new ecu?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> Turbine Clinic >> SimJet Turbine Direct Support >> new ecu? Page: [1]
Login
new ecu? - 5/8/2011 9:03 PM
MAXIAN
Score: 100
Last Login: 6/17/2013
Status: offline
Hi, today my ecu on a 3000 simjet maybe failed. At first runup it diet. I thing is the new lipo battery that it delivery at full charge 13 volts, and maybe was burn something.
The question is, if the ecu is burned, what is the best new ecu for this 3000?
Thank you
Hide Signatures
       Post #: 1
RE: new ecu? - 5/8/2011 9:15 PM
frema
Score: 103
Last Login: 6/19/2013
Status: offline
Try the new v10 from fadec
Hide Signatures
(in reply to MAXIAN)
       Post #: 2
RE: new ecu? - 5/8/2011 10:01 PM
MAXIAN
Score: 100
Status: offline
From Fadec?...who's he?
Hide Signatures
(in reply to frema)
       Post #: 3
RE: new ecu? - 5/8/2011 10:52 PM
frema
Score: 103
Status: offline
www.xicoy.com
find the v10 ecu ,and email Gaspar .
he will tell you if its possible or not ,using this ecu for your simjet.
Hide Signatures
       Post #: 4
RE: new ecu? - 5/9/2011 4:18 AM
rcjetsaok
Score: 135
Last Login: 6/20/2013
Status: offline
quote:
ORIGINAL: MAXIAN
Fadec is not a HE..... It is a What....." Full Authority Digital Engine Control " Unit. It is used in Full Scale jet aircraft and is a engine monitoring and managment unit. Takes an incredible amout of work load off the pilots.
Danno
_____________________________
The Hobby Express - Jet Central Tejas
Hide Signatures
       Post #: 5
RE: new ecu? - 5/11/2011 11:10 AM
MAXIAN
Score: 100
Status: offline
Yes, i know what mean FADEC.
So you mean the gaspar ecu.
Now i try to repair original ecu, in case.......
Hide Signatures
(in reply to rcjetsaok)
       Post #: 6
RE: new ecu? - 5/11/2011 12:51 PM
Vampire
Score: 100
Status: offline
Hi MAXIAN,
While you have not defined if you have the SIMJET - ECU (2002-D2) or the GASPAR -303 or 605, I can state that if using the Simjet-2002-D2 "Brick" ECU, it will take a 3S LiPol (11.1vdc) without issue, however, the 605 GASPAR (IXCOY) cannot when used on a Simjet due to the starter demand voltage.
When using a GASPAR -605, you must use a 2S Lipo (7.4vdc) as I have been advised by GASPAR.
I have become aware of the new v10 ECU but none of these have made it to the field just yet with Simjet enginse to date but will shortly. The other issue I have noted on GASPAR's web site is that the DATA TERMINAL currently used in the past on ALL Gaspar ECU's up thru the 605's WILL NOT WORK with the NEW v10 ECU and you will need to purchase the NEW v10 Compatable Data Terminal as stated on GASPAR's web paeg on this subject.
Best Regards,
Kerry J. Sterner
scaledesigner@verizon.net
Hide Signatures
       Post #: 7
RE: new ecu? - 5/12/2011 6:57 PM
MAXIAN
Score: 100
Status: offline
Thank you for reply.
Mine is a SIMJET - ECU (2002-D2). the lipo is a 3s 2500 mha.
Hide Signatures
(in reply to Vampire)
       Post #: 8
RE: new ecu? - 5/16/2011 1:46 PM
Vampire
Score: 100
Status: offline
Hi Maxian,
This 2002-D2 ECU is no longer supported by SIMJET - Denmark.
I may have a used one ($75 USD + shipping.) if you decide not to go to the new GASPR ECU which Simjet has now used for the past 3+ years.
Best Regards,
Kerry J. Sterner
Hide Signatures
       Post #: 9
RE: new ecu? - 5/19/2011 7:01 PM
MAXIAN
Score: 100
Status: offline
Hi Vampire.
The used ecu that have, of course is for a 3000, yes?
I'm trying to contact the simjet in denmark, but if i dont have a reply i will contact you.
Thank you
Hide Signatures
       Post #: 10
RE: new ecu? - 5/24/2011 7:14 PM
MAXIAN
Score: 100
Status: offline
Kerry...can you reply please, i need help for this turbine.
Thank you
Hide Signatures
       Post #: 11
RE: new ecu? - 5/25/2011 12:09 PM
Vampire
Score: 100
Status: offline
Hi Maium,
I do have 1) used ECU and can program it for your 3000.
Cost is $75.00 + shipping.
Please drop me an email at the shop email address below and we can make the required arangements.
Best Regards,
Kerry J. Sterner
Hide Signatures
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.313RCU1
