RE: HABU 32?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric RC Jets >> RE: HABU 32? Page: <<   < prev  7 8 9 10 11 [12] 13 14 15 16   next >   >>
Login
RE: HABU 32? - 7/13/2011 7:56 PM
lorhd2005
Last Login: 4/2/2013
Status: offline
anyone have the habu for sale,imlooking to buy one used,thanks
Hide Signatures
(in reply to Ted62)
       Post #: 276
RE: HABU 32? - 7/13/2011 10:01 PM
BalsaBob
Last Login: 5/16/2013
Status: offline
Thanks Ted, My LHS happen to have the beefier CC BEC in stock (the BEC Pro). Not much more money then the regular CC BEC ..... so I went with that. I have had good success with the single battery setup and these CC externel BEC's ...... so I am sort of affraid to change.
I just opened the box that had the batteries in it. These 6S 5000 mah packs are like a brick ! Is this thing going to fly ! ! ...... yikes ......
Bob
_____________________________
" This plan is way too ingenious to fail for the fourth time ..... "
Hide Signatures
(in reply to lorhd2005)
       Post #: 277
RE: HABU 32? - 7/14/2011 1:35 AM
Ted62
Last Login: 3/14/2013
Status: offline
quote:
ORIGINAL: BalsaBob
Bob
I had the same "yikes" pronouncement after I saw the 6s cell. Btw, some of the guys are simply putting 2 3s packs in series and are apparently saving some $$ that way. I went ahead and ordered the 6s cells (I bought an e-flight 6s and a Thunderpower 6s) before I even thought about it. Only money? Right? (gulp - I won't my wife read that!) Yes, the aircraft is a surprisingly great flyer, in fact, right before the threshold, I usually chop the power and letter float in - it has great low speed manners - many of my landings are of the 2-3 hop variety simply because I didn't bleed off enough speed before I touched her down. The plane is a dream to put together and you will have fun - use the grade of epoxy they recommend - 15-30 minute stuff is called for quite a bit. Have fun and send a picture or 2.
Hide Signatures
(in reply to BalsaBob)
       Post #: 278
RE: HABU 32? - 7/15/2011 2:04 AM
Ted62
Status: offline
Need a bit of help here. I have what I would call a really weird problem with my ESC/Motor/Receiver/ or sumthin!! I am using the E-flight 80 amp pro esc (not using the bec). When I connect the battery, I get a good cell count. However, when I power up the receiver, I no longer the 3 tones indicating the esc arms. I have checked the receiver, the ESC (it works if I substitute a servo programmer), and have subbed the wiring to the esc (there was a short servo extension in there from which I disconnected the orange wire). Seems I can make the esc operate normally if I use the servo testor, but, using a receiver, it no longer works (I subbed 2 receivers to be sure). Any thoughts - other than a bad ESC? The problem started about 2 nights ago, btw, when the esc didn't arm right away - took much longer than it normally does - usually just about instantaneous, but, was taking 10-15 seconds before it quit altogether. After describing this problem, I am leaning to guess a bad esc. LOL - any thought?? If it's the esc, why does a servo positioner work? Different pulse height?
Hide Signatures
(in reply to Ted62)
       Post #: 279
RE: HABU 32? - 7/15/2011 2:32 PM
Ted62
Status: offline
quote:
ORIGINAL: Ted62
Found the culprit! I had somehow bumped the throttle trim on my 9503 so the receiver pulse to the esc was out of the 1.2-1.8 ms "window". I simply lowered the trim lever (the throttle trim on the 9503 is mechanical) to the middle position, and, it works!!! Something to watch out for in the future.
Hide Signatures
(in reply to Ted62)
       Post #: 280
RE: HABU 32? - 7/15/2011 5:37 PM
v8mini
Last Login: 5/18/2013
Status: offline
quote:
ORIGINAL: Ted62
i think this might be where you have gone wrong, you have disconnected the orange signal wire, you need to disconnect the middle red wire when not using the ESC BEC
Hide Signatures
(in reply to Ted62)
       Post #: 281
RE: HABU 32? - 7/15/2011 9:01 PM
Ted62
Status: offline
I meant the signal wire, not the 5 volt wire - but thanks for your response.
Hide Signatures
(in reply to v8mini)
       Post #: 282
RE: HABU 32? - 7/15/2011 9:40 PM
aeroscale
Last Login: 5/8/2013
Status: offline
I've now got about 32 flights on mine and it really does fly well. Once you get the landing speed sorted out, it is a fun airplane. Mine is 100% stock including the ESC and 6S pack. It slows down nicely with full flaps. Gear wire is a bit soft, typical of metal products coming from that part of the world!
AEROSCALE
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Ted62)
       Post #: 283
RE: HABU 32? - 7/15/2011 9:41 PM
aeroscale
Status: offline
Sorry, brain fade. I realize you only needed one of them!
Hide Signatures
(in reply to aeroscale)
       Post #: 284
RE: HABU 32? - 7/16/2011 12:54 AM
Ted62
Status: offline
quote:
ORIGINAL: aeroscale
Real nice touch with the cockpit detail and tail-cone - great picture!
Hide Signatures
       Post #: 285
RE: HABU 32? - 7/16/2011 2:02 AM
aeroscale
Status: offline
Thanks; exhaust nozzle done with chrome trim MonoKote, cockpit with some scraps of sheet styrene to create seat back plus an LED for dress up.
AEROSCALE
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Ted62)
       Post #: 286
RE: HABU 32? - 7/16/2011 2:17 AM
Ted62
Status: offline
quote:
ORIGINAL: aeroscale
AEROSCALE
Neat! If the plastic thrust tube protruding from the tail cone bothers you, use a Dremel to grind it off - most of us here did that with no ill-effects.
Hide Signatures
       Post #: 287
RE: HABU 32? - 7/18/2011 2:51 AM
Dieselman1220
Status: offline
Ugh I keep seeing vids of people flying there Habus and mine is just collecting dust. Gary any idea how much longer those mega 1.5 secs will be on back order? Im almost tempted to buy another BL32 motor
just to fly mine again. but after flying on 8s 6s just puts me to sleep
Joseph K
Hide Signatures
(in reply to Ted62)
       Post #: 288
RE: HABU 32? - 7/18/2011 4:22 AM
efflux RC
Status: offline
quote:
ORIGINAL: Dieselman1220
just to fly mine again. [&o] but after flying on 8s 6s just puts me to sleep
They are out of US customs and on thier way. see tracking below. Just a  day or 2 now..
Detailed Results:
Bullet Processed through Sort Facility, July 15, 2011, 1:05 pm, BETHPAGE, NY 11714
Bullet Inbound Out of Customs, July 13, 2011, 9:18 pm
Test results are now released for our new ALL ALLOY 90mm EDF.    Please check it out.
http://www.rcuniverse.com/forum/m_10626142/tm.htm
Thank. Gary
www.effluxrc.com
effluxrc@gmail.com
< Message edited by efflux RC -- 7/18/2011 4:52 AM >
efflux RC - quality driven power
Hide Signatures
(in reply to Dieselman1220)
       Post #: 289
RE: HABU 32? - 7/19/2011 3:01 AM
BalsaBob
Status: offline
Maidened mine this weekend and put 4 flights on it. I am still amazed on how an airplane that is this heavy (for its size) flies so well. I let people pick it up ...... and enjoy their reactions when they see how heavy it is. The folks at E-Flite really did a fantastic job on this planes design. (I still can't believe how heavy it is ........). Bob
Hide Signatures
(in reply to efflux RC)
       Post #: 290
RE: HABU 32? - 7/19/2011 4:35 AM
Ted62
Status: offline
quote:
ORIGINAL: BalsaBob
Yes - landings can be a handful at our field - not the best surface (grass and mainly dirt) - so, I usually get a few bounces. In fact, I am replacing the springs on my TamJet's struts already. The corn around here is getting too high to make the best approach .
Hide Signatures
       Post #: 291
RE: HABU 32? - 7/19/2011 2:33 PM
jesses151
Last Login: 5/14/2013
Status: offline
Hey,
Can anyone tell me what diameter they are using on the exhaust of the thrust tube? And has anyone experimented with different diameters?
-Jesse
Hide Signatures
(in reply to edgeflyer)
       Post #: 292
RE: HABU 32? - 7/21/2011 4:29 AM
Dieselman1220
Status: offline
Hey Gary I see that you show the mega motors in stock now. Will you actually have a few left over? I'm thinking about getting a second one for another project?
Joseph K
Hide Signatures
(in reply to jesses151)
       Post #: 293
RE: HABU 32? - 7/21/2011 6:37 AM
efflux RC
Status: offline
Yes. We have a few 6s and 8s MEGA motors for the Habu 32 in stock.
Please see your email
Thank Gary
Hide Signatures
       Post #: 294
RE: HABU 32? - 7/24/2011 5:48 PM
bigbaggy
Last Login: 2/11/2013
Status: offline
Anyone used the EFlite 15-25 elecrtric retracts on the Habu 32? They are the same size frames just bigger wire struts 3.5 mm vs 3.0 mm
Paul Bageman
Team JR, BVM/Skymaster ,evoJet Booster
Hide Signatures
       Post #: 295
RE: HABU 32? - 7/24/2011 8:34 PM
efflux RC
Status: offline
quote:
ORIGINAL: bigbaggy
The 15-25 E-Flites are what is spec'd for the jet, and everyone is using. Yes the wire on those is 3.5mm. the (mains) wire will bend with nearly every landing, and must be bent back for the wheel to retract into the well. After enough of this bending the plastic trunion wil crack.
We carry the Tam's struts. They are sprung, trailing link struts, and will alleviate this problem. The spring on the Tams struts, will take a set after a few landings. So it them becomes loose, also deterring the gear from completely closing. Tam sells a upgrade kit for his struts with new (different) springs now.
The 25-46 retracts have bigger wire, and come with metal trunions. but they are a bit too thick for the wing. and will protrude from the bottom of the wing. We have not tried actually install them yet.
Hide Signatures
(in reply to bigbaggy)
       Post #: 296
RE: HABU 32? - 7/25/2011 1:22 AM
bigbaggy
Status: offline
Gary
Ah I miss read the manual and have been using the 10-15s gear. Doooooh!
They work on hard surface if you are really nice to them...
Thanks for the tune up.
Paul Bageman
Hide Signatures
       Post #: 297
RE: HABU 32? - 8/5/2011 8:58 AM
mauryr
Status: offline
On another forum, a member claims one of his wing spars just snapped at the wing root during a lift off. I don't doubt he destroyed his airplane because the wing spar broke, but I do not understand how it could possibly happen. These spars are very strong for vertical loads and I never expect them to break off just like that.
Has anyone else had this happen to them? I am trying to figure out if there were any pre-existing problems which may have caused it. He did not have the wings glued in for ease of transportation (neither do I, and my spars are still pristine after over 30 flights).
Thanks.
Hide Signatures
       Post #: 298
RE: HABU 32? - 8/5/2011 3:55 PM
Ted62
Status: offline
That's the first I've heard of this! I wonder if the owner hadn't drilled the spars to accommodate the #10 hex head screws in order to prevent the wing from levering away from the fuselage with each landing? I was tempted to do the same thing, but, ended up using RTV to bond the wing to the fuselage since I could transport the plane fully assembled anyway. If I ever need to remove either or both wings, a #11 Xacto blade should release the wing. I certainly haven't been bothered with either wing having a gap since I did that (thanks, Gary).
Hide Signatures
(in reply to mauryr)
       Post #: 299
RE: HABU 32? - 8/5/2011 5:56 PM
mauryr
Status: offline
I don't know if the owner drilled the spars, but I don't think so. It would be of little consequence, anyways, because he said the spar snapped clean off the fuselage as if cut with a knife.
I honestly can't believe there was no pre-existant condition (hard landing, broken anti-rotation dowel, something else). The spars look just too solid to break away like that.
Of course glue is the answer but, in my case, I want to carry the habu in the trunk of my car along with at least one big plane (jet or propeller driven) and it just won't fit with the wings on, so if that's the only solution mine is going on sale soon...
quote:
ORIGINAL: Ted62
Hide Signatures
(in reply to Ted62)
       Post #: 300
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.980RCU1
