RE: CARF-Models P-47 Thunderbolt    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Scale Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  5/1/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: CARF-Models P-47 Thunderbolt
Page: <<   < prev  13 14 15 16 17 18 19 20 [21] 22   next >   >>
Login
RE: CARF-Models P-47 Thunderbolt - 9/4/2012 11:21 PM
Joe C
Score: 100
Last Login: 5/20/2013
Status: offline
Very nice!!!
_____________________________
BEST IN THE WEST JET RALLY
www.bestinthewestjetrally.com Oct. 16th-20th, 2013
Hide Signatures
(in reply to Carbon-Customs)
       Post #: 501
RE: CARF-Models P-47 Thunderbolt - 9/4/2012 11:37 PM
jzuniga
Score: 105
Last Login: 5/21/2013
Status: offline
Beautiful Kasper!
Z
Hide Signatures
       Post #: 502
RE: CARF-Models P-47 Thunderbolt - 10/7/2012 7:57 PM
baron rojo
Score: 100
Last Login: 2/24/2013
Status: offline
hi, anyone can help me.
I tryed my P47 whith carf propeller,manual show pitch must be 14", but i tryed it and moki 250cc was a failure, it was stop by ignition system protection, because it was very hot.
I have a friend who tryed at the same weekend and happened the same.
anybody use a 2 blade propeller? if yes , is it 32x16?
Maybe carf manual is wrong ? it must be less pitch ? for example 30x11?
THANKS IN ADVANCE
Hide Signatures
(in reply to jzuniga)
       Post #: 503
RE: CARF-Models P-47 Thunderbolt - 10/7/2012 8:35 PM
TJPro351
Score: 100
Last Login: 5/14/2013
Status: offline
I set my solo 4 blade prop to 11 "units" on the hub.
Hide Signatures
(in reply to baron rojo)
       Post #: 504
RE: CARF-Models P-47 Thunderbolt - 10/7/2012 8:56 PM
fifou313
Score: 100
Status: offline
I have finished My P47.
I have set the prop to 11 "units" on the prop so the result is 30*14 for the prop.
Here a short video of the first engine test with the 30*14 prop:
and some pics.
I have planned to make the first flight at the end of october.
The only question I have if the elevator compensation with the flaps. If some one can give me some advise I will be very happy.
Best regards.
Fifou
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to TJPro351)
       Post #: 505
RE: CARF-Models P-47 Thunderbolt - 10/7/2012 9:21 PM
baron rojo
Score: 100
Status: offline
Pls, pay atencion on my words, we tryed 2  diferent p47 and we meet the same , motor was stoped by ignition temperature sensor, about overload propeller charge, check carefull and try the motor more than 10 minuts running ground, we meet a sad failure.
Hide Signatures
(in reply to fifou313)
       Post #: 506
RE: CARF-Models P-47 Thunderbolt - 10/7/2012 9:57 PM
affas
Score: 105
Status: offline
10min ground run with bad airflow and cooling will stop any Moki...
Best regards
Alf Hansen
Hide Signatures
       Post #: 507
RE: CARF-Models P-47 Thunderbolt - 10/7/2012 10:13 PM
baron rojo
Score: 100
Status: offline
How you know that it has got bad cooling and bad airflow? Moki only work on the air? After my friend and me meet the motor failure , we tryed whithout cow, and happened the same , i calculate the propeller load rate and 30x14 is  25% more than moki manual say. My question is anybody is flying whith carf  4 blades whith 14 pitch ? I am not asking if anybody will try 30x14, thanks
Hide Signatures
(in reply to affas)
       Post #: 508
RE: CARF-Models P-47 Thunderbolt - 10/9/2012 8:08 AM
fifou313
Score: 100
Status: offline
Does anyone have advice for my question about mixing elevator /flaps?
Thanks a lot for your answer.
Best regards.
Hide Signatures
       Post #: 509
RE: CARF-Models P-47 Thunderbolt - 10/9/2012 8:38 PM
baron rojo
Score: 100
Status: offline
seems that few people have flown it,  mix for elevator is = 0%, you dont need , i tryed 3 times before kill motor,
Hide Signatures
       Post #: 510
RE: CARF-Models P-47 Thunderbolt - 10/10/2012 2:41 PM
glazier808
Score: 291
Status: offline
Baron,
Try this thread
http://www.rcuniverse.com/forum/m_8946260/mpage_1/key_/tm.htm
Casey
Fliteskin, Sierra, Nelson Hobby, MICKO aircraft, Getstencils, Holman Plans, VicRC, Castle Creations, Addicted to Luft
Hide Signatures
       Post #: 511
RE: CARF-Models P-47 Thunderbolt - 10/25/2012 11:46 AM
DENTO
Score: 100
Status: offline
Hi guys
Can someone give me some advice on gear,I have jettronic valves on my gear every time I turn the trans on the gear try's to cycle into neutral ,I have to switch up and down a couple of times to get the gear in sink any advice would be good
Regards
John
Hide Signatures
(in reply to glazier808)
       Post #: 512
RE: CARF-Models P-47 Thunderbolt - 10/25/2012 2:10 PM
Prekin
Score: 101
Status: offline
Fifou, your Thunderbolt looks very nice. I think, that you chose good painting.
Do you have some more pictures and 3 view colour drawing?
Hide Signatures
       Post #: 513
RE: CARF-Models P-47 Thunderbolt - 10/25/2012 9:38 PM
fifou313
Score: 100
Status: offline
Hello Prekin.
Thanks you for your message.
I have found pics on internet for the scheme here : P-47
I have used only this pics to make the paint.
After I have made all the nomenclature of the plane and the marking with my plotter.
I can sell you all the rub on decals to paint all the nomenclature on the plane if you want it.
About the cockpit on pictures I have used the balsa dynamic kit.
If you are interested by the nomenclature or by the rub on decal to make the ameican star or the front bird contact me.
Best regards.
Philippe
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Prekin)
       Post #: 514
RE: CARF-Models P-47 Thunderbolt - 10/25/2012 9:58 PM
Prekin
Score: 101
Status: offline
Thank you very much for the link, Philippe.
I´m not building P-47 now, but I still think about it. If I build it, it will be 2m wingspan.
Is it problem for the decals? I think that your one is bigger.
Thank you for your offer.
Hide Signatures
       Post #: 515
RE: CARF-Models P-47 Thunderbolt - 10/25/2012 10:43 PM
SJN
Score: 105
Status: offline
The P-47 Kasper assembled, had its maiden a few days ago:
http://www.youtube.com/watch?v=SOmbMGgR4C8&feature=youtu.be
Click for fullsize
Sonnich Johannesen
Hide Signatures
       Post #: 516
RE: CARF-Models P-47 Thunderbolt - 11/22/2012 10:00 PM
wojtek
Score: 110
Status: offline
Philippe ,
the Dynamic Balsa cockpit looks very nice ! I have this and will use several parts from it , .. I opted for most of the parts from www.iflytailies.com/ for my P-47 though . Between the two, i think I will have most of the scale stuff crammed in there ...
I really am getting anxious to finish the P-47. This project has been on my work bench since last year. But with a new baby at home and with the huricane coming through a few weeks ago its been slow. Heres some shorts of my cockpit dash panel so far I figured I'd share here. I have been keeping the rest of my build under the Metalmorphing P-47 thread .
~V~
Nothing can ever be fast (or scale ;) ) enough !!!
www.all-scale.com
Hide Signatures
(in reply to SJN)
       Post #: 517
RE: CARF-Models P-47 Thunderbolt - 12/3/2012 4:55 PM
affas
Score: 105
Status: offline
Hi,
Starting my CARF P47 build now.
Are there any modifications that I have to complete or are the manual good to go??
Best regards
Alf Hansen
Hide Signatures
(in reply to wojtek)
       Post #: 518
RE: CARF-Models P-47 Thunderbolt - 12/6/2012 4:18 AM
wojtek
Score: 110
Status: offline
Not really. The manual is very well written. On my kid i did not have to shave/cut/angle the main gear support blocks. The gear fit and lined up perfectly and I juts needed to drill the mounting holes.
The canopy mounting method is the only thing I'd recommend deviating on , but that's to make it a sliding canopy ..
Im surprised more people are not building there :\
~V~
www.all-scale.com
Hide Signatures
(in reply to affas)
       Post #: 519
RE: CARF-Models P-47 Thunderbolt - 12/6/2012 4:26 AM
ram3500-RCU
Score: 145
Status: offline
That instrument panel is very nice. Very fitting for such a nice airplane.
Cheers,
Gary P. / use Steel Powder for ballast not lead. PM me for more information.
Hide Signatures
       Post #: 520
RE: CARF-Models P-47 Thunderbolt - 12/6/2012 4:28 AM
wojtek
Score: 110
Status: offline
Thanks Gary,
I have a few more pics of the cockpit coming along in the Metalmorphing thread
http://www.rcuniverse.com/forum/m_11000532/mpage_5/key_/tm.htm
~V~
www.all-scale.com
Hide Signatures
(in reply to ram3500-RCU)
       Post #: 521
RE: CARF-Models P-47 Thunderbolt - 12/6/2012 4:32 AM
ram3500-RCU
Score: 145
Status: offline
I checked it out. Good stuff. This will be another showpiece for sure.
Cheers,
Hide Signatures
       Post #: 522
RE: CARF-Models P-47 Thunderbolt - 1/6/2013 3:45 PM
P47Pilot
Score: 100
Last Login: 5/9/2013
Status: offline
There is some really superb work being exhbited here. Thanks guys for great inspiration. My own build is going way too slow, but at least I have it up on its feet now.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 523
RE: CARF-Models P-47 Thunderbolt - 4/25/2013 4:39 PM
wojtek
Score: 110
Status: offline
its taking longer than expected .. ( a new baby will do that ) but its close to maiden ... polishing out and some nomenclature ( over 300 pieces of it , lol ) still needed ...
Wojtek
www.all-scale.com
Hide Signatures
(in reply to P47Pilot)
       Post #: 524
RE: CARF-Models P-47 Thunderbolt - 4/25/2013 5:28 PM
uncljoe
Score: 160
Status: offline
Voy
  That's AWESOME craftsmanship !!!!!!!!!         whens the maiden ?
Semper Fi
 Joe
Look towards the Horizon......your death awaits you there
Hide Signatures
       Post #: 525
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.188RCU1
