3 peice Corsair wing    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> 3 peice Corsair wing
Page: [1]
Login
3 peice Corsair wing - 4/23/2011 11:33 PM
Poppashango
Score: 100
Last Login: 4/29/2011
Status: offline
I am building a composite Corsair and have come to another problem. Now that I have figured out how to cut foam cores with the correct gull and airfoil shape, I am now stuck at the 3 peice wing. Any ideas are welcome thanks
Hide Signatures
       Post #: 1
RE: 3 peice Corsair wing - 4/24/2011 3:39 AM
91zulu
Score: 130
Last Login: 5/21/2013
Status: offline
What exactly do you need to know?
_____________________________
91-Zulu
Hide Signatures
(in reply to Poppashango)
       Post #: 2
RE: 3 peice Corsair wing - 4/25/2011 1:35 AM
SCALECRAFT
Score: 119
Status: online
Make the center section in composite attached at the fuse like the real one, and make the outer panels as the real one as well in foam.
Hide Signatures
(in reply to 91zulu)
       Post #: 3
RE: 3 peice Corsair wing - 4/25/2011 1:39 AM
SCALECRAFT
Score: 119
Status: online
Kinda like our little one but in foam outer section and 3 piece, not one.
Steve
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to SCALECRAFT)
       Post #: 4
RE: 3 peice Corsair wing - 4/25/2011 10:38 AM
Avaiojet
Score: 111
Status: offline
I don't think I would use foam.
I'd spend the time to build a built up wing.
Charles, owner, CFC Graphics, Vinyl graphics "Model Airplane Graphics from a Model Airplane Builder." 58 years of modeling.
Hide Signatures
       Post #: 5
RE: 3 peice Corsair wing - 4/27/2011 8:45 AM
91zulu
Score: 130
Status: offline
The center section will be a challenge to cut, the outer panels would be easy.I would make a balsa and ply center and foam outer panels to cut down on the time. To cut the center in foam it would have to be in 3 sections, the center where the fuse sit and the 2 sides. You could try it but be sure to cut the right angles so as to get the gull shape. Then you could either just glass where the joints are with 1 oz cloth or make ply spars. I would glass AFTER each section is sheeted then glued together and sanded nice. Makes a neater job.
91-Zulu
Hide Signatures
(in reply to Avaiojet)
       Post #: 6
RE: 3 peice Corsair wing - 4/30/2011 6:12 PM
NCIS
Score: 130
Last Login: 6/29/2011
Status: offline
I don't see how a foam core wing will hold any type of joiner and be safe. You will need something solid for either the wing tubes or joiner box channel and spade. Check out my thread and see how I did it with a built up wing using joiners. "Blown up Ziroli 124" F4U-5N Build."
NCIS
Barry - Owner of Canopy Rails For Warbirds
Hide Signatures
       Post #: 7
RE: 3 peice Corsair wing - 4/30/2011 6:56 PM
91zulu
Score: 130
Status: offline
Just what wing span are we talking about here?
Barry Joiners does work on foam gull wings, very well, any size. You just have to build to what size your wing is. The pockets are glued into the outer panels to what ever length that makes you happy. The blades are glued into the gull center section to what ever thickness that makes you happy.
91-Zulu
Hide Signatures
(in reply to NCIS)
       Post #: 8
RE: 3 peice Corsair wing - 5/1/2011 12:31 AM
NCIS
Score: 130
Status: offline
quote:
ORIGINAL: 91zulu
Did you read my post? It doesn't sound like you understood what I said. I said they wouldn't work!!! The wing will have to be composite and hoolow like the Byron Corsairs and then the joiners will have to be bolted to the solid fiberglas inbetwwen the top and bootm skins. Plus why epoxy and bolt the spades to the center section if you want to save space. It is easier to bolt and epoxy them to the outer wing panels and hang them up in your transport vehicle.
Hide Signatures
       Post #: 9
RE: 3 peice Corsair wing - 5/1/2011 2:55 AM
91zulu
Score: 130
Status: offline
I did read your post correctly. You said in a nut shell that you cant do plug in foam gull wings it has to be hollow in order to install the set up for the plugin spars. And I said wrong.. it can be done. Guess you have not done too much complex building, if you did you would know it can and was done many times. As a matter of fact there is a video on you tube done by Ty on how to build a plug in foam wing. Even though its a 2 piece wing, just follow the same for a 3 piece Very easy. Go check it out, and his way is only one of a few ways to do it.
Not everyone has a vehicle that can carry large wings, thats why we find ways to break them up for transport.
91-Zulu
Hide Signatures
(in reply to NCIS)
       Post #: 10
RE: 3 peice Corsair wing - 5/1/2011 10:22 PM
NCIS
Score: 130
Status: offline
I don't do anything complex except build from scratch and make up my own three piece wing with spades and box channels made on a CNC machine for a 125" Corsair. I guess thats not as complex as building a foam wing.
Hide Signatures
       Post #: 11
RE: 3 peice Corsair wing - 5/2/2011 3:49 AM
91zulu
Score: 130
Status: offline
OK sir!
91-Zulu
Hide Signatures
(in reply to NCIS)
       Post #: 12
RE: 3 peice Corsair wing - 5/5/2011 2:51 PM
rwright142
Score: 100
Last Login: 5/19/2013
Status: offline
For anyone reading this thread who has not heard, Barry O'Brien (NCIS) passed away Sunday (May 1, 2011). RIP my friend.
In the works: 1/6 Scale F4U Corsair
CORSAIR Brotherhood # 39
Hide Signatures
       Post #: 13
RE: 3 peice Corsair wing - 5/5/2011 6:38 PM
91zulu
Score: 130
Status: offline
Rest in peace Barry, you will surly be missed. So long friend.
91-Zulu
Hide Signatures
(in reply to rwright142)
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.453RCU1
