50cc throttle problem    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Giant Scale Cars >> 50cc throttle problem Page: [1]
Login
50cc throttle problem - 4/10/2011 3:30 PM
vugt47
Score: 100
Last Login: 12/6/2012
Status: offline
i need a servo that will be strong enough to pull the throttle on a 50cc pocket bike engine http://www.minibikepartsnow.com/MPBN%20Pics/Engine49cc/eg49cc1.jpg. would two 1/10 scale servos work if i gave it enough leverage, or what if i used a spring to assist the servo? Is there just a reg servo that is strong enough? Ive seen the wiper motor servos but i dont understand how they are wired with a reg servo as the sensor. If you know how to wire one and could explain it to me or post a pic that would be absolutely amazing!
Please reply!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1
RE: 50cc throttle problem - 4/10/2011 11:27 PM
Lars from Norway
Score: 155
Last Login: 5/24/2013
Status: offline
Wow! Wiper motor? It is enough with a servo on about 6 kg as the arm is very easy to turn on the carb. Not much force needed to move it. The wiper motors that you have read about are for steering servos on really large cars.
_____________________________
Find a job you love, then you won''t have to work for the rest of your life.
Hide Signatures
(in reply to vugt47)
       Post #: 2
RE: 50cc throttle problem - 4/11/2011 7:54 AM
rangerfredbob
Score: 115
Last Login: 5/23/2013
Status: offline
it looks like that engine has a mikuni type carb on it they're a little harder to move, for $30 you could get an appropriately sized servo HERE and not have to make anything custom...
Hide Signatures
(in reply to Lars from Norway)
       Post #: 3
RE: 50cc throttle problem - 4/11/2011 9:04 PM
Rallyfinnen
Score: 100
Last Login: 5/16/2013
Status: offline
Replace the carb with a good walbro! It will be easier to tune, and you can use a standard servo.
The walbro can suck the fuel from the tank, with that one the tank needs to be higher than the carb.
Hide Signatures
(in reply to rangerfredbob)
       Post #: 4
RE: 50cc throttle problem - 4/11/2011 10:59 PM
Lars from Norway
Score: 155
Status: offline
rangerfredbob; i overlooked that part, i know from my time driving my moped that moving the "piston" up and down inside the carb is kind of heavy compared to twist the axle in a Walbro.
Hide Signatures
(in reply to Rallyfinnen)
       Post #: 5
RE: 50cc throttle problem - 4/13/2011 3:11 AM
vugt47
Score: 100
Status: offline
ye it might just my motor has a hard throttle but it take quite a bit of force to pull it, one on my servos from my 1/10 rc cant do it.
Hide Signatures
       Post #: 6
RE: 50cc throttle problem - 4/13/2011 3:12 AM
vugt47
Score: 100
Status: offline
thanks you for the advice i hope it will help
Hide Signatures
       Post #: 7
RE: 50cc throttle problem - 4/25/2011 5:26 PM
kenazzo2000
Score: 100
Last Login: 12/29/2012
Status: offline
use a 25 kilo servo like i will be using
Hide Signatures
       Post #: 8
RE: 50cc throttle problem - 4/27/2011 2:23 AM
da mad maori
Score: 100
Last Login: 4/28/2013
Status: offline
quote:
ORIGINAL: Lars from Norway
rangerfredbob; i overlooked that part, i know from my time driving my moped that moving the ''piston'' up and down inside the carb is kind of heavy compared to twist the axle in a Walbro.
+1
or replace the cable/spring with a solid wire and no spring
Hide Signatures
       Post #: 9
RE: 50cc throttle problem - 4/27/2011 11:39 PM
Lars from Norway
Score: 155
Status: offline
That is a very good idea, mad maori! To move the piston itself without the spring attatched is done with little or none effort, so just using a solid rod to move it can be done by almost any servo.
Hide Signatures
(in reply to da mad maori)
       Post #: 10
RE: 50cc throttle problem - 5/15/2011 1:57 AM
vugt47
Score: 100
Status: offline
Could anyone show me a pic or something of a servo and a wiper motor working together. I'm not too good with reading the diagrams so I need to see the actual thing, or explain how to wire it. Thanks
Hide Signatures
       Post #: 11
RE: 50cc throttle problem - 5/15/2011 3:51 AM
tonystott
Score: 100
Last Login: 2/19/2012
Status: offline
Just get a Hobbyking HV767
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9983
30kg/cm torque is way more than you could ever need
Hide Signatures
       Post #: 12
RE: 50cc throttle problem - 5/17/2011 12:16 AM
vugt47
Score: 100
Status: offline
so with this walbro carb, how is the gas tank going to work, would i have to just have a hose go to the bottom and a vent on it, or would i need to creat pressure, possibly with the exhaust? how exactly would the whole fueling system work?
Hide Signatures
(in reply to tonystott)
       Post #: 13
RE: 50cc throttle problem - 5/17/2011 10:40 PM
Lars from Norway
Score: 155
Status: offline
The Walbro-carb feeds itself with fuel, this is done via pulses from the crankcase. You will need a hose with a filter on to feed the carb (a clunk in the tank with filter on), and a hose to return the fuel to the tank. And also some sort of ventilation in the tank. No need to create pressure to make it feed from the tank.
Hide Signatures
       Post #: 14
RE: 50cc throttle problem - 5/17/2011 11:43 PM
vugt47
Score: 100
Status: offline
oh ok i get, thanks i will be getting one shortly
Hide Signatures
       Post #: 15
RE: 50cc throttle problem - 5/18/2011 2:18 AM
vugt47
Score: 100
Status: offline
ive been trying to find a clunk for in the tank but i cant find any, also what size hose does the walbro carb need, it doesnt say what the ID of the hose needs to be. this is the one i am looking to buy[image][/image][image][/image][image][/image]
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 16
RE: 50cc throttle problem - 5/18/2011 2:35 AM
proanti1
Score: 341
Last Login: 1/6/2013
Status: offline
Whats wrong with this clunk?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXXF25&P=ML
Her name was Lola. She was a show girl.
Hide Signatures
       Post #: 17
RE: 50cc throttle problem - 5/18/2011 3:14 AM
vugt47
Score: 100
Status: offline
i was trying to find one with more of a filter on it
Hide Signatures
(in reply to proanti1)
       Post #: 18
RE: 50cc throttle problem - 5/22/2011 9:32 PM
Fabe
Score: 100
Last Login: 12/10/2011
Status: offline
One of these should do the trick:
http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.2632/.f
http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.2560/.f
Daves will also have standard fuel line for the carbs if you don't find any...
Hide Signatures
       Post #: 19
RE: 50cc throttle problem - 5/23/2011 6:53 PM
kenazzo2000
Score: 100
Status: offline
ive bought one like yours and started the engine if you wont i can give you the site were i bought it from
Hide Signatures
(in reply to Fabe)
       Post #: 20
RE: 50cc throttle problem - 5/24/2011 2:00 AM
vugt47
Score: 100
Status: offline
that looks great on there, i already found a suitable website for me though, but thanks a lot.
Hide Signatures
(in reply to kenazzo2000)
       Post #: 21
RE: 50cc throttle problem - 5/24/2011 2:42 AM
vugt47
Score: 100
Status: offline
could you tell me what the inside diameter of the hos is that is required for the walbro carb?
Hide Signatures
       Post #: 22
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.596RCU1
