quikee jett
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Jett Engineering Support >> quikee jett
Page: [1]
Login
quikee jett - 8/11/2003 7:19:59 AM
sean mercer
Status: offline
Hi,
I bought a used q-jett here on rcu and the bearings are seeld. Is this normal for the q-jett as my sj 40's have the bearings totaly open? Also,when I tighten up the prop the crankshaft won't turn anymore. Help! sean
_____________________________
Low and fast is a blast!
       Post #: 1
quikee jett - 8/11/2003 5:41:58 PM
bob27s
Status: online
Hi Sean.....
Thanks for writing.
The rear bearing is never sealed. The front bearings are usually not sealed, especially on the Q-500 engines...front bearing lubrication is critical. Although Dub has provided sealed front bearings on special requests, on a few sport engines.
Sounds like the bearings had been replace along the way. If they are not the correct size, when you tighten down on the crank shaft, you may excessively preload the bearings preventing them from turning.
Considering it will not turn with the prop and drive washer installed, something may have been misaligned along the way too. It would be worth while shipping the engine back to Dub for inspection and a new set of bearings. Address is on the web site [url]www.jettengineering.com[/url]
Bob Brassell
(in reply to sean mercer)
       Post #: 2
quikee jett - 8/12/2003 5:29:14 AM
sean mercer
Status: offline
Bob,
I put the case in the oven and popped the bearings out. WOW! The rear bearing was froze solid from rust and it was sealed. Lucky I have bearing sets laying around for my SJ 40'S. Thanks for the help. sean
       Post #: 3
quikee jett - 8/12/2003 5:21:06 PM
bob27s
Status: online
Wow......... glad you checked.
Bearing change is easy enough.
Let me know how you make out
Bob
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.516RCU1
