Fubar-One
Joined: 3/1/2003 From: Canyon Country, CA, USA Status: offline
[QUOTE]Originally posted by snuff I just got the skylinker 800mw 1.2Ghz high Frequency color camera. I have only installed it in the plane, but from what i see on the ground it’s an awesome color camera. Low light situations suck, but great for outside. I will be test flying it (to find a plane I lost) this week if the weather clears up. I will try to record the flights but I don’t know if I can score a digital camcorder. But I will post results this week. Now for my $.02 worth no the legality of 1.2 ghz and the fines. Do ya really think that the FCC will fine somebody $10,000, that thought it would be cool to install a little wireless camera and video record his flight? I don’t think so! The key words are fine up to $10,000. That means you can get a "no no” and a tap on the wrist, or the max $10,000. Its most likely if you do get caught, "they" might take "whatever" equipment and tell you to tell all of your friends that 1.2 ghz is a restricted band and ARE NOT to transmit on it, Then again I could be wrong. . My rule would be: around airports and other obvious places 1.2 is a no no, out in the middle of a cornfield w/ nothing around for 80+ miles...so so. I'm going to take that chance! pirate: [/QUOTE] A digital camcorder isnt needed. An analog such as Hi-8, 8, or even VHS-C (ugh!) is doable so long as it has an analog AV input. My videos were recorded using both digital 8 and Hi-8 and the only real difference I have seen is a little line at the top or bottom of the screen for the Hi-8 and I think that is only visible during editing. Any video on my site that shows the date on the screen was shot by my father's Hi-8. We routinely dub what we each shot back and forth between camcorders at the end of a flying session. It has also been my experience, with whatever frequency a wireless video system is operating on, that if you mount the rx up on a pole or mast, the higher the better, the signal reception improves quite a bit.
_____________________________
"B Positive to ground, over..."
