Severe glitching problem with new Lynx 3D?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> Severe glitching problem with new Lynx 3D?
Page: [1]
Login
Severe glitching problem with new Lynx 3D? - 8/11/2003 1:43:49 PM
DanielT
Status: offline
OK, I'm just getting into this hobby, so please bear with me. Or, more accurately, I purchased all the parts needed for my first RC nitro car (a Thunder Tiger EB-4) nearly two years ago and am just finally getting around to finishing building it. I originally did most of the construction back then, but then hit a snag with the engine and clutch, and everything has been on hold since.
Anyways, to make a long story short I finally worked out the snag and have just finished getting the car built this weekend. So, tonight I decided to wire up the servos and get everything adjusted.
However, after charging my sort-of new Lynx 3D (previously never removed from the box), I discovered a problem: severe glitching whenever I try to use the transmitter. I'll try to list the symptoms:
* Nitro engine hasn't even been started yet, so no vibration or metal-on-metal problems. Can't find any grounding problems, antenna is straight and not touching anything, etc. The radio came with channel 83.
* With car powered on but radio off, no problems.
* Connected directly via DSC everything works as expected.
* As soon as I turn the radio on everything initially seems good, until I try to do something.
* I can make one motion slowly without too much chance of glitching: brakes.
* Any other motions, like steering or throttle, causes the servo to start to move correctly, but then *both* servos start glitching badly, moving randomly back and forth, until I stop the motion and sometimes for 5 seconds afterwards.
* If I try doing brakes quite quickly (on/off/on/off) even that will start everything glitching.
* I've tried switching to a different model memory and resetting the memory (per magazine article), but no luck.
Any idea what might be causing this? Receiver, transmitter, interferance on that channel? Thinking it might be a problem with all the computer equipment in this room I already moved the car a hundred feet away and still have the issue.
Needless to say this is distressing!
       Post #: 1
Severe glitching problem with new Lynx 3D? - 8/12/2003 1:23:21 AM
MikeMayberry
Status: offline
I would suggest you give us a call @ (858) 748-6948 and we can try to help figure it out. It's too difficult to do it over the forum.
Mike.
(in reply to DanielT)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.281RCU1
