RE: My Aftershock 8E Build thread.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: My Aftershock 8E Build thread.
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: My Aftershock 8E Build thread. - 4/23/2011 7:42 PM
nitrosportsandrunner
Score: 296
Last Login: 6/20/2013
Status: offline
those rims look really nice.
i wanna know how you are coming on those servo saver mods?
i plan on doing some modding of the servo saver on my earthquake 8e, just havent found the time yet.
_____________________________
SC10 brushless, Thunder Tiger Phoenix XB Brushless, 1/5 custom rock crawler, Slash 4x4, Atomik Barbwire
Hide Signatures
(in reply to All-or-Nothing)
       Post #: 26
RE: My Aftershock 8E Build thread. - 4/23/2011 11:55 PM
JTuepker1
Score: 100
Last Login: 2/3/2012
Status: offline
http://www.youtube.com/watch?v=HNJy7kreK90
video on how to set rebound on your truck more. I did it to my backdraft, works likes a charm.
Hide Signatures
(in reply to nitrosportsandrunner)
       Post #: 27
RE: My Aftershock 8E Build thread. - 4/24/2011 4:28 AM
All-or-Nothing
Score: 100
Last Login: 2/12/2012
Status: offline
quote:
ORIGINAL: nitrosportsandrunner
Waiting for the Servo Saver to come in. Should be Monday or Tuesday. Debating whether to just take the bushings to the LHS or just order a bearing kit for some Mini Rc and hope I get a hit.
I should probably just measure them and see what I can find on Bocabearings.com or some other bearing site.
Aftershock 8e, Earthquake 3.5
Serpent 811, Kyosho MP9
Hide Signatures
       Post #: 28
RE: My Aftershock 8E Build thread. - 4/24/2011 7:01 AM
masterhacker1989
Score: 115
Last Login: 6/14/2013
Status: offline
I know what size they are
5x8x2.5mm you can use traxxas part #2728
I was going to go pick up some bearings, but I got lazy and didnt when I last had my earthquake apart
Traxxas Tmaxx 3.3-WAAAAAY to much done to list
Redcat Earthquake 8E-Completly stock
Hide Signatures
       Post #: 29
RE: My Aftershock 8E Build thread. - 4/24/2011 7:04 AM
masterhacker1989
Score: 115
Status: offline
Heres the ones I'm planning on getting tin the near future:
http://www.rc-bearings.com/catalog/product_info.php?products_id=860
Hide Signatures
(in reply to masterhacker1989)
       Post #: 30
RE: My Aftershock 8E Build thread. - 4/24/2011 10:22 AM
masterhacker1989
Score: 115
Status: offline
I stole the bearing out of my Tmaxx steering and went to install them on my earthquake, and I found that I has to sand down the shaft that the bell cranks mount on to get them to go on nicely, it seems the shafts are a hair bigger than the bearings inner hole, I think its just because they didnt do a good checking them before they left the factory, because the bearings slipped on one end with no problem, but the other 3 I had to sand, some more than others. It did get rid of a whole bunch of slop in the steering by installing ball bearings, I recomend that everyone do this
Hide Signatures
       Post #: 31
RE: My Aftershock 8E Build thread. - 4/24/2011 11:17 AM
All-or-Nothing
Score: 100
Status: offline
quote:
ORIGINAL: masterhacker1989
This is great news. I am hoping that the Aluminum Servo Saver gets rid of even more slop along with the addition of the bearings.
Great work Masterhacker1989
Hide Signatures
       Post #: 32
RE: My Aftershock 8E Build thread. - 4/25/2011 7:05 AM
All-or-Nothing
Score: 100
Status: offline
More goodies.....
When I went to pop it on the motor it wouldn't sit flush so immediately I thought I would have to trim it somehow. Fortunately it was just hitting the plastic piece that goes over the center diff. (Put the dremel away now).
Here is where it was hitting.
So I just liffted the plastic piece and it popped right into place.
Hide Signatures
       Post #: 33
RE: My Aftershock 8E Build thread. - 4/25/2011 8:22 AM
masterhacker1989
Score: 115
Status: offline
Lemme know how that heat sink works, im having heat issues with my earthquake. Also is that the heat sink redcat sells?
Hide Signatures
       Post #: 34
RE: My Aftershock 8E Build thread. - 4/25/2011 9:50 AM
All-or-Nothing
Score: 100
Status: offline
Yes it's the Redcat HeatSink and Fan. I think it should work pretty well but I will let you know.
Hide Signatures
       Post #: 35
RE: My Aftershock 8E Build thread. - 4/26/2011 2:31 PM
All-or-Nothing
Score: 100
Status: offline
Woo Hoo....................more goodies
Hide Signatures
       Post #: 36
RE: My Aftershock 8E Build thread. - 4/27/2011 4:16 AM
masterhacker1989
Score: 115
Status: offline
Ooh nice, be careful with the bearing puller though, I screwed up the crank on my tmaxx pulling off the flywheel with a bearing puller, it chipped the end where a snap ring held on the clutch, luckily i was able to make it work by using a screw instead of a snap ring. I was going to buy one of those "setup" things, but I thought about it, and i can get my Rc's handling pretty good just by eying stuff up, plus I just run them in my backyard, or a grave pit anyways, So it doesnt really pay for me to get one
Hide Signatures
       Post #: 37
RE: My Aftershock 8E Build thread. - 4/27/2011 4:30 AM
All-or-Nothing
Score: 100
Status: offline
Ooh nice, be careful with the bearing puller though, I screwed up the crank on my tmaxx pulling off the flywheel with a bearing puller, it chipped the end where a snap ring held on the clutch, luckily i was able to make it work by using a screw instead of a snap ring. I was going to buy one of those ''setup'' things, but I thought about it, and i can get my Rc's handling pretty good just by eying stuff up, plus I just run them in my backyard, or a grave pit anyways, So it doesnt really pay for me to get one
I mostly use the Set-Up rig for my Serpent and Kyosho MP9 but I am going to be using it on the Aftershock to get it dialed a little more.
Hide Signatures
       Post #: 38
RE: My Aftershock 8E Build thread. - 4/27/2011 2:29 PM
All-or-Nothing
Score: 100
Status: offline
Got another delivery today.........
Hide Signatures
       Post #: 39
RE: My Aftershock 8E Build thread. - 4/27/2011 4:12 PM
JTuepker1
Score: 100
Status: offline
Nice radio, got one myself use it for my redcat buggy, will be using for my new caster buggy when it arrives. Easy setup and love the display easy to read.
Hide Signatures
       Post #: 40
RE: My Aftershock 8E Build thread. - 4/27/2011 5:11 PM
masterhacker1989
Score: 115
Status: offline
Ive tried to order one of those radios twice now, from 2 different places, and both times it said they were in stock, and i ordered them, waited 2 weeks,saw that it hadn't shipped, then had them refund my money, I guess im not supposed to have one...
Hide Signatures
(in reply to JTuepker1)
       Post #: 41
RE: My Aftershock 8E Build thread. - 4/28/2011 5:31 AM
All-or-Nothing
Score: 100
Status: offline
So far this is what I have into the truck...
Aftershock 8E $209 with free shipping
Heat Sink $7
Fan $9
AKA Rims (17MM SET OF 4) $20
JConcepts Goosebumps (Set of 4) $36
45 Weight Shock Oil $4
40 Weight Shock oil $4
Diff Oil $10
12MM to 17MM adapters $15
New High Torque Servo $12
These are all things that anyone racing their trucks would purchase besides maybe the hub adapters. All in right now I have $326 including the truck's price.
All the the Toe-In and Camber adjustments were done with my Hudy 1/8 Set-Up Station. This truck runs just as fast as any of the other "Big Name Brand" trucks at our track and as I get more practice I see many wins in the future. I am running the stock batteries and they have plenty punch almost too much in some of the turns and technical parts.
Gonna hit the track this afternoon and have better details on how it handles and more settings. I do need to go with harder springs to smooth out the landings more but I don't know how that will affect the handling. Anyways I will report here how it does.
Hide Signatures
       Post #: 42
RE: My Aftershock 8E Build thread. - 4/28/2011 6:16 AM
Goatcrapp
Score: 100
Last Login: 5/23/2013
Status: offline
get a program card.  I found that the punch overpowered the chassis/driveline too much as well, and lowered it a bit..  I also changed the timing a bit, and i gotta say, it really woke up the aftershock.. smoother all around, without the fine line between in and out of control it had before...
as for shocks - being a mostly-basher myself, i decided to try my old MGT springs and shocks.  I wouldn't say to use these specifically - they needed rigging to fit, and still weren't optimal, but the added shock travel was a godsend for landings in this SC truck. Something to look into perhaps.
Hide Signatures
       Post #: 43
RE: My Aftershock 8E Build thread. - 4/28/2011 12:59 PM
electricrc68
Score: 143
Last Login: 8/2/2011
Status: offline
how do you have all this money!!!!! i wish i did.
Parkzone Ember 2
Hide Signatures
(in reply to Goatcrapp)
       Post #: 44
RE: My Aftershock 8E Build thread. - 4/28/2011 3:30 PM
JTuepker1
Score: 100
Status: offline
Its called a job.
quote:
ORIGINAL: electricrc68
Hide Signatures
(in reply to electricrc68)
       Post #: 45
RE: My Aftershock 8E Build thread. - 4/28/2011 4:14 PM
brew99
Score: 100
Last Login: 7/19/2011
Status: offline
quote:
ORIGINAL: All-or-Nothing
Heat Sink $7
Fan $9
Diff Oil $10
How did you get the truck for $209?   wasn't it $289?
Hide Signatures
       Post #: 46
RE: My Aftershock 8E Build thread. - 4/28/2011 11:26 PM
All-or-Nothing
Score: 100
Status: offline
I bought it on Amazon. Maybe the store wasn't selling and they were getting rid of their last stock. I don't know but it was too good to pass up.
Hide Signatures
(in reply to brew99)
       Post #: 47
RE: My Aftershock 8E Build thread. - 4/28/2011 11:57 PM
electricrc68
Score: 143
Status: offline
quote:
ORIGINAL: JTuepker1
Its called a job.
i don't have a job yet. im only 14.
Parkzone Ember 2
Hide Signatures
       Post #: 48
RE: My Aftershock 8E Build thread. - 4/29/2011 12:03 AM
brew99
Score: 100
Status: offline
Wow, good score on that one!!   Just to let you know, I'm appreciating your thread and regular updates of the aftershock.   I have one too, and have upgraded the steering arm, C Hubs, stainless screws, and fr/rr suspension mounts.   This thing is almost to fast, and i think I'm gonna try to lower the punch as it is hard to keep control from starts.
Hide Signatures
       Post #: 49
RE: My Aftershock 8E Build thread. - 4/29/2011 1:14 AM
Goatcrapp
Score: 100
Status: offline
14 is a tough age...  old enough where you can't be completely reliant on your parents for liesure items...  but not old enough to work (in some states) or be taken seriously.
Set goals for yourself.  If you want something - price it.. and set your goal.  Shop wisely...  don't bother with the big dollar items that make only the smallest differences.
Then figure out ways to earn some extra cash.  Obviously - neighborhoods have changed since i was that age..  so this may not be possible for you, but I used to hit up my neighbors for grocery runs..  a couple of bukcs here and there for each trip i made on their behalf..  the standard lawn mowing, garbage, yrd organizing, etc etc jobs..   also stock up on chores..   see if your parents will chip in a little extra if you take on a heavier chore load.  On the flip side - at your age chores are typically free..  ie:  you're expected to earn a small fraction of your keep.
If you're good in school - you can do some tutoring.
Whats a current fad?  I made the most moeny at that age by selling the various trading cards that were hot - marvel comics cards (the holograms lol) - magic, the gathering, etc.   I'm completely out of touch with what's in phase right now, so you'd have to be the best judge.
Its a tough age..   i remember, lol.   money definitely didn't come easy..   or not easy either..   it just wasn't there.
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.938RCU1
