MGT 8.0 won't shift into 2nd    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Team Associated - Monster GT >> MGT 8.0 won't shift into 2nd
Page: [1]
Login
MGT 8.0 won't shift into 2nd - 4/25/2011 5:14 PM
R Dub
Score: 100
Last Login: 2/5/2012
Status: offline
Hello all - Just like the title states my MGT 8.0 will not shift into 2nd gear. It will run like a raped ape all day long in 1st. It will wheelie like a champ and just runs great other than it not shifting. I have tried to adjust the shift point by turning the allen screw counter clockwise but to no avail. Before I rip the trans apart to see if anything is broke I wanted to see if anyone else has had this issue and maybe what it could be. Thanks in advance!
Hide Signatures
       Post #: 1
RE: MGT 8.0 won't shift into 2nd - 4/27/2011 6:49 PM
AgentDrewski
Score: 105
Last Login: 6/21/2011
Status: offline
I am having this issue
Hide Signatures
(in reply to R Dub)
       Post #: 2
RE: MGT 8.0 won't shift into 2nd - 4/27/2011 6:53 PM
cummins driver
Score: 214
Last Login: 5/19/2013
Status: offline
Its most likely the grub screw that holds the 2nd gear sprag onto the shaft. There are 2 grub screws when you look through the shift point adjustment hole in the tranny. The one that goes straight in holds the sprag to the shaft. The other one is angled and is the adjustment screw. If the one holding the sprag to the shaft backs out some, it will never shift.
There is a flat spot on the shaft that the grub screw must sit on. Sometimes you can find it without pulling the tranny apart, but its best to take it apart, reseat it on the flat spot with loctite, and then reassemble.
My 4.6 did this. Not a bad fix, just gotta pull the transmission.
Good luck!
_____________________________
- Savage - MGT Pulling Truck - Losi LST2 - Brushless Blitz - RC10GT (getting a 2.5) - Brushless T4 - Sportwerks Mayhem Pro
Hide Signatures
(in reply to AgentDrewski)
       Post #: 3
RE: MGT 8.0 won't shift into 2nd - 4/28/2011 3:11 PM
AgentDrewski
Score: 105
Status: offline
aren't the transitions for the 8.0s different then the 4.6s
Hide Signatures
(in reply to cummins driver)
       Post #: 4
RE: MGT 8.0 won't shift into 2nd - 4/28/2011 3:21 PM
Nickboulin
Score: 100
Last Login: 1/24/2012
Status: offline
yes, the transmissions are different.
Hide Signatures
       Post #: 5
RE: MGT 8.0 won't shift into 2nd - 4/28/2011 4:33 PM
R Dub
Score: 100
Status: offline
quote:
ORIGINAL: cummins driver
Good luck!
Thanks for the input. I will give this a try and let you know if that fixes it.
Hide Signatures
       Post #: 6
RE: MGT 8.0 won't shift into 2nd - 4/28/2011 5:31 PM
cummins driver
Score: 214
Status: offline
They are physically different in a few ways, but they work exactly the same so the same principles apply.
Hide Signatures
(in reply to R Dub)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.436RCU1
