RE: Setup Tips for your MCPX    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> RE: Setup Tips for your MCPX
Page: <<   < prev  1 [2]
Login
RE: Setup Tips for your MCPX - 9/4/2011 3:50 PM
turboomni
Score: 100
Last Login: 12/30/2012
Status: offline
Quote:Normal Mode
Throttle curve - 0 40 60 80 100
Pitch Curve 30 45 70 85 100
Idle Up
Throttle curve - 100 100 100 100 100
Pitch Curve - 0 30 70 85 100 Quote
May I as why you don't run a linear pitch curve so when either upright or inverted you will be the same amount away from mid stick?
I run 0 to 100% linear with midstick always at 0 pitch on all my heli's in all modes in my big gasser heli's but in normal modes on my electrics my collective curve is still 0 degrees at mid stick with something like 35-40-50-75-100. All stunt modes are linear . That way when upright or inverted it is the same amount away from mid stick.
< Message edited by turboomni -- 9/4/2011 5:24 PM >
Hide Signatures
(in reply to Gairlochan)
       Post #: 26
RE: Setup Tips for your MCPX - 9/22/2011 10:26 AM
chrig
Score: 100
Last Login: 9/22/2011
Status: offline
Where should be 0 pitch. Stick in middle position?
Hide Signatures
(in reply to Rob2160)
       Post #: 27
RE: Setup Tips for your MCPX - 9/23/2011 12:49 AM
warp
Score: 100
Last Login: 11/6/2011
Status: offline
 Hi Rob
  Thnaks for all the tips tricks and vids you put out man!
Im very noob at r/c CP hellis. I'm a bit concerned about knowing if i have set up my mCPx properly. i have the Dx6i radio with it.
my question is, when im spinning up the helli sometimes leans to one side, or even nose down, sometimes tail down. never consistant.
is this normal? of cause when my un-skilled fingers get it together i can get the little guy straightend out. but no always often i end up chopping up the lawn
Hide Signatures
       Post #: 28
RE: Setup Tips for your MCPX - 9/27/2011 6:58 PM
srt10
Score: 318
Last Login: 5/21/2013
Status: offline
Rob, I'm going to have to try out your settings in my DX6i when I get home from work today...
_____________________________
first to own the Mini Slash!
Amsoil Dealer.. 6XL Revo, Baja 5B, Losi8T, PS295, UL-1, AQ MC, OM29, DF33
Hide Signatures
(in reply to warp)
       Post #: 29
RE: Setup Tips for your MCPX - 12/15/2011 1:31 AM
Doug Brindle
Score: 100
Last Login: 12/17/2011
Status: offline
Guys,
The book says to set the TRAVEL ADJUST for PITCH at 75%. On the DX6i radio, is that value set with the stick pulled down (down arrow showing on the screen) or with the stick pushed up (up-arrow showing on the screen).
In my setup, in NORM mode, while hovering, my pitch/throttle stick is pushed up nearly to it's limit. And, it's very sensitive. Just a micro-adjustment on the pitch-throttle stick is a dramatic difference.
Hide Signatures
       Post #: 30
RE: Setup Tips for your MCPX - 1/23/2012 1:04 AM
srt10
Score: 318
Status: offline
can someone explain how or what this means for pitch to be set around 70% for Justin's MCPx?
thank you!
http://www.youtube.com/watch?v=e4D9UXkp_dU&feature=player_embedded#!
Hide Signatures
(in reply to Doug Brindle)
       Post #: 31
RE: Setup Tips for your MCPX - 1/24/2012 11:40 PM
madmorgan
Score: 100
Last Login: 12/27/2012
Status: offline
its hard to say srt10 i would guess hes at 70% max pitch on throttle or set the end points to 70 % which doug above you mentions and your answer doug would be set at 75% on both arrows so with heli off left stick all the way down set to 75 then move all the way up and adjust to 75 all they really say is the coll and pitch sould nt be used on max for both so they prob set theirs to 70 instead of 75 .
if you dont know you better ask somebody ! usarmy active 1989-1997, 1990 desert sheild /desert storm, 1993 somolia .
Hide Signatures
(in reply to srt10)
       Post #: 32
RE: Setup Tips for your MCPX - 1/25/2012 12:04 AM
srt10
Score: 318
Status: offline
quote:
ORIGINAL: madmorgan
Ok, I'm new to this stuff
so basically back off from max stick in both directions?
Hide Signatures
(in reply to madmorgan)
       Post #: 33
RE: Setup Tips for your MCPX - 2/25/2012 7:29 AM
earpopper
Score: 100
Last Login: 2/25/2012
Status: offline
Hey guys,
I just recently bought a MCPX and I am having a hell of a time just trying to get it off the ground. Whenever I add throttle the blades begin to vibrate violently and the heli gets pretty erratic. It spools up fine, but the moment I add enough throttle to life of the ground it just goes crazy.  Anyone else have this issue? Any suggestions?
Chris
Hide Signatures
(in reply to srt10)
       Post #: 34
RE: Setup Tips for your MCPX - 2/25/2012 7:40 AM
srt10
Score: 318
Status: offline
check to make sure the main gear is tight on the shaft
Hide Signatures
(in reply to earpopper)
       Post #: 35
RE: Setup Tips for your MCPX - 2/25/2012 5:21 PM
madmorgan
Score: 100
Status: offline
ok i have no idea what the others flying abilities are i am no expert but do yourself a favor especially the new guys in this  and set you tx up per eflight ok i set mine up like eflight suggests and i have no issues with it at all ! maybe these other guys have been reading around and seeing what the pros settings are AND HOW THEY LIKE TO FLY notice i said how they like to fly and posting it around in forums which is bs cuz they r probably noobs themselves i emphasis on that because they have probably been flying for 20 years and they know what they like . now after you have mastered these things then you can start playing with settings and see what affects what and set it up to your likings .so heres a thing to try esp warp who posted and i know i said this  on first page SLOWLY MOVE YOUR LEFT STICK UP TRYING NOT TO HAVE ANY INPUT LEFT OR RIGHT TO CONTROL THE TAIL IF YOU SEE ITS STARTING TO LEAN SLOWLY ADJUST ON YOUR RIGHT STICK UNTIL EVERYTHING IS NICE AND LEVEL THEN PROCEED TO INCREASE LEFT STICK UNTIL SKIDS LIFT OFF FLOOR I SWEAR I CAN LIFT MINE OFF THE FLOOR 4 INCHES OFF AND TAKE MY HANDS OFF THE TX FOR 5 OR 6 SECONDS BEFORE IT STARTS TO MOVE IN ANY DIRECTION. i think some of you are just raising the left stick so fast and because the servos do not recenter and if you crash and pick bird up inspect it every time you tilt it the controller is imputting to servos .so take it for what its worth you can try what i suggest or not. if your having head vibrations try the grommet mod to the swash it works great and check your main gear  or get a microheli aluminum and be done with that.
Hide Signatures
(in reply to srt10)
       Post #: 36
RE: Setup Tips for your MCPX - 2/25/2012 5:58 PM
madmorgan
Score: 100
Status: offline
ok guys just watched his video hes working with a dx8 i believe hes talking about your travel adjust in the pitch so hes basically saying turn on your dx6 get into travel adjust highlight pitch you will see 100% on a new setup with arrow pointing down or left stick all the way down set it to 70% then move the stick up and you will see arrow  point up now and its at 100 % adjust this to 74 %  then exit out  eflight has this set to 75 %  i have mine set at 100 % lol but there again i have swash type set 3 servo 120 degree not 1 servo 90 degree with all -80 in the wash mix  im going to make new per eflight and see what happens.
Hide Signatures
       Post #: 37
RE: Setup Tips for your MCPX - 2/26/2012 1:53 AM
madmorgan
Score: 100
Status: offline
went to spool it up and the thing flopped over didnt do preflight come to find out the gear on my ail servo fell off thats a new 1 i guess
Hide Signatures
       Post #: 38
RE: Setup Tips for your MCPX - 3/14/2012 1:25 AM
fleetz
Score: 100
Last Login: 9/10/2012
Status: offline
Hi Rob,
Hope you are travelling well.
No hurry as the MCPX (V2) is on order and I won't get to the MCPX for a while. Just wondering if the V2 version MCPX would have the same settings you have recommended and the link tweak to increse the pitch?
Cheers,
Ian
Hide Signatures
       Post #: 39
RE: Setup Tips for your MCPX - 3/14/2012 1:26 AM
fleetz
Score: 100
Status: offline
Hi Rob,
Cheers,
Ian
Hide Signatures
       Post #: 40
RE: Setup Tips for your MCPX - 3/14/2012 1:32 AM
fleetz
Score: 100
Status: offline
Hi Rob,
Cheers,
Ian
Hide Signatures
       Post #: 41
RE: Setup Tips for your MCPX - 3/28/2012 5:52 PM
syzygy
Score: 100
Last Login: 7/19/2012
Status: offline
Straight to the point key TX tweaks.
One video showing steady hover indoors.
One video showing inverted flight with control outdoors.
You've demonstrated that getting the pitch setting right and tweaking those curves as mentioned in your video can produce a stable hovering mcpx.  As every heli guy knows, once you've got steady hover, the rest follows in natural order.
Just what I needed to see.  Now I may finally cut the seals on my new DX6i and mcpx boxes (I've been dreading the learning curve).
Thanks!
Edit: I've opened the DX6i and mcpx v2 and have configured the TX and bound the heli.  I can confirm that the mcpx v2 has the same factory negative pitch condition requiring Rob's 720 degree linkage adjustment as described in his video.  To see the negative pitch, bind the heli on a level surface and then immediately disconnect the TX and the battery on the heli.
Thanks again Rob!  You have supplied a valuable service (right around to the opposite side of the globe)!
< Message edited by syzygy -- 3/29/2012 12:15 AM >
Hide Signatures
       Post #: 42
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.531RCU1
