Simjet 2250... Lipo ?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AMT Netherlands Pegasus HP - RTF
Seller:  thunderbolt-RCU
Details:   $3,000.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Turbine Clinic >> SimJet Turbine Direct Support >> Simjet 2250... Lipo ?
Page: [1]
Login
Simjet 2250... Lipo ? - 3/15/2011 8:48 PM
Aviator-No
Score: 100
Last Login: 2/24/2013
Status: offline
Hi,
Can I run a 3 cell lipo on my old 2250 ?
I have the gold colored ECU, and running on a 8 cell ncad at the moment.
Brgds
Svein-Roe
Hide Signatures
       Post #: 1
RE: Simjet 2250... Lipo ? - 3/16/2011 10:02 AM
Uefly
Score: 100
Last Login: 5/12/2013
Status: offline
Hi!
If this ECU is an old original 2002 SimJet Fadec, you can run it on a 3 cells LipPo. The solenoidvalves that belongs to this ECU handle 12 volts. But if you have a Gaspar ECU, you better run it on 2 cells LiPo. I have one SimJet 3000 that I run on a SimJet 2002 Fadec, and when I went from 8 cells NiCad to 3 cells LiPo all my starts have been perfect. I use a 2600 mah LiPo with 30C because it is vital that your battery can deliver a solid punch to the startprosedure, and this works perfect .
_____________________________
" In thrust I belive "
Hide Signatures
(in reply to Aviator-No)
       Post #: 2
RE: Simjet 2250... Lipo ? - 3/16/2011 12:40 PM
Aviator-No
Score: 100
Status: offline
Hi Uefly,
The turbine I have is an old one, original with air start that I monted a manual elstarter on.
There is no solenoids valves, only a manual 3 way valve that i flipp over after preheating on gas.
So the ECU is only controling the glowplug and pump
Brgds
Svein-Roe
Hide Signatures
(in reply to Uefly)
       Post #: 3
RE: Simjet 2250... Lipo ? - 3/16/2011 1:21 PM
Uefly
Score: 100
Status: offline
How old is this ECU, and what is called?
Hide Signatures
       Post #: 4
RE: Simjet 2250... Lipo ? - 3/16/2011 1:22 PM
Aviator-No
Score: 100
Status: offline
Here is a picture of the ECU cover...
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 5
RE: Simjet 2250... Lipo ? - 3/16/2011 1:35 PM
Uefly
Score: 100
Status: offline
You can run a 3 cell lipo on your ECU, but I would prefer a 3 cell LiFe, 9,9 volt. LiFe handle cold temperature much better than LiPo. You can buy batteries from Hobby King to a ridiculous low price.
Hide Signatures
       Post #: 6
RE: Simjet 2250... Lipo ? - 3/16/2011 1:50 PM
Aviator-No
Score: 100
Status: offline
Thanks Uefly,
Do you recognize the cover...? whats the name of the ECU?
Brgds
Svein-Roe
Hide Signatures
(in reply to Uefly)
       Post #: 7
RE: Simjet 2250... Lipo ? - 3/16/2011 2:28 PM
Uefly
Score: 100
Status: offline
I can see that the by the cover that this ECU is an original old SimJet ECU, and all old ECU`s from SimJet can be run by 3 cells LiPo. Dont know the exact version of it, but it looks familiar with one I have been seen before
Hide Signatures
       Post #: 8
RE: Simjet 2250... Lipo ? - 3/17/2011 3:39 PM
basimpsn
Score: 120
Last Login: 5/22/2013
Status: offline
Guys I have the same engine w electric start in good condition, ECU, fuel pump and Solenoid valves. For sale
It''''''''''''''''''''''''''''''''s a hobby - keep it simple
Hide Signatures
(in reply to Uefly)
       Post #: 9
RE: Simjet 2250... Lipo ? - 3/18/2011 1:53 PM
Vampire
Score: 100
Status: offline
Hello Svein-Roe,
Yes, this is not a problem on an ECU that used an 8 cell Nicad. Thsi would be your SJ-2002-D2 and older ECUs.
This could not be done on the new GASPAR - 605 series however, this must remain a 7.4v 2S Lipo due to the starter Voltage that Simjet uses wouod over amp the ECU.
Best Regards,
Kerry J. Sterner
scaledesigner@verizon.net
Hide Signatures
       Post #: 10
RE: Simjet 2250... Lipo ? - 3/22/2011 7:02 PM
Aviator-No
Score: 100
Status: offline
Today I ran the turbine several times on my 3 cell lipo.... After every start I had to change glow plug...:-(
Any solutions...? Connect a lighbulb or a resistor to lower the voltage?
The good thing is that it felt like it was spooling up much faster... ? the responce was faster. Could this be correct?
Hide Signatures
(in reply to Vampire)
       Post #: 11
RE: Simjet 2250... Lipo ? - 3/23/2011 8:24 AM
Uefly
Score: 100
Status: offline
On my SimJet 2002 ecu, I can adjust the glowpower with my SimJet dataterminal. I can choose from low, medium and high glowsetting. I have medium on mine ecu running on 3 cells LiPo. I dont know if you can plug a terminal into your ecu??
You can always choose to run it on 3 cells LiFe package (9,9 volts)
Hide Signatures
       Post #: 12
RE: Simjet 2250... Lipo ? - 3/23/2011 11:19 AM
Aviator-No
Score: 100
Status: offline
There is no way to connect a terminal to my ECU...
I have ordered a Life pack for it
Svein-Roe
Hide Signatures
(in reply to Uefly)
       Post #: 13
RE: Simjet 2250... Lipo ? - 3/23/2011 2:15 PM
basimpsn
Score: 120
Status: offline
quote:
ORIGINAL: Aviator-No
Go back to Nicad battery or use a bulb and a Glow igniter
Hide Signatures
       Post #: 14
RE: Simjet 2250... Lipo ? - 3/24/2011 4:16 PM
Vampire
Score: 100
Status: offline
You have limited options to deal withthis if you do no thave a Data Terminal in which you coulld adjust the Glow Plug output voltage
I use MC-9 plugs but any other "Cold Plug" would be suitable. A Cold plug = 2 volts vs. the 1.2volt
The only other option for you is to return to the 8Cell Nicad as when fully charged is apporx. 10+volts and the 11.1 3S Lipo is generally 12+ volts.
BTW, the subject Data terminals are no longer avaibale and the 2002 D2 ECU boards are going away as well being replaced by Xicoy 605 ECU.
Kerry J. Sterner
Hide Signatures
       Post #: 15
RE: Simjet 2250... Lipo ? - 3/29/2011 6:15 PM
Aviator-No
Score: 100
Status: offline
LiFe 3 cell was the way to go :-) Working perfect :-)
Brgds
Svein-Roe
Hide Signatures
       Post #: 16
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.391RCU1
