Control horn bolts on Glow 3D/Sport Scale ARF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Questions and Answers >> Control horn bolts on Glow 3D/Sport Scale ARF
Page: [1]
Login
Control horn bolts on Glow 3D/Sport Scale ARF - 5/13/2011 12:15 AM
Oberst
Score: 621
Last Login: 5/22/2012
Status: offline
I'm building a Seagull .90-1.25 Extra 260 and I put all the control horn bolts through the holes in my control surfaces. It uses the 2 aluminum washers and a nut to keep them in place with a little loc-tite on the threads.
Where the bolt goes through, it goes through plywood or bass wood. In the directions it said to put a little 30 min epoxy in the holes just before slideing the control horn bolt through. I forgot to do that because I only glanced at the directions. I built this plane once before, and I don't recall putting anything in the holes before because it's in a plywood area, and not balsa.
Do you guys think it will be OK? Or do I have to pull everything apart to put the epoxy in? Because of my experience this is a easy build and I'm wondering if this was a important step I over looked?
Pete
Click to see fullsize image.
Click for fullsize
_____________________________
AMA #856404 Fokker Planes Forever! VFW POST 8534 Mens Aux Member
Hide Signatures
       Post #: 1
RE: Control horn bolts on Glow 3D/Sport Scale ARF - 5/13/2011 2:16 AM
Gray Beard
Score: 314
Last Login: 5/24/2013
Status: offline
You don't have to do anything, it's your plane. I use thin CA to harden the wood, not epoxy. The why of it is the screws may compress the wood a bit and the screws may loosen up a bit then wobble around and enlarge the drilled hole in the wood. That creates a sloppy control surface. Your call.
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
(in reply to Oberst)
       Post #: 2
RE: Control horn bolts on Glow 3D/Sport Scale ARF - 5/13/2011 12:05 PM
Kaos Rulz
Score: 103
Last Login: 2/22/2013
Status: offline
Pete,
You're OK. Keep an eye to ensure the nut/bolt remains snug and you won't have any problems. Enjoy the plane, you'll love it!
ED -- AMA 20464 -- A plane is 1000+ different parts all flying in very close formation.
Hide Signatures
       Post #: 3
RE: Control horn bolts on Glow 3D/Sport Scale ARF - 5/13/2011 7:19 PM
TedMo
Score: 100
Last Login: 8/23/2012
Status: offline
My method would be to drill hole tap drill size, thereby screwing bolt into wood. With the nut then fastened to it it is locked together.
Hide Signatures
(in reply to Kaos Rulz)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.141RCU1
