Volcano S30    Gallery
Logged in as Guest
    Search This Thread
Printable Version
More Resources on the
Volcano S30
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Volcano S30
    Page: [1]
    Login
    Volcano S30 - 4/25/2011 6:15 AM
    Big Z-Man
    Score: 100
    Last Login: 9/5/2011
    Status: offline
    I have a volcano S30 and I was wondering if someone could help me on tuning the engine as for as when I push the trigger forward for to long the engine dies. I also need help on adjusting the brake. I would like it to stop in a shorter distance and not kill the engine when I push the trigger on the remote forward. Thanks for any help that could be given.
    Hide Signatures
           Post #: 1
    RE: Volcano S30 - 4/27/2011 3:57 AM
    mileslong
    Score: 100
    Last Login: 2/2/2013
    Status: offline
    first off im gonna tell you how to fix the break problem.. if the motor is stullin out when you pull the break screw in the idel screw in and then test your breaks to see if the throttle arm moves.. now most ppl will tell you that there should be a 1mm gap in the carb and this is true so make sure you look at that before you start it up so it doesnt take off.. On your breaks all you should have to do is move or tighten the the linkage towards the servo arm.. For the motor, mind you its been awhile sense ive had my redcats, but i think the hsn should be close to 2 1/4 turns out and the lsn was 3/4 of a turn in from flush.... hope that helps
    Hide Signatures
    (in reply to Big Z-Man)
           Post #: 2
    RE: Volcano S30 - 4/27/2011 5:37 AM
    Big Z-Man
    Score: 100
    Status: offline
    Thanks alot, I'm actaully going to work on my truck first thing in the morning when I get home from work. Thanks again.
    Hide Signatures
           Post #: 3
    RE: Volcano S30 - 4/30/2011 4:20 PM
    volcanoman01
    Score: 100
    Last Login: 6/17/2012
    Status: offline
    I havea volcano s30 and the idle screw and servo saver nut is vibrating loose what can any one help me out .
    Hide Signatures
           Post #: 4
    Page:   [1]
    Page: [1]
    Volcano S30
  • See User Ratings
  • Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    0.250RCU1
