RE: Black Horse Shrike Commander    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: Black Horse Shrike Commander
Page: <<   < prev  1 2 3 4 5 [6] 7 8   next >   >>
Login
RE: Black Horse Shrike Commander - 3/17/2012 4:57 PM
kcforsythe
Score: 100
Last Login: 3/4/2013
Status: offline
Hey Joe,
Now that I've got everything in the plane and could do a more accurate balance, it turns out I am going to have to either add some weight in the nose or move one of the lipos forward to get the 6mm balance from the leading edge. I need to determine how much I'd need to add before I decide whether I'll just add weight or do a move of a lipo. There's definitely room in the nose to add weight but I hate to increase the overall weight. If it's just a little, that's probably what I'll do though.
My first check of the balance was a little crude but I used a precise craddle this time and you're concerns are unfortunately valid.
I'll let you now how it turns out. Heading to the LHS today to pick up some items to complete the work.
Our weather here has been very warm. Amazingly, I've been out 4 times already this season, mostly flying heli's.
One other thing I'm going to try is setting the ailerons up as flaperons and see if I can get the speed slowed more for landing.
Do you know why they have you drill into the wing tube and put screws down from the top of the wings? With two wing bolts on each side, I wouldn't think this would be needed. I've never seen a plane do this before. Just seems like overkill.
More later....
Kent
Hide Signatures
(in reply to JoeMamma)
       Post #: 126
RE: Black Horse Shrike Commander - 3/19/2012 12:30 AM
kcforsythe
Score: 100
Status: offline
Well....break out the champagne....she flies!!!
Flew the first two flights today and everything went great. When I added weight to the nose, I added slightly too much making it just a bit nose heavy but I think with this plane, it will aid in stability. It felt most comfortable flying on high rates. I was expecting all of the controls to be more sensitive bit they're really not. I had plenty of expo on both the aileron and elevator but I'll be flying it on high rates from now on.
I flew the first flight with gear down for the entire flight. The second I retracted the gear and tried out the flaperons. I didn't need to program in much down elevator at all with the ailerons both down. The plane looks UNBELIEVABLE in the air with the wheels up. Very scale like.
I was also surprised at how well it slowed down to land. The second landing I was just above stall speed and it didn't feel like a wing wanted to fall off at all.
I'll try and get some video of the next flight and post a link to it.
More later....
Kent
Hide Signatures
(in reply to kcforsythe)
       Post #: 127
RE: Black Horse Shrike Commander - 3/19/2012 1:23 AM
handyman 220
Score: 100
Last Login: 5/26/2013
Status: offline
That's great news!! Glad to hear it !!
_____________________________
Do it right the first time, or not at all!
Hide Signatures
       Post #: 128
RE: Black Horse Shrike Commander - 3/19/2012 1:37 PM
JoeMamma
Score: 115
Status: offline
Kent,
A good maiden is always great news ! Glad to hear she wasn't pitchy like one particular flight I saw in a youtube video.
There are only a few BH Commander flights I found on line, so be sure to post yours when you get the time.
Joe M.
Joe Mamma
Hide Signatures
       Post #: 129
RE: Black Horse Shrike Commander - 3/21/2012 11:22 PM
aerocom20
Score: 100
Last Login: 1/12/2013
Status: offline
HI Kent,
Thanks for the flight report!
Could I ask a couple of questions?
When you mention high rate are you meaning the high rate throws as in the manual?
Also what amount of expo had you dialed in?
Regarding your ailerons/flaperons did you slow the aircraft down to a landing speed with the flaperons deployed?
How many degrees down travel do you set for the flaperons?
Adrian
Hide Signatures
       Post #: 130
RE: Black Horse Shrike Commander - 3/22/2012 10:03 PM
zob007
Score: 100
Last Login: 3/17/2013
Status: offline
Hi Kent,
congratulations for your successfull maiden flights. Electric option is often a good one with twins. Which total weight did you achieved?
Can this plane fly slowly and land slowly?
regards
Hide Signatures
(in reply to aerocom20)
       Post #: 131
RE: Black Horse Shrike Commander - 3/22/2012 10:15 PM
zob007
Score: 100
Status: offline
Hi Kent,
regards
Hide Signatures
       Post #: 132
RE: Black Horse Shrike Commander - 3/27/2012 7:25 PM
kenair
Score: 100
Last Login: 5/22/2013
Status: offline
Awesome, look forward to the video and more flight reports!
cheers -ken
my sites at www.mustang51.com and www.spitfire9.com
Hide Signatures
(in reply to zob007)
       Post #: 133
RE: Black Horse Shrike Commander - 3/27/2012 8:49 PM
JoeMamma
Score: 115
Status: offline
My original idea was to make mine up like Bob Hoover's Commander.
That was until I got some prices $$$$$$ for all of the complicated graphics. That shot down that idea in a hurry !
Joe M.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Joe Mamma
Hide Signatures
(in reply to kenair)
       Post #: 134
RE: Black Horse Shrike Commander - 4/27/2012 12:05 AM
JoeMamma
Score: 115
Status: offline
Hey Kent,
Put on any more flights on your Commander ?
I finally started to work on mine. I decided to go with electric power and EFlite electric retracts. Just ordered most of my parts.
Boy, the assembly manual sure leaves a lot to be desired.
Today I was attempting to fit and adjust the cowls (nacelles) before I install the motors.
When they installed the landing gear doors on mine, they really messed up........they are already pre-glued, are sticking, crooked, binding up and also the installed return springs are very weak. Obviousley NO quality control is used here ! Because they were already pre-glued and installed, they will now be a real pain to attempt a repair.
You mentioned those wing screws going into the wing support tube. I didn't know what you were talking about until I spotted them. I agree........wayyyy overkill so mine won't get those wing tube screws.
Our club is having its annual electric event on May 19th and 20th, so I'm shooting to finish her up for that date. It may not be completed by then, but I wanted to at least put it on display.
Joe M.
Joe Mamma
Hide Signatures
       Post #: 135
RE: Black Horse Shrike Commander - 4/27/2012 9:00 AM
Quigleywins
Score: 110
Last Login: 5/25/2013
Status: offline
Hi joe can you tell me what set of retracts you are going to use as that is the way i will go to get mine back in the air.I did contact e flite and they sent the information on the non rotating ones when questioned again they said they never had a set that would fit. If you have used the 60 size ones I will like to know how strong they are.
On that build I put a small piece of the air retract tube over the screw on the rudder actuator as the brass centhe in the nylon arm can come lose later. Its a good fix.the tube fills the gap between the thread and the nylon. yours Paul T
''''''''''''''''bugger''''''''''''''''- That went in quick... I fly that well now i''m DANGEROUS.
Hide Signatures
       Post #: 136
RE: Black Horse Shrike Commander - 4/27/2012 10:13 PM
JoeMamma
Score: 115
Status: offline
quote:
ORIGINAL: Quigleywins
Hi Paul,
Retracts ? I'll be using the EFlite 60-120 size for the nose gear.
EFlite doesn't yet make a set of 60-120 rotating gear, but they do have a set of rotating mains in the 25-46 size. The actual aluminum case on the 60-120 size is slightly larger than the smaller 25-46 size. The strut wire size on the 60-120 size is 5mm. The strut wire size on the 25-46 size is 4mm. I'm hoping the 25-46 size main gear will be beefy enough for the Commander.
Both the EFlite nose retract and the main gear are far from a drop-in fit, so it's going to take some wood fabrication to get them all to work.
This afternoon I started to spend some time on drawing up what will be needed for the EFlite retract gear conversion.
I didn't care for the supplied spinners, so I ordered a set of Tru Turn 2.25" Ultimate spinners. I'm planning on using a set of Master Airscrew 12x6 3-blader's. Tru Turn is going to do a custom-cut for me to fit the 3-bladers. I used the same spinners with the same EFlite motors, and the same 3-blader's on my Hangar 9 Twin Otter.
The Tru Turn's have always fit perfect for me. The only problem is they are a little pricey.
Rudder ? I haven't really looked at the rudder hookup as of yet.
Joe M.
Joe Mamma
Hide Signatures
(in reply to Quigleywins)
       Post #: 137
RE: Black Horse Shrike Commander - 4/28/2012 4:50 AM
kcforsythe
Score: 100
Status: offline
Hey Joe,
I have about 5 flights on it. Unfortunately I had the nose gear stop working while doing some testing on the bench so I had to send it out and have it replaced. I think the electronics when bad on it. Max at ParkRCModels sent me a new one out within a few days and I'm back in business. I haven't had it out since then though. I still plan on taking some video but haven't had the chance. Sorry.
Paul, the electric gear I used is the RC Lander tricycle gear with rotating mains. They handle up to 15lbs total weight. These mains require that you build up the gear mount on the plane and use longer screws. Mine turned out to be a great fit though. The struts that come with the kit slide right on this gear and work like a charm.
Kent
Hide Signatures
       Post #: 138
RE: Black Horse Shrike Commander - 5/1/2012 6:24 AM
duanen
Score: 100
Status: offline
hey guys,well i just had the phone call from my LHS that my aerocommader is finally on its way will be here in about 10 days.Ive had this plane on order for 3 months.Im thinking about trying the new NGh 9cc gas engines in this plane.for those who have the plane who do you think these will fit?
Hide Signatures
       Post #: 139
RE: Black Horse Shrike Commander - 5/1/2012 8:46 PM
JoeMamma
Score: 115
Status: offline
quote:
ORIGINAL: duanen
Looks like you may be the first to try using the NGH 9cc gasser in this particular Commander.
Joe M.
Joe Mamma
Hide Signatures
(in reply to duanen)
       Post #: 140
RE: Black Horse Shrike Commander - 5/6/2012 7:23 PM
Jas65
Score: 100
Last Login: 8/11/2012
Status: offline
Hello guys
Im kind of new on this forum and luckily founded this thread about the commander,i have just ordered one from staufenbiel in germany and looking forward
As it arrives,I have the robbe twin air and the step up to the commander just seemed natural,im planning to electrify it when it arrives,since im located
In sweden making orders from the US is not mine first option du long customs processing,im bying quite lot of mine gear from hobbyking and wonder if anyone could give a me a motor suggestion also from HK if possible,im very glad that atleast one flier got it in air running a electric setup.
Best regards
Jack from Sweden
Hide Signatures
       Post #: 141
RE: Black Horse Shrike Commander - 5/6/2012 9:18 PM
JoeMamma
Score: 115
Status: offline
quote:
ORIGINAL: Jas65
Hello guys
Best regards
Jack from Sweden
Hello Jack,
I'm really not familiar with HK motors or ESC's, but maybe somebody else here at RCU can help.
For my Commander I'm going with EFlite Power 32's, EFlite 60 amp ESC's, Master Airscrew 12x6 3-bladers and Hyperion 4-cell 3300 mah lipos.
The reason for this power setup is I have the identical setup on both a Hangar 9 Twin Otter and an EFlite Deuces Wild. For about two years both of these planes have performed perfectly with this same setup.
The Commander weighs about the same as my Twin Otter, so I'm hoping this same power setup will work out equally as well on the Commander.
Joe M.
Joe Mamma
Hide Signatures
(in reply to Jas65)
       Post #: 142
RE: Black Horse Shrike Commander - 5/6/2012 9:53 PM
Jas65
Score: 100
Status: offline
Thanks joe, I think i found what i was looking for..
http://www.hobbyking.com/hobbyking/store/%5F%5F19025%5F%5FTurnigy%5FG32%5FBrushless%5FOutrunner%5F600kv%5F.html
The data seems similar to the power 32, i have 2. Cyclone power esc at 60 a that gone suit fine,the biggest problem for now i to figure out how mount the motors in the nacelles,i think i need to have the plane first so i can calculate the motormount etc.
Br
Jack
Hide Signatures
       Post #: 143
RE: Black Horse Shrike Commander - 5/7/2012 8:49 PM
Jas65
Score: 100
Status: offline
Hello
I would like to know the dimensions on the spinner that are supposed to cover 12/6 3 bladed master airscrew,if someone could provide dimension in european mm that would be great.
Br
Jack
Hide Signatures
(in reply to Jas65)
       Post #: 144
RE: Black Horse Shrike Commander - 5/7/2012 11:59 PM
JoeMamma
Score: 115
Status: offline
quote:
ORIGINAL: Jas65
Hello
Br
Jack
The supplied plastic spinners are 2.25 inches. I chucked them up to see how straight they were. Discovered they are fairly wobbley so they got sent to the junk pile.
I am using a set of Tru Turn, 3-blade, 2.25 inch, Ultimate spinners, part number TT-2283-B. Tru Turn keeps a list of most of the prop manufacturers, prop diameters and prop pitches, so I had my spinners custom machined to fit the Master Airscrew 12x6 3-blade props. Tru Turn always does a great job ! I also used a set of Tru Turn prop/motor/spinner adapters. Tru Turn's only problem is they are a little pricey.
We have a saying on this side of the pond.........."You get what you pay for". That saying usually is true.
As far as the metric size, 2.25 inches comes out to be 57.15mm. If you measure your cowls, I believe a 60mm spinner will fit. Maybe Graupner has them ??
Joe M.
Joe Mamma
Hide Signatures
(in reply to Jas65)
       Post #: 145
RE: Black Horse Shrike Commander - 5/9/2012 8:07 PM
Jas65
Score: 100
Status: offline
Today the shrike arrived with a lorry to mine door, hehe...what a neat size of the box..
Decided to go on the bigger motors (G46) from Hobbyking, equal to a Ic 46 engine stated by HK, also ordered 2 alu spinners  from HK (57mm) and 12(5/7 3 bladed props from Graupner, im gone inspect the kit tonight and specially the landing gears as I understand thru earlier post they are not realiable?any more tips anyone can provide me with?
cheers for now
/Jack
Hide Signatures
       Post #: 146
RE: Black Horse Shrike Commander - 5/9/2012 8:14 PM
kcforsythe
Score: 100
Status: offline
I used the E-flite 46 motors and I've been happy with the power. It has plenty of power but doesn't seem overpowered. I had to add weight to the nose to get a good balance. I'm using 2, 4S 4000mah batteries mounted just behind the cockpit but it was still tail heavy without the extra nose weight. It's a beautiful plane in the air! It gets a lot of attention.
Kent
Hide Signatures
(in reply to Jas65)
       Post #: 147
RE: Black Horse Shrike Commander - 5/9/2012 8:20 PM
Jas65
Score: 100
Status: offline
Glad to hear about that, especially the motors since im was a little worried I had ordered some Kind of to big motors
Jack
Hide Signatures
       Post #: 148
RE: Black Horse Shrike Commander - 5/10/2012 2:13 AM
Quigleywins
Score: 110
Status: offline
Joe one or two questions about your retracts. 1 Did you use the 105 deg retract on the front. 2 Have you finished the instilation of the gear.3 Were the rotating strong enough for the job.
I will in the next week be ordering the set up you have. I am working on the repair as well as the duel ace and piper commanche. so progress is some what slow not to mention the mess. Yours Paul T
Hide Signatures
(in reply to Jas65)
       Post #: 149
RE: Black Horse Shrike Commander - 5/10/2012 6:40 PM
Jas65
Score: 100
Status: offline
Hello again
Also I would like to hear moore about the retract issue, you guys that had problem with the origin mounted retract was this caused by a weak baseplate or the legs, or maybe something else, I inspected mine retracts yesterday and from what I can see they looks solid and the finnish is
ok, if to spend another 200$ on new retracts I want to exlude that the origin has some inbuilt weakness as they seems fine in a first look, on another side Im not willing to risk whole project due  poor quality installed by BH
Cheers
Jack
Hide Signatures
       Post #: 150
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.094RCU1
