Superfast
Joined: 12/24/2002 From: Grandview, MO, USA Status: offline
WOW if thats a "few" questions, I am sure glad you didn't have "ALOT" of questions - That hatch is mounted in the front with dowel pins and the tabs slide inside the fuse side and are secured with #6 screws through the side of the plane. - As far as a guideline, I kinda guessed. I did reach around inside and poke some small "t" pins through so I could get a good reference as the where the balsa was. I tried to leave as much balsa as I could so I didn't weaken the center of the fuse. I few of the guys at the field cut out more than me and simply added some extra balsa to beef it up. - The only material I re-used in the hatch was the former for the instrument panel, other than the it is all new balsa. - The original forward formed is right there where mine is, I simply doubled it with lite ply to make it a little stronger for the dowels pins. The rear former is stock also. When the plane comes that former is covered in 1/16 balsa. I sanded off the sheeting to give a little more clearance for the new hatch. - The only part I recovered is the top blue section. When you cut your hatch take a piece you cut off down to your LHS and match the color. It matches to a Darker Blue Ultracote. - Wider beams towards the rear of the hatch area were original. - Canopy was attached with small screws touched with a drop of ca to keep them in. I t should make the canopy removable if I ever need to in the future. - The blocks in the wings should be fine. Just make sure you drill them out a bit, the wood is very hard and will split. I coated the screw section with epoxy before screwing them in, and was able to get some epoxy on the backside also through the lightening holes. - As far as weight savings or not. I really don't know. I didn't weight it before I did the mod. The weight wasn't a concern to me at the time, I was more concerned with gaining access to the wing area !! My plane is some where in the 12 1/2 pound range with a Brison gasser on the front. Even with the added weight of the gas engine I still had to add 4 ounces of lead to the nose. Now that I have flown the plane quite a bit I have some plans this winter to lighten it up a little bit. I am going to move the rudder servo forward and eliminate the nose weight, go with lighter batteries and probably switch to carbon fiber landing gear. I figure with those mods I should be able to shave a good 1/2 pound off the plane. Don't get me wrong here, the plane flys great and will do anything I ask of it. It has unlimited vertical and will hover quite easily, not to mention knife edges are a blast ! I got my carbon prop today, so tomorrow it's off to the field for some flights. Scott
< Message edited by Superfast -- 9/11/2003 4:15:01 AM >
