Steering issue help NON SERVO RELATED
AZ
I'm not having binding but I can't quite figure it out. I know something is off with my steering setup. I don't remember what I did in the past to the steering as it's held up quite well. I have to modify my front skid plates to fit the steering post because it sits to high. I've tried taking out the washers but the linkage looks like it will hit the drive shaft. Please take a look at my pictures and let me know if you need any other details to fix my issue. Thanks in advance!
RE: Steering issue help NON SERVO RELATED
Everything looks right as far as I can tell. Here are the exploded views so you can double check everything. Because your using spacers I would make sure you didn't forget to install anything. Also if this is not the right model you may have to look in the legacy section.
http://traxxas.com/products/models/e...maxx-downloads
AZ
I'm not sure. Maybe I'll rip in to it and just buy a new assembly since I know I don't have all the factory parts in there.
AZ
I took it apart, removed the washers and the center bar connecting the two horns on the first picture hits the diff. I'm thinking thats why I had the washer there.
