RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Hangar 9 Twist 3D 40 (less Rx) - RTF
Seller:  stuk_at_work
Details:   $250.00   |  5/14/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!!
Page: <<   < prev  1 2 [3]
Login
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/8/2012 7:43 PM
Lifer
Score: 148
Last Login: 5/18/2013
Status: offline
Bobby,
Thanks!
Hide Signatures
(in reply to Raman)
       Post #: 51
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/9/2012 7:02 AM
Bob Paris
Score: 110
Last Login: 5/19/2013
Status: offline
OK Guys,
If anyone has done a build thread here on RCU, with the Top Flight .60~.90 F4U, please list it some where so we can look at your build.
It looks like this model will weight out anywhere between 10.5# and 12.0#.
It also seems to build out quite tail heavy, so you will need nose weight...maybe at least 12 oz. The review I read had a OS .65 LA installed and needed 12 oz. of lead under the engine to balance the model. The OS .65LA engine powered this model quite well and if you go to the video Tower has on this model...you will see just how well it does with this engine.
A RCG 20 cc weights out at 29 oz. and the cowl is big enough to hide a small gas engine. I'm flying a RCG 20 cc now, with a Master Air Screw 16x8 "S" series prop and I have also used a 15x7 three bladed M.A. prop with little difference in RPM and performance. I'm flying a 9.3# model and this enigne will pull this model vertical with a vengence...unlimited vertical. So I plan on going with a RGC 20 cc engine in my kit.
I already received information from Tower that my model will be on its way Monday...standard shipping to Hawaii, may take a month. But its next on the building board.
Soft Landings Always,
Bobby of Maui
< Message edited by Bob Paris -- 12/9/2012 5:42 PM >
_____________________________
AMA 15016
Say what you mean, mean what you say...and !#$& it if you can''t take a joke.
Hide Signatures
(in reply to Lifer)
       Post #: 52
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/10/2012 3:13 AM
jrod1019
Score: 100
Last Login: 5/16/2013
Status: offline
quote:
ORIGINAL: Bob Paris
OK Guys,
A RCG 20 cc weights out at 29 oz. and the cowl is big enough to hide a small gas engine. I'm flying a RCG 20 cc now, with a Master Air Screw 16x8 ''S'' series prop and I have also used a 15x7 three bladed M.A. prop with little difference in RPM and performance. I'm flying a 9.3# model and this enigne will pull this model vertical with a vengence...unlimited vertical. So I plan on going with a RGC 20 cc engine in my kit.
Bobby of Maui
i think they used a o.s. 65ax and not the LA sport motor.
Hide Signatures
(in reply to Bob Paris)
       Post #: 53
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/10/2012 8:20 AM
Bob Paris
Score: 110
Status: offline
Hay Jrod1019,
I stand correctred, your right. A OS .95 AX was used in the review.
Bobby of Maui
AMA 15016
Hide Signatures
(in reply to jrod1019)
       Post #: 54
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/10/2012 8:14 PM
SkyPilot101
Score: 125
Status: offline
Too good of a deal to pass up, ordered one!!! Now to decide if it will superceed other unfinished birds
Hide Signatures
       Post #: 55
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/11/2012 2:23 AM
aghost
Score: 100
Last Login: 5/17/2013
Status: offline
 Bob, There's a thread in the Warbirds section on this plane
http://www.rcuniverse.com/forum/m_10436714/mpage_1/key_/tm.htm
I put an OS108 2S in mine. Otherwise pretty much a stock build. Came in at 10 lb. Did not need extra weight to balance. Flies great.
Brian
Hide Signatures
       Post #: 56
RE: Top Flite released an F4U Corsair 61 ARF !!!!!!!! - 12/12/2012 1:04 AM
JWQ500RC
Score: 100
Status: offline
Just ordered mine at $220. delivered. Couldn't pass it up. Now I just have to come up with the money for the retracts and engine.
Jim Williams
Club Saito Menber #621
Hide Signatures
(in reply to aghost)
       Post #: 57
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.391RCU1
