RE: Spektrum Telemetry module and iPhone App.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> JR Radio & Spektrum Radios >> RE: Spektrum Telemetry module and iPhone App.
Page: <<   < prev  38 39 [40] 41 42 43 44 45 46 47   next >   >>
Login
RE: Spektrum Telemetry module and iPhone App. - 1/19/2013 10:21 AM
Aerocal
Score: 105
Last Login: 5/24/2013
Status: offline
quote:
ORIGINAL: orthobird
hello
does anyone have any advice
i am using a jr transmitter x9503.
with the spektrum telemetry unit.
today was two flights with this system, and lots of interesting data.
max altitude was 1200 feet
max speed was 110 mph
cylinder head temp was 130 F, and high was 160 F.
rpm, was only thing did not show well.  it was reading in 400,000,000 digits?
does anyone know what is going on here?
what rpm sensor are you using?
Hide Signatures
(in reply to orthobird)
       Post #: 976
RE: Spektrum Telemetry module and iPhone App. - 1/19/2013 10:24 AM
Aerocal
Score: 105
Status: offline
quote:
ORIGINAL: orthobird
also, i emailed the flight log from my iphone to myself, and i cannot open it on my mac.
it is a tlf file.
anyone know how i can see this?
The .tlm file needs to be opened with the STi app.Im not aware that it will run on a mac.Try D/L the Spektrum STi app on your iPhone and open it with that.
Hide Signatures
       Post #: 977
RE: Spektrum Telemetry module and iPhone App. - 1/19/2013 12:37 PM
orthobird
Score: 105
Last Login: 5/25/2013
Status: offline
thank you
what should it be set at?
it is an airplane with a two blade prop.
quote:
ORIGINAL: czorzella
Orthobird - go back to your model's telemetry profile and make sure you configured the POLES and GEAR RATIO at the RPM Parameters. These parameters will convert your 9 digit raw data into proper readings.
quote:
ORIGINAL: orthobird
hello
_____________________________
avoid crashing!!
Hide Signatures
(in reply to czorzella)
       Post #: 978
RE: Spektrum Telemetry module and iPhone App. - 1/19/2013 3:52 PM
czorzella
Score: 100
Status: offline
quote:
ORIGINAL: Aerocal
I/C engines dont have poles.
Oops, my bad!
Hide Signatures
(in reply to Aerocal)
       Post #: 979
RE: Spektrum Telemetry module and iPhone App. - 1/19/2013 4:09 PM
BuschBarber
Score: 104
Status: offline
quote:
ORIGINAL: czorzella
quote:
ORIGINAL: Aerocal
Oops, my bad!
I will bet the if you go to Europe, Poles have I/C engines.
He He
Rich
byronf16@gmail.com
Hide Signatures
       Post #: 980
RE: Spektrum Telemetry module and iPhone App. - 1/19/2013 4:18 PM
orthobird
Score: 105
Status: offline
avoid crashing!!
Hide Signatures
(in reply to BuschBarber)
       Post #: 981
RE: Spektrum Telemetry module and iPhone App. - 1/19/2013 4:52 PM
Aerocal
Score: 105
Status: offline
quote:
ORIGINAL: orthobird
thank you
quote:
ORIGINAL: czorzella
quote:
ORIGINAL: orthobird
hello
I/C engines dont have poles(poles would be on an electric motor) so leave that at Inh.The ratio is 1:1.00 if you have direct drive.A ratio would be used for say a heli or a gear drive to get true head/prop speed.
You didnt say what you are using for a sensor.
Hide Signatures
       Post #: 982
RE: Spektrum Telemetry module and iPhone App. - 1/19/2013 4:55 PM
orthobird
Score: 105
Status: offline
ok
thank you
of course
i knew that
lol
 that is how it is set
i am using the sensor for cdi
avoid crashing!!
Hide Signatures
       Post #: 983
RE: Spektrum Telemetry module and iPhone App. - 1/19/2013 8:57 PM
Len Todd
Score: 100
Last Login: 5/23/2013
Status: offline
Orthobird:
What sensor are you using for a CDI source? I would like to figure out what I could use. I have a couple Optical sensors that I am about to start testing with. I have tried tapping into the CDI's Tach circuit. That does not work. I have also tried tapping into the Hall effect circuit w/o positive results. So waht are you using off the CDI?
33% Extra DLE 111, DX8
33% Extra for 3D, DX8
Hide Signatures
       Post #: 984
RE: Spektrum Telemetry module and iPhone App. - 1/20/2013 12:19 AM
JohnB96041
Score: 110
Status: online
quote:
ORIGINAL: Len Todd
Orthobird:
Here is my solution and it has worked great.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Len Todd)
       Post #: 985
RE: Spektrum Telemetry module and iPhone App. - 1/20/2013 7:08 AM
Aerocal
Score: 105
Status: offline
Thanks John and Len
I havent had the frustration of getting the rpm to work trying to use the signal from the cdi and Ive heard mixed results.IIRC Ive seen posts where some have had success but I dont remember the details.I think I would opt for the dedicated/isolated sensor if at all possible myself.
Hide Signatures
(in reply to JohnB96041)
       Post #: 986
RE: Spektrum Telemetry module and iPhone App. - 1/20/2013 2:22 PM
Franco2fly
Score: 114
Last Login: 5/21/2013
Status: offline
Guys,
Especially those with CDI set ups.  FORGET Hall effect and make life easy, plug and play.
Use the Optical seen here mounted on a balsa stalk that is then attached to the inside of the cowl:
Here I have it on a short lead, but you can easily get a 12" extension if so desired.
This one should be put to bed.
KKKKFL
Hide Signatures
       Post #: 987
RE: Spektrum Telemetry module and iPhone App. - 1/22/2013 12:23 PM
tarcure
Score: 100
Status: offline
While some apps on the iPhone do not back up their specific data the Spektrum app apparently does. I was able to restore my iPhone from my backup and the telemetry information was now available.
Hide Signatures
       Post #: 988
RE: Spektrum Telemetry module and iPhone App. - 1/22/2013 12:25 PM
Franco2fly
Score: 114
Status: offline
Hmmm...  where was the iPhone data backed up?  Do you do frequent "Sync's"?  I'm pretty negligent when it comes to doing syncs or backups.
KKKKFL
Hide Signatures
(in reply to tarcure)
       Post #: 989
RE: Spektrum Telemetry module and iPhone App. - 1/22/2013 12:30 PM
tarcure
Score: 100
Status: offline
Backups are found in iTunes on the computer the phone is synced to. Plug in iPhone, open iTunes, and look at your device. Can be backed up to iCloud or the computer itself. Very handy.
Hide Signatures
(in reply to Franco2fly)
       Post #: 990
RE: Spektrum Telemetry module and iPhone App. - 1/22/2013 9:58 PM
Aerocal
Score: 105
Status: offline
Yes I discovered the STi app does backup the files and settings to its Known state at the time of backup.Backups can definitely be a good thing in a time of need.Friggin computers.No matter how good the software,system or interface you never know when a backup is going to save your butt.
Hide Signatures
       Post #: 991
RE: Spektrum Telemetry module and iPhone App. - 1/24/2013 2:22 PM
orthobird
Score: 105
Status: offline
question for you all.
i have the spektrum TM 1000
and the following sensors:
1.  temp
2.  rpm
3.  ignition batt voltage
4.  receiver voltage
5.  gps
i do not have the altimeter or the airspeed
i use the iphone STI app, and
i noticed that when i flew my plane, i did not have any data for altitude or airspeed, when i looked at the 3 gauges on the screen, onluy RPM was on.
then i realized, the GPS module is on the other page, that shows a satellite picture of the airfield and it showed the speed and altitude.
my question is this:
can the GPS speed and alt. be displayed on the screen with the gauges?
avoid crashing!!
Hide Signatures
       Post #: 992
RE: Spektrum Telemetry module and iPhone App. - 1/24/2013 2:31 PM
Franco2fly
Score: 114
Status: offline
I don't believe the GPS altitude is all that accurate, and doubt you can get it to read out the way you want.  The whole GPS thing is only worthwhile in 'Replay' mode as far as I'm concerned(ie. "How far out did I swing on that last approach?" or did I really exceed our fields boundaries and fly over the neighboring community?).  I believe you would be far better served just adding the Airspeed sensor, and then using the audio output to have it going to your ear bone every 5 seconds.  Altitude is nice to have, but comes in as a second place to airspeed for me.
Just my 2 cents.
KKKKFL
Hide Signatures
       Post #: 993
RE: Spektrum Telemetry module and iPhone App. - 1/24/2013 3:09 PM
orthobird
Score: 105
Status: offline
it had read 1200 feet at one point.  do you think that is possible?
i do get it up there, since the plane is 116 inches long and wingspan is 118"
speed at one time was 110 mph.
the plane weighs 46 pounds.
one of the older gentleman at the club refuted any of the telemetry data, saying it was impossible the plane would be that high or that it would go that fast.
avoid crashing!!
Hide Signatures
       Post #: 994
RE: Spektrum Telemetry module and iPhone App. - 1/24/2013 3:20 PM
rapega
Score: 100
Last Login: 5/13/2013
Status: offline
Hi,
is anybody using an ipad mini?
Thank you,
Ralf
Hide Signatures
       Post #: 995
RE: Spektrum Telemetry module and iPhone App. - 1/24/2013 3:33 PM
Franco2fly
Score: 114
Status: offline
A 46lb bird is VERY heavy... That may well be over the weight limit AMA has set.  As for the speed and Altitude, they are both possible, Just remember that GPS altitude is different from the Altitude sensor.  The HH Spektrum altitude sensor starts at Zero whether your at the beach or
flying in Denver on the side of a hill.  GPS altitude would show your actual altitude.  GPS speed is somewhat smoothed where as the Pitot tube airspeed reading is nearly instantaneous.  When I bank into a downwind turn, my speed warning goes off (< 10mph) even though the plane is actually moving through the air somewhat faster.
KKKKFL
Hide Signatures
(in reply to rapega)
       Post #: 996
RE: Spektrum Telemetry module and iPhone App. - 1/24/2013 3:42 PM
orthobird
Score: 105
Status: offline
Hi Franco
thank you for all your info,
however, where have you been
or should i say, not been.
i am referring to weight limit.
You got to get out more.
Here it is:
also,
have you ever heard of Bill Hempel, here is his website:
he sells25%, 30%, 40%, 50% and 60% scale planes:
check out his website.
i may be converting you to the big planes.
much more stable, easier to fly, easier to land,
but you have to be experienced,
a mistake can cost you thousands of dollars.
back to the telemetry question,
so i should do away with that GPS deal then, seems to me if i cannot get real time info with this, where it tells me the stuff, what good is it?
thanks again for all your advice
avoid crashing!!
Hide Signatures
       Post #: 997
RE: Spektrum Telemetry module and iPhone App. - 1/24/2013 4:05 PM
BuschBarber
Score: 104
Status: offline
quote:
ORIGINAL: Franco2fly
KKKKFL
I believe the AMA weight limit is 55lb, without a wavier, and 100lb, with a wavier.
Rich
byronf16@gmail.com
Hide Signatures
       Post #: 998
RE: Spektrum Telemetry module and iPhone App. - 1/24/2013 4:13 PM
Franco2fly
Score: 114
Status: offline
You can get it real time, I think you might have misunderstood me...
I just cannot fly and look down at a tiny iPhone screen to pick out details.  It is updated REAL TIME, there's just not the kind of audio feedback.
Maybe if I describe how I use the STi telemetry it might help:
I fire up the DX8 then the Aircraft, I make sure I see the bars on the DX8 transmitter.  I scroll the wheel and clear the min/max screen,
then I fire up the STi app (with dongle unplugged) I make sure that I have the correct plane selected, when I see the Error Dongle not
plugged in I insert the dongle, at this point I usually see the needles.  If not, repeat from start.  Once the needles are showing I will sometimes
take out a soda straw, place it over the pitot tube to make sure that Airspeed is working (Its my number one sensor)  Then I do one last system check, making sure that audio is turned on.  (I used to listen to RPM, Airspeed, Altitude, Voltage, Temp but have found that this if Info overload, now I just have airspeed temp and Altitude every 5 seconds)  Ok  so I take off listening for the updates...  I use a wire earphone clipped to my lapel with the iPhone inside a jacket so as to keep wires out of the way of spinning props.  I have found that I can do consistant and very good
landings if I get the altitude read out to be somewhere between 50 and 80 feet.  I also review post flight the GPS track to see if I can identify good turn points depending on the wind conditions.  I'm somewhat of a geek in this regard as I will not leave the flying field without making Logbook (yes I maintain a log book) entries and that's where I find the GPS read out most usable.  I must admit that I don't really compare the GPS altitude or speed readings.
I have 3 quarter scale planes now and I do find that they fly much differently than the park fly or even 25 size electrics.  Plus I like the smell and
sound of the engines over the whine of electrics chopping air.
KKKKFL
Hide Signatures
       Post #: 999
RE: Spektrum Telemetry module and iPhone App. - 1/24/2013 5:12 PM
orthobird
Score: 105
Status: offline
http://www.rcuniverse.com/forum/m_9792424/anchors_9793144/mpage_1/key_/anchor/tm.htm#9793144
avoid crashing!!
Hide Signatures
       Post #: 1000
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.736RCU1
