RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Premier Pilot 1/4 scale full body pilot
Seller:  Ren DiLeo
Details:   $129.00   |  3/24/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!!
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 11/19/2011 8:10 PM
firestone1121
Score: 100
Last Login: 2/2/2013
Status: offline
quote:
ORIGINAL: JeffH
Not quite. The .60 size P-51 ARF requires significant down trim to fly level.
I know my H9 P51 .60 requires 7 clicks of down to fly straight and level, and 7 clicks once i cut the throttle to make my landing approach
_____________________________
Money is the root of all evil. For more information, send $10 to me.
Hide Signatures
(in reply to JeffH)
       Post #: 26
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 11/19/2011 10:46 PM
bladebender
Score: 100
Last Login: 5/18/2013
Status: offline
flew the heck out of mine never had that problem .The clevis broke on the elevator and I was going strait up
Hide Signatures
(in reply to firestone1121)
       Post #: 27
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/10/2011 7:41 PM
Raman
Score: 100
Last Login: 3/13/2013
Status: offline
It's finally in stock!
EFlite Extra 260, TRF801GTe, TRF416WE, TG10 MK.2 Pro, DF03-RA, Cup Racer, Sand Scorcher Turbo Scorpion
Hide Signatures
(in reply to bladebender)
       Post #: 28
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/12/2011 4:48 AM
iflircaircraft
Score: 123
Last Login: 5/19/2013
Status: offline
I placed my order. To me it's well worth the price they are charging considering the the time and complexity of building the kit. This isn't a box type airframe especially with the gull wing and the fully operational split flaps.
Tom
"Where there''s a WILL, There''s a WAY"
Hide Signatures
(in reply to Raman)
       Post #: 29
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/12/2011 5:38 AM
Raman
Score: 100
Status: offline
Mine should be shipping tomorrow. Agree it's pricey, but I think it's worth it as well, given what's out there is junk. I'm not so hung up on the retracts either, most likely I'll install electric retracts from E-Flite, hope the fit
http://www.e-fliterc.com/Products/Default.aspx?ProdID=EFLG410
Hide Signatures
(in reply to iflircaircraft)
       Post #: 30
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/12/2011 12:59 PM
landeck
Score: 137
Status: offline
quote:
ORIGINAL: Raman
For the Corsair you need rotating retracts. The ones you referenced do not rotate. In fact, I don't think E-Flite has released rotating retracts in the 60-90 size yet. You will need to use some other brand.
Bruce
Bruce L. AMA# 54227
Ultra Sport Brotherhood #15
Hide Signatures
(in reply to Raman)
       Post #: 31
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/12/2011 4:25 PM
Lifer
Score: 148
Status: online
I have a set of Sierra rotating retracts in my .60-size TF P-40. I think there is a slight difference in strut length, but I'm sure he can make a set to length. They are of exceptional quality.
Hide Signatures
(in reply to landeck)
       Post #: 32
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/12/2011 5:19 PM
Raman
Score: 100
Status: offline
quote:
ORIGINAL: landeck
quote:
ORIGINAL: Raman
Bruce
You're right.. they make them for 25-46, not 60 to 120 size
http://www.e-fliterc.com/Products/Default.aspx?ProdID=EFLG320
There's always Lado: http://www.lado-tech.net/en/15-f4u-corsair
Or
http://www.sonicelectric.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=LD-MERS-AM100&Category_Code=NEW&Product_Count=0
Hide Signatures
       Post #: 33
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/12/2011 6:44 PM
landeck
Score: 137
Status: offline
Another possibility are the WingSpan Retracts:
http://www.wingspanretracts.com/
http://www.rcuniverse.com/forum/m_10649650/tm.htm
http://www.rcuniverse.com/forum/m_10800776/tm.htm
or Down and Lock:
http://www.downandlocked.com/
Bruce
Bruce L. AMA# 54227
Hide Signatures
(in reply to Raman)
       Post #: 34
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/12/2011 7:41 PM
Raman
Score: 100
Status: offline
Bruce,
Thank you for those links. I have a feeling down and lock is out of my budget.. so its a toss up between the Lado and Wing Span.. though they both seem to have their weak points..
Hide Signatures
       Post #: 35
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/12/2011 9:23 PM
landeck
Score: 137
Status: offline
Raman, yes Down and Lock are expensive. I am putting E-Flite retracts in the TF P-47 right now. I want to do the Corsair next but will wait and see if E-Flight comes out with rotating retracts or see how WingSpan finally works out or what Robart announces at the end of the month.
Bruce
Bruce L. AMA# 54227
Hide Signatures
(in reply to Raman)
       Post #: 36
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/12/2011 9:55 PM
Raman
Score: 100
Status: offline
I'll probably hold off as well to see what Robart comes up with. They all seem to have some sort of short coming.. Lado look better to me than Wing Span with exception of the brass screw.. they really should rethink that
Hide Signatures
       Post #: 37
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/12/2011 11:16 PM
lablover
Score: 103
Last Login: 5/8/2013
Status: offline
could we do the fixed until one decides what to do?
Hide Signatures
(in reply to Raman)
       Post #: 38
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/12/2011 11:24 PM
Raman
Score: 100
Status: offline
The ARF kit comes with fixed landing gear
Hide Signatures
(in reply to lablover)
       Post #: 39
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/13/2011 1:17 AM
Chad Veich
Score: 265
Status: offline
Put a set of Sierra pneumatics in it and be done with it. The Sierra gear are very robust and set up properly pneumatic retracts are very reliable. At this point in time the electric options don't seem to be as reliable as a good set of pneumatics. My .02 cents of course.
Hide Signatures
(in reply to Raman)
       Post #: 40
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/13/2011 5:57 PM
scottrc
Score: 104
Status: offline
I second on the pneumatics, I have a set of Robart 615s that were in my last two Corsairs and worked flawlessly and I plan to put them in this one as well.
If you love your plane, set it free, if it doesn''t return, you should have checked the battery.
Hide Signatures
(in reply to Chad Veich)
       Post #: 41
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/13/2011 6:16 PM
Raman
Score: 100
Status: offline
Mechanical, Pneumatics or electric all work. It's really a matter of preference, taste and money. The current trend is electric retracts, even Robart has acknowledged it and are coming out with their own.
You may like fiddling with hoses and compressed air, while other just want to drop it in, plug it in and see it work.
This is a very scale warbird, so my preference is to have scale looking retracts that open and close in what I call an elegant graceful manner.
Hide Signatures
(in reply to scottrc)
       Post #: 42
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/13/2011 11:24 PM
Raman
Score: 100
Status: offline
Looks like mine was just delivered! UPS emailed me a notification. Technically this is supposed to be a Christmas gift from my wife to me.. I'm inclined to not open it until then, although she probably will want me to open it now.. We're very backwards that way lol.
Hide Signatures
(in reply to Raman)
       Post #: 43
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/16/2011 3:28 AM
iflircaircraft
Score: 123
Status: offline
Robart and Down n Locked have joined and will be making electric actuated Robarts. Since my Corsair is on it's way I'll hang in there until Robart has some retracts to offer. It's building season here in the northeast anyway.
Tom
Hide Signatures
(in reply to Raman)
       Post #: 44
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/8/2012 7:03 AM
Bob Paris
Score: 110
Status: offline
Hi Guys,
I just ordered the Top Flight F4U ARF from tower...$209.00 w/free shipping & Decembers discount for club members...WoW. The U-Build kit almost cost this much... : ) I bought a set of 90 deg. rotating Lado's retracts a couple of years ago...and I have the Robo struts in house. I wonder if this model will take a RCG 20cc gas engine ? Some one please get building and send in pictures.
Merry Christmas
Bobby of Maui
< Message edited by Bob Paris -- 12/8/2012 3:58 PM >
AMA 15016
Say what you mean, mean what you say...and !#$& it if you can''t take a joke.
Hide Signatures
       Post #: 45
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/8/2012 11:05 AM
Lifer
Score: 148
Status: online
Bobby,
Do you recall which Tower code you used?
Hide Signatures
(in reply to Bob Paris)
       Post #: 46
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/8/2012 1:20 PM
da Rock
Score: 265
Status: offline
Just look the ARF up on Tower. It was $299 a week ago, and was $249 yesterday. Use the discount codes that have just showed up on Tower's front page and you can get $30 off $250.
If you are a Tower Club member, you could get $50 off of $250, and have free shipping.
Good flying wit ya today
Hide Signatures
(in reply to Lifer)
       Post #: 47
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/8/2012 2:13 PM
Lifer
Score: 148
Status: online
I deleted the Super Saver code sheet. Do you know the code for $300 purchases?
Hide Signatures
(in reply to da Rock)
       Post #: 48
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/8/2012 3:56 PM
Bob Paris
Score: 110
Status: offline
Hi Guys,
Here are the codes for the Super Savers Club ...
Up to $249.99, w/$40.00 off is 010B5
up to $299.99, w/$50.00 off is 010B6
over $300.00, w/$60.00 off is 010B7
Free delivery with Super Savers Club membership and for me that is a good bit of savings living in Hawaii..!
Soft Landings Always,
Bobby of Maui
AMA 15016
Hide Signatures
(in reply to Lifer)
       Post #: 49
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/8/2012 4:20 PM
Raman
Score: 100
Status: offline
I'm gonna call Tower and ask them to refund the difference.. They should honour it right, I only bought it a year ago.. Lol
Mine is still in box, have not even built it yet.
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.672RCU1
