RE: ESM FW D-9    Gallery
Logged in as Guest
    Search This Thread
Printable Version
warbirds
Seller:  hi joe
Details:   $1,900.00   |  6/13/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: ESM FW D-9
Page: <<   < prev  63 64 65 [66] 67 68 69 70 71 72   next >   >>
Login
RE: ESM FW D-9 - 11/9/2012 3:03 AM
Asanders
Score: 105
Last Login: 6/18/2013
Status: online
thanks appreciate that. 2 blade is what I need. I will check them out
_____________________________
Oops !!
Hide Signatures
(in reply to kahloq)
       Post #: 1626
RE: ESM FW D-9 - 11/9/2012 3:22 AM
vertical grimmace
Score: 164
Last Login: 6/19/2013
Status: offline
quote:
ORIGINAL: Asanders
Awesome! 2 blades rule!
"let''''s just say, they will be satisfied with less" Ming the Merciless
Hide Signatures
(in reply to Asanders)
       Post #: 1627
RE: ESM FW D-9 - 11/9/2012 3:50 PM
drifter
Score: 115
Status: offline
Would the aluminum 4" spinner for the Top Flite giant FW-190 be a viable alternative?
It cost $40, and comes in a 2 and 3 blade version.
Click to see fullsize image.
Click for fullsize
< Message edited by drifter -- 11/9/2012 4:42 PM >
Why do they call it "dead weight" if it keeps your airplane alive?
Hide Signatures
       Post #: 1628
RE: ESM FW D-9 - 11/9/2012 4:38 PM
vertical grimmace
Score: 164
Status: offline
quote:
ORIGINAL: drifter
Would the aluminum 4'' spinner for the Top Flite giant FW-190 be a viable alternative?
That is a good idea. Have to check the shape though. May not matter to you if it is not perfect. I think the A spinners are different than the D9.
Hide Signatures
(in reply to drifter)
       Post #: 1629
RE: ESM FW D-9 - 11/9/2012 4:51 PM
Ramstein44
Score: 110
Status: offline
The Anton and Dora spinners are different in design but I too considered the TF spinner for my D11 conversion. I personally think it looks better in size then the one on my D9. I'll compare them later.
Click for fullsize
Click for fullsize
Dont expect the best if you give the bare minimum.
Platt FW190, Holman FW190, Meister FW190, SIST FW190, TF FW190.
Hide Signatures
(in reply to vertical grimmace)
       Post #: 1630
RE: ESM FW D-9 - 11/9/2012 5:03 PM
Asanders
Score: 105
Status: online
too late, I ordered the one from China last night. The top flite would have been cheaper. I noticed the TF is 4 inch and the other one is 4.25. Prob not much of a diff in that area. Fed Ex says my 190 will be here tomorrow!
Oops !!
Hide Signatures
       Post #: 1631
RE: ESM FW D-9 - 11/9/2012 7:59 PM
n8622t
Score: 101
Last Login: 6/12/2013
Status: offline
You should have used UPS... you would have gotten it yesterday
"Go low if you wanna make a show"
P-40 Brotherhood #49
Hide Signatures
       Post #: 1632
RE: ESM FW D-9 - 11/10/2012 2:19 PM
Asanders
Score: 105
Status: online
It is in town! I have to work today, hope my sweet wife accepts the delivery lol!
At FedEx destination facility
SALT LAKE CITY, UT
Oops !!
Hide Signatures
(in reply to n8622t)
       Post #: 1633
RE: ESM FW D-9 - 11/11/2012 12:20 AM
umitv
Score: 100
Status: offline
Which gas engine will fit without firewall modification? Da60 5.3 inch from firewall but dle 55 is 6.5 inch from standoffs
real men fly gas
Hide Signatures
       Post #: 1634
RE: ESM FW D-9 - 11/11/2012 2:02 AM
kahloq
Score: 125
Status: offline
quote:
ORIGINAL: Asanders
The one from sdshobbies is 4.5", not 4.25"
Hide Signatures
       Post #: 1635
RE: ESM FW D-9 - 11/15/2012 3:47 AM
Asanders
Score: 105
Status: online
I am installing the xyz or whatever it is from HK 53cc twin. I was wondering do you have to install a twin cylinder with the carb down or can you put it up? Never used one of these before. I noticed in your videos Ticketec you used this engine. Looks like it flew it well.
Oops !!
Hide Signatures
       Post #: 1636
RE: ESM FW D-9 - 11/15/2012 8:07 AM
ticketec
Score: 105
Status: offline
quote:
ORIGINAL: Asanders
Flies great with that engine!! I installed mine with the carb facing down and haven't had a problem. I know someone else has turned the pots around on the engine is that the exhaust is opposite to the carb but I my choice was to install the engine as it was manufactured.
Dave
Hide Signatures
       Post #: 1637
RE: ESM FW D-9 - 11/15/2012 8:58 AM
STICK MODE
Score: 100
Status: offline
quote:
ORIGINAL: ticketec
quote:
ORIGINAL: Asanders
Dave
I would back Dave with that thought they fly very scale like, ideal motor for the plane
If the world should blow itself up, the last audible voice would be that of an expert saying it can''''''''t be done."
Hide Signatures
(in reply to ticketec)
       Post #: 1638
RE: ESM FW D-9 - 1/9/2013 9:09 PM
mike day
Score: 100
Last Login: 6/17/2013
Status: offline
how do you get sds hobbys to answer the phone to plase the oder for a spinner.?
Hide Signatures
       Post #: 1639
RE: ESM FW D-9 - 1/9/2013 9:56 PM
STICK MODE
Score: 100
Status: offline
quote:
ORIGINAL: mike day
just order it on line i have used them for a while with no probs
Hide Signatures
(in reply to mike day)
       Post #: 1640
RE: ESM FW D-9 - 1/9/2013 10:01 PM
fockewulf37
Score: 111
Last Login: 5/9/2013
Status: offline
Hey Guys,
I Have not been keeping on the threads much lately. But. The cockpits I produce are fit to the plane. You do have the reroute the control lines and reposition some of the servos most of the time. I try to make the cockpits so they will fit a full body size pilot that is available. There are other cockpit Producers that make shallow cockpits that you have to do less cutting.
I try to make a cockpit kit so that you look down into the cockpit area and it not just for a bust. I try to supply a decent cockpit for a fairly reasonable price...
As my website says. If you cut something up,or screw something up, and need a replacement part just email or call me. I am very reasonable on replacement parts.
Ty
tysplanes.com
food for thought:''''If the enemy is in range, so are you..''''''Tracers work both ways.''''
Hide Signatures
       Post #: 1641
RE: ESM FW D-9 - 1/10/2013 2:06 AM
kahloq
Score: 125
Status: offline
I definitely happy with the cockpit kit. Sure I had to do some mods, but were mostly minor. The plane just wouldn't look right without a full cockpit.
Hide Signatures
(in reply to fockewulf37)
       Post #: 1642
RE: ESM FW D-9 - 1/14/2013 5:33 PM
mike day
Score: 100
Status: offline
thanks stick .i need wheels herd some used williams brothers. i looked at them which ones do i need and what size i using sierra mains thanks.?
Hide Signatures
(in reply to STICK MODE)
       Post #: 1643
RE: ESM FW D-9 - 1/14/2013 6:22 PM
STICK MODE
Score: 100
Status: offline
quote:
ORIGINAL: mike day
Mike I bought a set of Williams brothers 4and a half inch wheels but felt they where a bit thin for the plane (they could be used ) in the end I used Glennis scale wheels down side is there not cheap another way is to use the esm ones with the kit place them up on a lathe on a mandrel and sand more of a radius on the contact face ( just get rid of the square look ) then paint them in fact I ended up doing this with the smaller ESM190 a5 Down side to Glennis ones are that when they are in the deployed mode ( as for landing ) the weight will change the COG to more nose heavy as they swing forward cheers stick
Click for fullsize
Hide Signatures
       Post #: 1644
RE: ESM FW D-9 - 1/16/2013 12:52 AM
Dowmer
Score: 100
Last Login: 6/15/2013
Status: offline
Gents,
I've been lurking for a long time now so I thought I'd pipe up.  First I'd like to give a shout out to Ramstein, ticketec, Frank (aka) Stick Mode, Kwik and the rest for all the great info and discussion over the past year or so.
Question is:  I want to get into gas motors (I'm a newbie) and D9 is my choice of plane.  I know the XYZ 53 just shoe horns into the cowl of the ESM D9 at 217mm width.  I want to get the ESM and then move everything to a Holman D9 kit when finished.  Will the XYZ twin fit the Holman cowl....Anyone?  I know it has a slightly smaller wingspan. (2")  Ramstein, your a D9 Experten, whats the inside Cowl diameter of the Holman kit?
Weight wise, are the ESM and Holman kits build about the same for weight?
Jason
Flying:
P-40E 80"
Hide Signatures
       Post #: 1645
RE: ESM FW D-9 - 1/16/2013 1:16 AM
Ramstein44
Score: 110
Status: offline
Mine is at a friends house in prep for paint. I think the XYZ is too large to fit the Holman. The cowl is much smaller then the ESM. I just placed a DLE55RA in my holman and I had plenty of space. I'd possible go that route. Not the normal DLE as you have to butcher the cowl with that muffler or purchase an aftermarket version.
Hide Signatures
(in reply to Dowmer)
       Post #: 1646
RE: ESM FW D-9 - 1/16/2013 1:19 AM
Dowmer
Score: 100
Status: offline
Thanks Ram,
I wanted to keep everything concealed.  Doesn't the DLE55RA stick out the bottom?
J
Flying:
P-40E 80"
Hide Signatures
(in reply to Ramstein44)
       Post #: 1647
RE: ESM FW D-9 - 1/16/2013 1:45 AM
Ramstein44
Score: 110
Status: offline
It will.
Hide Signatures
       Post #: 1648
RE: ESM FW D-9 - 1/16/2013 2:18 AM
Dowmer
Score: 100
Status: offline
OK...   Any recommendation for a motor that will work well in both the ESM and the Holman D9 that will fit in the cowl?
J
Flying:
P-40E 80"
Hide Signatures
       Post #: 1649
RE: ESM FW D-9 - 1/16/2013 2:57 AM
STICK MODE
Score: 100
Status: offline
Hi Jase
Good to see you on board on this one I know you will do the kit credit I used the xyz motor it’s totally concealed I did this by using two cowls cutting it at 12 o’clock 3, 9, and 6, and adding in 3/8 of a inch per section that gave me room to enclose the plugs etc and still look scale. The 56 xyz has more than enough power for scale flying as you know I filled in the wings and stab and glassed them which I feel has been worth it. Wheels came via Ram cockpit kit via TY( very easy to install) paint via air brush and a few beers ( ok quite a few beers ) its had 18 flights on it so far, fly’s nice more like a pattern plane .
The xyz starts easy I choke it for about 4 flicks ignition on and she’s a one flick start to date no problems. Have put in link to show xyz in place and running was taken a while ago but up loaded with my normal speed lol (yeh ill get around to it)
Cheers Frank aka stick
http://www.youtube.com/watch?v=0naBPQFedgI
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1650
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.906RCU1
