XXL/PICCO question    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Losi Monster Trucks >> XXL/PICCO question
Page: [1]
Login
XXL/PICCO question - 3/4/2011 1:52 AM
dzchey21
Score: 100
Last Login: 12/25/2011
Status: offline
So i got my new picco and i went to install it, and the bottom of the block hits the chassis plate, i have seen where someone put washers under the motor mounts but i wasnt really fond of that, so my question is, what are my options, and does the dynomite engine mount raise the engine a little so this isnt a problem
_____________________________
Losi xxl. Picco .28
Hide Signatures
       Post #: 1
RE: XXL/PICCO question - 3/4/2011 3:40 AM
1QwkSport2.5r
Score: 155
Last Login: 5/21/2013
Status: online
quote:
ORIGINAL: dzchey21
IIRC, there is an engine mount floating around somewhere that did raise the engine enough to clear the chassis plate, but I cannot remember what it was. I would google search "picco LST2". You'll have better luck finding out. The LST2 and XXL use a lot of the same parts, and the LST2 has been around forever..
I think most people use washers even though it kinda goes against better judgment. Thats what I would do - using stainless washers and lots of locktite.
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
(in reply to dzchey21)
       Post #: 2
RE: XXL/PICCO question - 3/4/2011 4:04 AM
dzchey21
Score: 100
Status: offline
im worried about washers because im worried it will break the ears off the engine, which would suck
It is so close i have thought about grinding the bottom of the block, i mean its like within 1/16 of an inch or maybe even less.
if anything i might build a shim or new mounts.
Losi xxl. Picco .28
Hide Signatures
(in reply to 1QwkSport2.5r)
       Post #: 3
RE: XXL/PICCO question - 3/4/2011 12:06 PM
Mclovin350z
Score: 115
Last Login: 8/9/2012
Status: offline
If the head of the bolt is enough to hold it down then some washers will be enough to hold it up. I know it isn't the right way to do it, but it would work fine. The best thing to do is get a cheap piece of flat stock or sheet metal at lowes and make shims.
Losi xxl, Picco 26 t-maxx 4907, Sirio s27 revo, revo 2.5 with modded 18tm, EMBE, mostly stock 4908 maxx, pos mini lst2.
Hide Signatures
       Post #: 4
RE: XXL/PICCO question - 3/4/2011 1:36 PM
dzchey21
Score: 100
Status: offline
quote:
ORIGINAL: Mclovin350z
Im taking the engine and mounts to work today to see if there is something that i can make work, I would feel alot better if it had something all the way across the mount.
I understand what you are saying just seams like if its not spreading the load all the way across the mount there is a good chance for damage to the engine
Either way ill post up what i find today
Losi xxl. Picco .28
Hide Signatures
(in reply to Mclovin350z)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.359RCU1
