Need help balancing my Funtana    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Questions and Answers >> Need help balancing my Funtana
Page: [1]
Login
Need help balancing my Funtana - 4/22/2011 8:51 PM
nauticom
Score: 100
Last Login: 5/23/2013
Status: offline
All:
Recently I purchased a used Funtana from a lhs. The Funtana has a ws of 72"
It has an Zenoh G26 up front. The on-line manual says to CG balance it at 6 3/8 to 6 3/4" from the leading edge at the fus.
When done at this distance, it is extremely nose heavy.
One of my questions, as this my first gas powered plane. Can I locate the ignition battery way back in the fus without creating noise issues
with the receiver/servos? I will be using a JR 9303 2.4 receiver.
Also does anyone know if there have been any rev's to the CG point?
_____________________________
Bob Masterson
Corsair Brotherhood # 60
Hide Signatures
       Post #: 1
RE: Need help balancing my Funtana - 4/22/2011 10:18 PM
scooterinvegas
Score: 141
Last Login: 7/7/2012
Status: offline
You can mount both batteries in the tail if you want. You can also move you gas tank to the cg under the wing. That should help. If you still need tail weight, you can mount your servos in the tail.
I have two gassers with the servos in the tail. Works for me.
Maybe I should just take rubbing alcohol with me to the field and rub the props down before starting any of my planes!
Hide Signatures
(in reply to nauticom)
       Post #: 2
RE: Need help balancing my Funtana - 4/22/2011 10:49 PM
carrellh
Score: 179
Last Login: 5/24/2013
Status: offline
The Funtanas called for 1.25 glow or 20cc gas. A Saito 20cc gas engine is 30 ounces with muffler and ignition. A Zenoah G20 is 41 ounces complete. A G26 is 53 ounces.
Even after moving a bunch of stuff you may need lead in the tail.
- Carrell
Hide Signatures
       Post #: 3
RE: Need help balancing my Funtana - 4/22/2011 11:57 PM
scooterinvegas
Score: 141
Status: offline
I would move the firewall before adding lead.
Moving the firewall is pretty easy. It only takes a couple of hours.
Hide Signatures
(in reply to carrellh)
       Post #: 4
RE: Need help balancing my Funtana - 4/23/2011 12:26 AM
MinnFlyer
Score: 390
Last Login: 4/27/2012
Status: offline
Gimme a break.
He has a plane made for up to a 20cc engine and he's putting in a 26cc and you would go through all of the trouble of moving the firewall rather than add a little lead?
To each his own. But I would add a little lead and never give it another thought. You'll have MORE than enough power to compensate.
Mike B. AMA# 42400 www.gettingairborne.com
Ultra Sport Brotherhood #2 - Waco Brother #188 - Cub Brother #2
"Those are my principles. If you don’t like them, I have others." - Groucho Marx
Hide Signatures
(in reply to scooterinvegas)
       Post #: 5
RE: Need help balancing my Funtana - 4/23/2011 2:05 AM
scooterinvegas
Score: 141
Status: offline
quote:
ORIGINAL: MinnFlyer
To each his own.
You got that right!!
Moving servos and or battery's would most likely take care of the balance. But if you want to be like Minn and add LEAD to your light weight, high-performance aerobatic model, you can do that too.
Hide Signatures
(in reply to MinnFlyer)
       Post #: 6
RE: Need help balancing my Funtana - 4/23/2011 2:53 AM
MinnFlyer
Score: 390
Status: offline
Only what's needed
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.695RCU1
