Dynam radio crystal switch to Futaba TX failure    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Lanier Taylorcraft (1/4) - ARC
Seller:  p38nut
Details:   $250.00   |  6/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Electric Aircraft Universe >> Electric General Discussion >> Dynam radio crystal switch to Futaba TX failure
Page: [1]
Login
Dynam radio crystal switch to Futaba TX failure - 3/31/2011 4:27 PM
zep77
Score: 100
Last Login: 5/9/2011
Status: offline
Tried to get a better TX and wanted to use my old FUTABA 6A and switch the crystal in the crap Dynam NEKO 4 that came with the HAWK SKY. Both are 72 MHZ so I thought I could take the crystal out of the Dynam and put it in the Futaba and it would work, WRONG. Why would it not work ? Dynam crystal is 72.790 going into the Futaba which was 72.810. I left the 72.790 crystal in the receiver thinking it would work. know there are about 15 years or so apart in age. What has changed in crystals ? Thanks.
Hide Signatures
       Post #: 1
RE: Dynam radio crystal switch to Futaba TX failure - 3/31/2011 5:09 PM
BarracudaHockey
Score: 280
Last Login: 6/19/2013
Status: offline
You learned the hardway that crystals are manufacturer specific for the most part.
Also, changing transmitter crystals is illegal.
_____________________________
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to zep77)
       Post #: 2
RE: Dynam radio crystal switch to Futaba TX failure - 3/31/2011 6:51 PM
zep77
Score: 100
Status: offline
Did not know that it was illegal.  I have been out of the hobby for over ten to fifteen years now. I use to change crystals all the time if a radio malfucntioned or traded. I will have to look into that one. Thanks !
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 3
RE: Dynam radio crystal switch to Futaba TX failure - 3/31/2011 6:59 PM
zep77
Score: 100
Status: offline
quote:
ORIGINAL: BarracudaHockey
"If your transmitter uses a plug-in module then you can purchase additional modules on different frequencies and legally swap modules in the transmitter. " This is what I found. So you can switch on the same unit just not between units?
Hide Signatures
       Post #: 4
RE: Dynam radio crystal switch to Futaba TX failure - 3/31/2011 9:12 PM
BarracudaHockey
Score: 280
Status: offline
A module isn't the crystal, its the entire RF module like plugs into the back for the radio that includes the tuned assembly including the crystal.
Its illegal unless your trained to properly tune the radio to change frequency determining components such as the crystal.
www.JaxRC.com
Hide Signatures
(in reply to zep77)
       Post #: 5
RE: Dynam radio crystal switch to Futaba TX failure - 11/5/2012 11:41 PM
mrlogdog
Score: 100
Last Login: 11/6/2012
Status: offline
I find it utterly ridiculous that it's "illegal" to swap crystals. It works fine if you don't jump too many channels. Curious what law makes this illegal? Just go fly.
Hide Signatures
       Post #: 6
RE: Dynam radio crystal switch to Futaba TX failure - 11/6/2012 1:47 PM
BarracudaHockey
Score: 280
Status: offline
The FCC makes it illegal, please don't give illegal and potentially dangerous advice.
www.JaxRC.com
Hide Signatures
(in reply to mrlogdog)
       Post #: 7
RE: Dynam radio crystal switch to Futaba TX failure - 11/6/2012 2:33 PM
mrlogdog
Score: 100
Status: offline
two key parts here, potentially and Fcc (federal) The ama and fcc have been working for years to screw the little guy out of the simple joy of flying model planes. I suppose it's illegal to fly AM radio's too. switch your crystals, do a range check and go fly. Next it will be required to fly nothing but 2.4.
Hide Signatures
       Post #: 8
RE: Dynam radio crystal switch to Futaba TX failure - 11/6/2012 3:08 PM
BarracudaHockey
Score: 280
Status: offline
I'm not sure what you're talking about.
The AMA had been after the FCC for years and worked to get the 50 channels we have in the 72mhz band. Part of the agreement to get those channels was sharing the band with other users that operate between our channels.
Go and swap transmitter crystals, without the equipment or knowlege to verify that a transmitter is within output specs, and create interference with other users, paying users of that space, and find out what kind of power the feds have.
Flying in the country with nobody else around? Probably no issue other than reduced range. Try it and cause an accident, and an investigation determines that you acted illegally, and you'll probably be on your own.
I'm not really trying to change your mind, just hoping that others don't think you're offering good advice.
www.JaxRC.com
Hide Signatures
       Post #: 9
RE: Dynam radio crystal switch to Futaba TX failure - 11/6/2012 5:42 PM
Red Baron Gary
Score: 100
Last Login: 6/15/2013
Status: offline
It is not illegal to swap receiver crystals. It IS illegal to swap TX crystal UNLESS you have the transmitter checked by a FCC licensed technician to make sure that your radio is on the frequency you have changed to.
As most of us do not have the test equipment to do this checking, most of us either buy a new receiver or just leave well enough alone.
My .02,
Gary
"I don''t want to see''em crash, but I want to be there when they do." Moore''''s bromide, r.i.p. ''05
Hide Signatures
       Post #: 10
RE: Dynam radio crystal switch to Futaba TX failure - 11/7/2012 1:03 PM
Rodney
Score: 174
Status: offline
BarracudaHockey has given you some good advice above. While you may have things working when you swap transmitter crystals, you may also be generating lots of sidebands that will interfere with other users, that is the reason for the law. As to crystals, they are not a simple item. They can have an X cut, Y cut or a variations as well as quite a variation in capacitance. Now they can be used in different types of oscillators as well and each circuit is set up to work within a definite set of parameters so, when you swap crystals you may also be detuning the circuit which can create spurious side bands.
Hide Signatures
(in reply to Red Baron Gary)
       Post #: 11
RE: Dynam radio crystal switch to Futaba TX failure - 11/7/2012 3:35 PM
Red Baron Gary
Score: 100
Status: offline
If you *really* want to swap tx crystals. contact either International Crystal in Oklahoma City, OK or Sentry Crystal in Chicashaw, OK.
Tell them the radio you have and the frequency you want to be on and the can probably make a crystal for you.
Minding however, the fee for this will more than likely be in the $15.00-$20.00 range.
As a ham radio op, both of the above have made custom crystals to suit my needs over the years.
Gary
Hide Signatures
(in reply to Rodney)
       Post #: 12
RE: Dynam radio crystal switch to Futaba TX failure - 11/11/2012 7:01 PM
Bill G
Score: 112
Last Login: 6/8/2013
Status: offline
Someone can correct me if wrong, but I had heard that crystal transmitters are also tuned (such as with adjustable pots) for optimization with a specific frequency crystal. My understanding was that if you swapped a crystal with one from more than 1 channel in number from the original crystal, the tuning issues would become significant. The crystal type can also be different, as someone stated before, such as the Hitec Feather and Futaba micro 72MHz receivers using a different crystal type from GWS/Berg.
Hide Signatures
       Post #: 13
RE: Dynam radio crystal switch to Futaba TX failure - 11/12/2012 5:10 PM
Red Baron Gary
Score: 100
Status: offline
Th-re are many types of crystals,referred to as "cuts" that determine the frequency of the actual crystal itself in relationship to the frequency the user wishes to be on.
The object of the pot or trimmer it is called is to allows for small adjustments to the circuit the crystal is in to allow either the transmitter (or the receiver if that is the case) to be precisely tuned.
Hope the above is helpful,
Gary
Hide Signatures
(in reply to Bill G)
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.313RCU1
