesn't weight 32 lbs. like the PT-19 did.
Frank
Hide Signatures
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.703RCU1
