Swinging Corona
Tower Hobbies
Logged in as Guest
  Printable Version
Walkera 53#8!! 5G6-1, 4#3B and Nine Eagles - RTF
Seller:  travis@rchelizone.com
Details:   $170.00   |  10/8/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> Electric RC Helis >> Swinging Corona
Page: [1]
Login
Swinging Corona - 8/9/2003 10:22:20 PM
hoverhead
Status: offline
I am About to go Crazy! My Corona W/Gws Pg-03 will not stop swinging,I have tried adjusting Gyro and come up with nothing,Gain all the way up leaves the tail wagging anything under full gain back in full swing! this even with full pitch both directions.
Help
Thanks Brian
       Post #: 1
Swinging Corona - 8/10/2003 2:26:15 AM
hoverhead
Status: offline
I just noticed I have No tail rotor control during power up! If I let her wind down to low power I gain back control???
Brian
(in reply to hoverhead)
       Post #: 2
Swinging Corona - 8/10/2003 3:34:56 AM
KnimRod
Status: offline
A simple test would be to hold the MR and try to turn the TR back and forth with your other hand (not too hard!). They should be locked together. If they're not locked, make sure the TR shaft front pinion set screws on tight on the TR shaft. If the screws are loose, take them out, clean them and then reinstall them using loctite. Also check the set screws on the crown gear. If everything is tight up front, the TR rear pinion may have failed, in which case you would need a new shaft. You should be able to trace the source of the problem without too much difficulty.
Good luck!
       Post #: 3
Swinging Corona - 8/10/2003 6:04:45 AM
hoverhead
Status: offline
For the reply! Everything seems to be in order as far as MR - Tr rotation,problem seems to be in the control! as throttle is decreased to slow I gain control of tail rotor servo, as I speed up I completely loose control of tail rotor servo.have checked have checked transmitter Jr-Xp642 for rev mixing and everything looks good there.have reset Gyro gain and setup.I am thinking Gyro is bad???
Thanks Brian
       Post #: 4
Swinging Corona - 8/11/2003 10:06:51 PM
SoaringEagle
Status: offline
Do the TR and gyro work with the motor off? You should be able to manually move the tail boom left and right and see the gyro try to adjust in the opposite direction. Plus you should be able to control the TR with your transmitter.
If that all works, maybe you should look at the routing of your wiring. Does the TR servo or gyro wiring run near the ESC wiring or the motor? Could be a noise problem??
Randy
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.453RCU1
