CGRetired
Score: 221 Joined: 9/14/2004 Last Login: 5/24/2013 From: Galloway, NJ, USA Status: online
You said a biggie there, Kiwibob. A 60 size trainer is not a warbird. Kyle: You may consider buying and building a warbird, which is ok, but build it and put it aside for a while. I would highly recommend that you at least get something that gives some stick time with a timid, mild mannered type plane. With your experience, you already know the difference between right and left... meaning the AIRCRAFT right and left, which can be the hardest concept for someone new into flying can overcome. You probably already know what I mean, but for those of you that do not (real beginners), when flying an RC aircraft, you stand at a fixed position on the ground, and fly something that is in the air. You have to consider that whatever you do with the controls, works with the plane, not the pilot. For instance, if it's coming toward you, well, if you want to turn right, well, is your right or the plane's right? Of course, it's the plane's right, but it moves to YOUR LEFT... from your vantage point on the ground. Flying away from you is easy because both are the same. If the plane is moving across in front of you, one moment it is coming toward you and as it passes by, it is now going away from you. Ok..ok..enough of that basic skills stuff, but it supports my point, and may help others understand that trying to do it on their own may not be a good choice. I will admit that some have succeeded, but at what cost? Kyle, you already know the difference I am talking about here, so that level is something that you do not need to focus on, so one less load on your brain to overcome. The next would be speed, followed by approach and landing, not to mention emergency procedures.. you can't autorotate, for instance, with a fixed wing. If it were me, I would opt for something like a Tiger 60 or Four Star 60 as your starting aircraft, and fly your first couple of flights with an instructor on a buddy box. You will quickly get the idea and move to solo almost right away. But, this type of aircraft will do wonders for you in your learning curve with fixed wing aircraft, and will go pretty far to prime you to fly something that is very unforgiving, such as a warbird. Consider it, is all I ask. CGr.
< Message edited by CGRetired -- 4/7/2011 12:54 PM >
_____________________________
Skylark 70 - OS .75 AX; Excelleron 90 - OS 1.20 AX; Venus II - OS 1.20 AX; And, I still fly my trainer, Hanger 9 Alpha - OS .46 FX! Some electrics. Airtronics RD8000 - Spektrum DX7 - DX6i. AMA 705964. Semper Paratus!
Hide Signatures
