RE: I Saw it! TF 60 Size Corsair ARF!!!!!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
warbirds
Seller:  hi joe
Details:   $1,900.00   |  6/13/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: I Saw it! TF 60 Size Corsair ARF!!!!!
Page: <<   < prev  10 11 [12] 13 14 15 16 17 18 19   next >   >>
Login
RE: I Saw it! TF 60 Size Corsair ARF!!!!! - 2/10/2012 1:39 AM
iflircaircraft
Score: 123
Last Login: 6/11/2013
Status: offline
Here is mine ready to fly once I break in the OS 95V 4-stroke.
Tom
Click to see fullsize image.
Click for fullsize
_____________________________
"Where there''s a WILL, There''s a WAY"
Hide Signatures
(in reply to KNowAceHere)
       Post #: 276
RE: I Saw it! TF 60 Size Corsair ARF!!!!! - 2/10/2012 2:20 AM
lablover
Score: 103
Last Login: 5/8/2013
Status: offline
What size 3 blade did you end up getting?
Hide Signatures
(in reply to iflircaircraft)
       Post #: 277
RE: I Saw it! TF 60 Size Corsair ARF!!!!! - 2/10/2012 3:20 AM
CorsairJock
Score: 110
Last Login: 5/25/2013
Status: offline
Just gotta say: the OBVIOUS choice would be a Master Airscrew 3 blade 14 x 7. Works fine with Saito .91, I'm pretty sure it should be the prop of choice for an OS .95
Avatar: Electric Powered, Highly Modified Hangar 9 Corsair
Club Saito Member #670
Hide Signatures
(in reply to lablover)
       Post #: 278
RE: I Saw it! TF 60 Size Corsair ARF!!!!! - 2/10/2012 2:22 PM
lablover
Score: 103
Status: offline
quote:
ORIGINAL: CorsairJock
I was thinking the same thing, I just wanted to hear someone else say it
Hide Signatures
(in reply to CorsairJock)
       Post #: 279
RE: I Saw it! TF 60 Size Corsair ARF!!!!! - 2/10/2012 3:09 PM
da Rock
Score: 265
Last Login: 6/18/2013
Status: offline
Master Airscrew 14x7(3) clocked 113mph on one of my H9s the last warbird flyin. OS91
Spitfire, Hellcat, Corsair have all flown well with that combination. The TF 50 size Corsair however will get electrified...
Good flying wit ya today
Hide Signatures
       Post #: 280
RE: I Saw it! TF 60 Size Corsair ARF!!!!! - 2/10/2012 11:20 PM
iflircaircraft
Score: 123
Status: offline
it's a master airscrew 14x7. I painted the tips yellow. I'm hoping to maiden as soon as the weather cooperates
Tom
Hide Signatures
(in reply to da Rock)
       Post #: 281
RE: I Saw it! TF 60 Size Corsair ARF!!!!! - 2/10/2012 11:24 PM
iflircaircraft
Score: 123
Status: offline
A couple more pics
Tom
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 282
RE: I Saw it! TF 60 Size Corsair ARF!!!!! - 2/20/2012 12:32 PM
lablover
Score: 103
Status: offline
Anybody get theirs in the air yet. I would hate to see this thread die. Mine is ready but mother nature is gonna make me wait till spring!
Hide Signatures
       Post #: 283
RE: I Saw it! TF 60 Size Corsair ARF!!!!! - 2/20/2012 11:06 PM
iflircaircraft
Score: 123
Status: offline
I'm waiting on spring as well.
In the meantime I'm going to replace the Robart gear with E-flite elect gear. After a buddy of mine bought the H-9 50 Corsair with Elect gear I have to change over. The Robarts just don't seem as dependable after seeing and feeling the E-Flites.
I might drill new holes in the flange to mount the elect gear as opposed to adding rails as someone else has done.
Tom
PS: it's a $200 loss (the robarts being newly purchased) but to me ,money well spent.
< Message edited by iflircaircraft -- 2/21/2012 12:20 PM >
Hide Signatures
       Post #: 284
RE: I Saw it! TF 60 Size Corsair ARF!!!!! - 2/22/2012 4:08 PM
Brad-C
Score: 100
Last Login: 1/7/2013
Status: offline
I finally got mine done. At least the building part - still have to set throws and run the engine in a bit.
It came out to 9lb 6oz and balanced with no added weight with the DLE20. The E-Flite retracts should work fine with the weight being below their spec too.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 285
RE: I Saw it! TF 60 Size Corsair ARF!!!!! - 2/22/2012 9:33 PM
Lifer
Score: 153
Last Login: 6/19/2013
Status: offline
BradC,
The Master Airscrew 16x8x3 runs really fine on the DLE 20. Painting the tips yellow looks pretty good, too!
Hide Signatures
(in reply to Brad-C)
       Post #: 286
RE: I Saw it! TF 60 Size Corsair ARF!!!!! - 2/22/2012 11:21 PM
Brad-C
Score: 100
Status: offline
quote:
ORIGINAL: Lifer
BradC,
Cool, thanks for the info. I'll try it out. That's a XOAR 16x8 WWII prop on there now. I have a 17x8 as well. I would rather go with a 3 blade for looks but the cost for the XOAR was more than I was willing to do for the first flights until I know if it tends to nose over or not.
Hide Signatures
(in reply to Lifer)
       Post #: 287
RE: I Saw it! TF 60 Size Corsair ARF!!!!! - 2/23/2012 1:05 AM
iflircaircraft
Score: 123
Status: offline
Good job Brad!
Are those robart diamond tread wheels? I just ordered those with the robo struts. The gear doors add a nice touch.
I also have the E-flite retracts coming.
I don't foresee nose over tendencies with the 100 degree retracts.
Happy Flying
Tom
Hide Signatures
       Post #: 288
RE: I Saw it! TF 60 Size Corsair ARF!!!!! - 2/23/2012 1:32 AM
Brad-C
Score: 100
Status: offline
quote:
ORIGINAL: iflircaircraft
Good job Brad!
Happy Flying
Tom
Thanks.. Yeah, those are Robart wheels. They look better but also give more on landing than the stock ones so it's less likely to do the warbird bounce and stall trick.
Good luck with yours!
Hide Signatures
       Post #: 289
RE: I Saw it! TF 60 Size Corsair ARF!!!!! - 2/23/2012 9:42 AM
Kostas1
Score: 330
Status: offline
That's really nice Brad!!!
Will you capture the footage from the maiden flight;
<==**Check my gallery for more pictures**
Club Saito member #706
Hide Signatures
       Post #: 290
RE: I Saw it! TF 60 Size Corsair ARF!!!!! - 2/23/2012 4:36 PM
Brad-C
Score: 100
Status: offline
quote:
ORIGINAL: Kostas1
Thanks..
Yep, I'll post video when I maiden it.
Hide Signatures
(in reply to Kostas1)
       Post #: 291
RE: I Saw it! TF 60 Size Corsair ARF!!!!! - 2/25/2012 12:04 PM
iflircaircraft
Score: 123
Status: offline
Brad: I tried to PM you but to no avail. Is there a trick getting the strut from the retracts? I loosened the set screw but don't want to force anything.
I'm at the point of installing the Robo-struts but can't get the wire from the retracts.
Tom
Hide Signatures
       Post #: 292
RE: I Saw it! TF 60 Size Corsair ARF!!!!! - 2/25/2012 4:02 PM
Brad-C
Score: 100
Status: offline
Tom,
I went through the same thing on mine.
At the end of the strut there are actually 3 set screws to remove and then the collar will come off. The guide pin is one of them. Just grab that with vice grips and back it out. Once that's out, you will see there are two normal set screws on either side of where the pin goes in (rotate the strut to get to them). Once the end collar is off, pull the strut out and you'll see how the spring inside has ends that set in to small holes in both the retract housing and the spring side collar. Make sure you keep left and right straight on the spring as you will have to re-tension the strut in the right direction when you put it all back together.
I just got your PM this morning by the way.
Brad..
Hide Signatures
       Post #: 293
RE: I Saw it! TF 60 Size Corsair ARF!!!!! - 2/25/2012 10:41 PM
iflircaircraft
Score: 123
Status: offline
Thanks Brad.
Hide Signatures
       Post #: 294
RE: I Saw it! TF 60 Size Corsair ARF!!!!! - 2/27/2012 10:42 PM
Brad-C
Score: 100
Status: offline
I haven't flown it yet but here's a couple of videos of it running. I had it out to tune the engine so I taxied it around a few times. That JTEC muffler makes the DLE 20 sound really nice. Way better than the stock muffler which was louder and annoyingly raspy - in my opinion anyway.
http://www.youtube.com/watch?v=mbUQiCeTebA
http://www.youtube.com/watch?v=qaNNbGBcoTQ
Hide Signatures
       Post #: 295
RE: I Saw it! TF 60 Size Corsair ARF!!!!! - 3/1/2012 4:12 AM
scottrc
Score: 104
Status: offline
It looks like it handles really well on the ground and sounds like it will have plenty of power.
If you love your plane, set it free, if it doesn''t return, you should have checked the battery.
Hide Signatures
       Post #: 296
RE: I Saw it! TF 60 Size Corsair ARF!!!!! - 3/1/2012 4:13 AM
scottrc
Score: 104
Status: offline
I just ordered one of these tonight. Will be using a TT .75 and Robart 615s from and older Corsair along with the robostruts. I had good luck with them on the kit built version.
Hide Signatures
       Post #: 297
RE: I Saw it! TF 60 Size Corsair ARF!!!!! - 3/2/2012 5:09 PM
CorsairJock
Score: 110
Status: offline
What Size (diameter, width) Are the (Stock) Main Wheels?
Also, Please measure the wheel wells, to determine what is the largest diameter wheels that could work with them.
For the record: full scale Corsairs have wheels that are 32" diameter. Since these are 1/8 scale, the correct scale size would be 4" I know from experience that fitting 4" wheels into a '60 size' Top Flite Corsair is quite a challenge. But the recommended size is 3 1/4", which flat out appear to be way too small. I have found that 3 1/2" wheels offer a good compromise of scale looks and functionality.
< Message edited by CorsairJock -- 3/10/2012 12:56 AM >
Hide Signatures
(in reply to mimoore67)
       Post #: 298
RE: I Saw it! TF 60 Size Corsair ARF!!!!! - 3/2/2012 5:42 PM
Brad-C
Score: 100
Status: offline
Pretty sure I bought 3.5" when I changed out the stock wheels. I can verify when I get home.
Hide Signatures
       Post #: 299
RE: I Saw it! TF 60 Size Corsair ARF!!!!! - 3/2/2012 9:24 PM
scottrc
Score: 104
Status: offline
I had Robart 3.5" on my last Corsair and they looked small, then again these were the smooth tread. The diamond, which I have on the Mustang, seem to have a smaller hub,
Hide Signatures
       Post #: 300
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.655RCU1
