203_morris
Score: 100 Joined: 1/17/2010 Last Login: 5/26/2011 From: southbury ,
CT, USA Status: offline
one of the best hatch covers is called a dorade box check out rough drawing....its pretty simple,build a box with no cover or bottom just the sides glue it to the deck ...next build another box with only sides and cover...build it so it fits snug over the box frame that is glued to the deck ,, glue foam to top inside cover,,can hold in place with small ss screws ,,these dorade boxe's have been used on real sailboats for years, and work very well,,as for the size thats up to you, you don't want it to high and you don't want it heavey,balsa wood works great if you seal it with fiber glass resin one coat,, makes it lite and very strong,,, I am still working on my boat,, it is all glassed ,and sanded, but I am working on the hatch myself, trying to make it water proof but yet easy on and easy off,, sleepless nights , as soon as I figure it out I will send you a photo,should be in the next couple of days,, or you can always make a flat hatch cover out of lite weight aluminum and screw it down be sure to glue foam on the bottom of the cover,,this works but it has to be screwed down ,,I havent had much luck with this type of cover unless you use quite a few screws,,and your deck needs to be super smooth,,,well hope this helps,, your boat is looking realy good,,,can't wait to see it finished,any problems or you get stuck just leave me a note on site I check in almost every day looking for idears ,
Hide Signatures
