RE: ESM FW D-9    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AZ Model Aircrafters 1/4 Scale Albatross D.V - RTF
Seller:  Dumb Thumb
Details:   $2,500.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: ESM FW D-9
Page: <<   < prev  61 62 [63] 64 65 66 67 68 69 70   next >   >>
Login
RE: ESM FW D-9 - 6/28/2012 9:30 PM
glazier808
Score: 291
Last Login: 5/25/2013
Status: offline
"someone please measure and post the pivot point to axle distance on the standard Sierra gear? The larger size with the functional downlink. "
12inches is what I measure on my gear. I belive the holman/sist gear are the same, as this is what I have, not the d9.
Casey
_____________________________
Fliteskin, Sierra, Nelson Hobby, MICKO aircraft, Getstencils, Holman Plans, VicRC, Castle Creations, Addicted to Luft
Hide Signatures
(in reply to corsair183)
       Post #: 1551
RE: ESM FW D-9 - 6/28/2012 9:34 PM
wphilb
Score: 105
Last Login: 5/24/2013
Status: offline
Many thanks!
Whitney
Hide Signatures
(in reply to glazier808)
       Post #: 1552
RE: ESM FW D-9 - 6/28/2012 9:38 PM
glazier808
Score: 291
Status: offline
glad to help
Hide Signatures
(in reply to wphilb)
       Post #: 1553
RE: ESM FW D-9 - 8/15/2012 10:01 PM
n8622t
Score: 101
Last Login: 5/20/2013
Status: offline
Hey Ram I had to revive it from page 10...wanted to see what muffler you had used on your build of the D9
Jimmy
"Go low if you wanna make a show"
P-40 Brotherhood #49
Hide Signatures
(in reply to Ramstein44)
       Post #: 1554
RE: ESM FW D-9 - 8/15/2012 10:38 PM
Ramstein44
Score: 110
Status: offline
Just the stock version. I wish I'd known about the j-tech version I used on the BF109 then.
Dont expect the best if you give the bare minimum.
Platt FW190, Holman FW190, Meister FW190, SIST FW190, TF FW190.
Hide Signatures
(in reply to n8622t)
       Post #: 1555
RE: ESM FW D-9 - 8/16/2012 7:06 AM
ticketec
Score: 105
Status: offline
Hey Ram,
Did you ever end up flying your dora? I would love to see some flying pic's of your colour scheme!
dave
Hide Signatures
       Post #: 1556
RE: ESM FW D-9 - 8/16/2012 10:17 PM
Ramstein44
Score: 110
Status: offline
I flew her several times prior to the paint but haven't after the new scheme. Just don't get the chance to go all the way out to my big bird field (Chattfield) much anymore. I hope to get some pics here soon or at WOR if all go as planned.
Hide Signatures
(in reply to ticketec)
       Post #: 1557
RE: ESM FW D-9 - 8/19/2012 7:54 PM
kwik
Score: 105
Status: offline
Ticketec, are you still visiting this thread?
I have a question for you, didnt you test the XYZ 53 cc twin?
Here it is, in a Sist D9;
http://www.youtube.com/watch?v=29a9azO-l-Q&feature=plcp
Now, I get 6500 rpm with a Menz 19x10
The plane weights 10 kg
What do you think? Will that do it? Will it fly?
What max rpm do you get, at which propeller? Do you remember?
There is some resistance when I move the propeller, almost like the bearings are too tight.
I cannot hand-start it, must use a starter.
Ta 152 says I should try a 18x8 ....
Hide Signatures
       Post #: 1558
RE: ESM FW D-9 - 8/19/2012 11:47 PM
TA152
Score: 105
Status: offline
I said 20" x 8" Kwik
Ta152C. The ultimate Warbird!
Hide Signatures
(in reply to kwik)
       Post #: 1559
RE: ESM FW D-9 - 8/20/2012 4:37 AM
kahloq
Score: 125
Status: offline
At 6500 rpms with a 10 pitch, your not going to be flying any faster then 62mph. You might try an 18x12. Even at 6000rpms, you'd get 69mph with a 12 pitch. With an 8 pitch, even at 8000rpms, youd only get 60mph
Hide Signatures
(in reply to TA152)
       Post #: 1560
RE: ESM FW D-9 - 8/20/2012 8:07 AM
ticketec
Score: 105
Status: offline
quote:
ORIGINAL: kwik
Hey Kwik
Yeah still here! Just been busy plaing with EDF and turbines lately but still keep an eye here
Yes I am running the XYZ 53cc twin and I am using a 22x10 prop. I was using a "TBM" branded prop but that has since been damaged and I replaced it with a cheap carbon fibre 22x10 prop which is ok, but not as good as the wooden one I had on it. I am going to replace it with an Xoar prop on it next so see if that provides a little bit better performance.
As for RPM, I am getting about 5600 with the 22x10 "TBM" prop and my dora weights in at about 11.5kg. The aircraft flew fine with good speed, It sometimes feels a little short in the vertical, but as the engine bed's in further this will improve and better and better. It has already improved a lot from when I first flew her. I also tried 22x8 prop but did not like it, the 10 in pitch was fine, Remember it's a warbird not a pylon racer!!
As for not being able to hand crank it???? there is something wrong there for sure! This must be why there seems to be quite a difference in RPM figures for your engine to mine. I have only ever hand started mine and have no need for an electric starter. It is just as loose as any other gasser engine once I have the fuel up to it, so I would be looking into what is causing that to start with. you also had some issue with a piston or ring didn't you?
dave
Hide Signatures
(in reply to kwik)
       Post #: 1561
RE: ESM FW D-9 - 8/20/2012 7:56 PM
kwik
Score: 105
Status: offline
Okay. thanks Ticketec. I think the handstarting and max rpm is due to the RcExl ignition.
I ruined it by using Life battery directly on it, and now I have a brand new ignition, which doesnt want to
ignite the fuel from handstarting. So damn irritating.
And the tightness of the axle...I can feel its uneven when I turn it. I fear the bearing has corroded
since I left it outside a few nights....must open it up and check, I'm afraid.
Hide Signatures
       Post #: 1562
RE: ESM FW D-9 - 8/27/2012 7:37 PM
kwik
Score: 105
Status: offline
Ticketec, 22x10 at 5600 rpm means we have exactly the same numbers.
Here is a video of the test flight; As you can see I need more power at takeoff.
19x10 at 6500 rpm barely made it, and it is too slow in flight.
I might have to abandon this engine, but there are no alternatives regarding gas twins
strong enough, and that will fit inside the cowling. Too good to be true....
http://www.youtube.com/watch?v=rMJZMgc0Z5E&feature=youtu.be
Hide Signatures
       Post #: 1563
RE: ESM FW D-9 - 8/27/2012 9:44 PM
n8622t
Score: 101
Status: offline
Ya I had bought one of these 53cc twins for the LA7 and had considered it for the D9, but after seeing the RPM numbers with the 22x10 i abandoned the idea for either plane. Still seems to be a good engine though....
Jimmy
Hide Signatures
(in reply to kwik)
       Post #: 1564
RE: ESM FW D-9 - 8/27/2012 9:49 PM
n8622t
Score: 101
Status: offline
Hey Tic if are using the original ignition you might try an EXCEL upgrade...local gut is having trouble with his XYZ 53cc ignition and is going to the EXCEL.
Jimmy
Hide Signatures
       Post #: 1565
RE: ESM FW D-9 - 8/27/2012 10:12 PM
kwik
Score: 105
Status: offline
Mine has RcExcl already. It is the second set now. Maybe the reason the first one stopped working was that
I used Life directly. So now I have the second one, using a regulator.
Impossible to start by hand now.
I bought two ignitions from OctopusRC. One of them didnt work at all. No joy. The second one was used in the test flight.
Had to rev it up to about 1000 rpm with the starter for, say, 10 seconds. After that it is running fine.
I am now waiting for "original" Saito/Rcexcel ignition for the FG-57; It wont start anymore either.
(Using RcExl from octopus RC on the FG-57 now also, it lasted for 15 flights)
I wonder how so many can sell RcExcl twin ignition at e.g 75$ (Octopus), while advantage hobby sells RcExl for 222$ ?
http://www.advantagehobby.com/177601/SAIG57T153/
http://store.octopusrc.com/index.php?l=product_detail&p=122
Is there a quality difference, I wonder? Both are RcExcl twin ignitions.
Hide Signatures
       Post #: 1566
RE: ESM FW D-9 - 8/28/2012 3:25 AM
n8622t
Score: 101
Status: offline
Yes there are copies....google the ignition and look at the Chinese suppliers. One of them shows you how to tell the copy fron the actual... If I find it I'll post it for you
Jimmy
Hide Signatures
(in reply to kwik)
       Post #: 1567
RE: ESM FW D-9 - 8/28/2012 3:47 AM
n8622t
Score: 101
Status: offline
Be sure voltage is below 6.0v, 4.8v is safer setting
Jimmy
Hide Signatures
       Post #: 1568
RE: ESM FW D-9 - 8/28/2012 6:15 AM
STICK MODE
Score: 100
Last Login: 5/13/2013
Status: offline
Be sure voltage is below 6.0v, 4.8v is safer setting = very true as most 6 volt systems charge at up to 8 volts i have always run mine on 4.5 never had a issue with ignition lipos with a regulator are accidents waiting to happen i once plugged a 3 cell in to my 2 cell jet cat p80 end result was a $540 hole in the pocket as smoke came from the on board ECU as for rpm on the D9 i run the same set up as Ticketec never had a issue with flight mines had over 40 on it so far my tank is slightly higher to help gas to the carby hand starts every time when wet sounds like something is not right in the bearing dept if the motor is that tight kwik PS i watched your flight seemed all right it is a war bird it appeared to me to be ok in speed (in flight) but will say the takeoff was long just my 2 cents worth woops the US dollars has come back up make that my 1 cents worth
If the world should blow itself up, the last audible voice would be that of an expert saying it can''''''''t be done."
Hide Signatures
       Post #: 1569
RE: ESM FW D-9 - 8/28/2012 11:28 AM
ticketec
Score: 105
Status: offline
quote:
ORIGINAL: kwik
Kwik,
Seeing that both our Fw's are of roughly the same size and weight, they should fly fairly similar with the same amount of power. I would suggest that you try the 22x10 prop. you flight looked a little like the first time I tried the 22x8 prop, I landed after about 4-5 circuits as well. Have you seen the video's of mine flying that I have posted so that you have something to compare it with?
I'm hoping to get out with the dora this weekend and will tach the engine again to give you it's current figures with the crappy carbon 22x10 prop.
I have been very lucky that my XYZ has worked perfectly so far since it came out of the box. still using the original ignition, the only change made was I am running iridium spark plugs and I run high octane fuel as well.
Another option that has just come out, but i'm not sure on it's dimensions is the DLE that have released, a new twin DLE-60
http://www.troybuiltmodels.com/items/DLE60TWINENGINE.html
I would seriously think about trying the 22x10 before you take the XYZ out and see how that performs.
dave
Hide Signatures
(in reply to kwik)
       Post #: 1570
RE: ESM FW D-9 - 8/28/2012 10:19 PM
n8622t
Score: 101
Status: offline
DLE60 10.5" plug cap to plug cap... like the 53cc twin vs. a 50cc single, it wont do what a single cylinder 60cc will do, but it will be smoother if thats all you are after.
Hide Signatures
       Post #: 1571
RE: ESM FW D-9 - 8/28/2012 10:40 PM
kwik
Score: 105
Status: offline
But Dave, going from 19x10 to 22x10 ? Then rpm will drop from 6500 to 5600...meaning speed in the air will drop ?
And hp drops too....can you tell me your thoughts behind this? Is it something you experienced?
That the performance was better with 22x10 than with 19x10 ?
Hide Signatures
       Post #: 1572
RE: ESM FW D-9 - 8/29/2012 4:38 PM
vertical grimmace
Score: 154
Status: offline
Too bad DLE did not angle those plugs back.
"let''''s just say, they will be satisfied with less" Ming the Merciless
Hide Signatures
(in reply to kwik)
       Post #: 1573
RE: ESM FW D-9 - 8/29/2012 10:06 PM
n8622t
Score: 101
Status: offline
quote:
ORIGINAL: kwik
Thats what you call a typographical error....
Hide Signatures
(in reply to kwik)
       Post #: 1574
RE: ESM FW D-9 - 9/10/2012 5:39 AM
kahloq
Score: 125
Status: offline
Ok finally some updated progress on mine. She is getting close to being finished. A lot of small things left to do, but should be ready to maiden next weekend hopefully. I may not have the cockpit done by then, but as long as everything else is good to go, I'll take ehr out to test.
ESM fw-190D9
Motor: Rimfire 65cc electric
Prop: 21x14 2 blade currently. Also have a 20x14 3 blade....additonally have a 23x12 2blade in the mail.
Esc: CC 160 HV version 2
Batts: two times 6s 6000 in series for 12s 6000.....have two 6s 8000's in the mail for longer flights provided the maiden goes ok.
Retracts: Sierra 1/5th scale 190 gear plus retractable tail wheel
Spinner: SDShobbies for the 2 blade. gene barton for the 3 blade
Paint...base coats of light german gray with yellow rudder. The rest...ie the green/gray on the fuse/horizontal stabs were airbrushed on by Vertical grimace. Many thanks to him for his help.
The top of the wings are untouched. I took the wing to Home Depot and had them color match the green and the grey and they both came out perfect first time from the mixer
I will be adding additonal marking, unit bands, etc
But heres some nice pics. Also...instead of the screws for the internal cowl attachments as shown in the manual...I installed 4-40 blind nuts
The two tail wheel pics....the one shows the unit fully retracted and the other extended. Once the cover plate is installed, the tail wheel will be mostly within the fuse when up.
I will also be setting up a separate air tank/valve for the tail wheel just in case so if it leaks over time, I 'll still be able to get the mains down. OR.....I may just get a tamjets failsafe device like the jet jockies use so ifn the pressure fails below a certain level, the unit auto activates the valve to drop the gear.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by kahloq -- 9/11/2012 12:38 PM >
Hide Signatures
       Post #: 1575
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.781RCU1
