RE: Extreme Flight Vanquish 2m Build Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> RE: Extreme Flight Vanquish 2m Build Thread
Page: <<   < prev  37 38 [39] 40 41 42 43 44 45 46   next >   >>
Login
RE: Extreme Flight Vanquish 2m Build Thread - 6/22/2012 4:11 AM
cygnet
Score: 100
Last Login: 5/21/2013
Status: offline
Show the run way facing north that would be impressive.
Hide Signatures
(in reply to Flyer88)
       Post #: 951
RE: Extreme Flight Vanquish 2m Build Thread - 6/22/2012 4:32 AM
Flyer88
Score: 100
Last Login: 5/9/2013
Status: offline
Its almost impossible to get a good panoramic shot of our field. Maybe from the air ?
Facing NW from the pits....E/W runway
Facing NE from the pits...N/S runway
< Message edited by Flyer88 -- 6/22/2012 12:56 PM >
_____________________________
Why is there never enough time to do it right, but always enough time to do it over ?
Hide Signatures
(in reply to cygnet)
       Post #: 952
RE: Extreme Flight Vanquish 2m Build Thread - 6/22/2012 4:43 AM
cygnet
Score: 100
Status: offline
Big Alberta Sky you need GPS when you crash or you won't find it.
Hide Signatures
       Post #: 953
RE: Extreme Flight Vanquish 2m Build Thread - 6/22/2012 4:46 AM
Flyer88
Score: 100
Status: offline
It was beautiful skys today, alittle hard to see at times. But a good day.
Helios was trimmed nice . Tried your tweek the ailerons trick for pulling to the canopy and it works well.
You goin tomorrow ??
Hide Signatures
       Post #: 954
RE: Extreme Flight Vanquish 2m Build Thread - 6/22/2012 4:52 AM
cygnet
Score: 100
Status: offline
See who needs a computer radio, with all that mixing ha ha ha.
Hide Signatures
       Post #: 955
RE: Extreme Flight Vanquish 2m Build Thread - 6/22/2012 9:36 PM
dando
Score: 100
Last Login: 5/20/2013
Status: offline
Hello, guys!
Has anyone trimmed the Vanquish using Brian Hebert's method? If so, what incidence settings are you running? How is the Vanquish flying afterwards?
In addition, has anybody made a new cut in the fuselage for the warm air to exit or enlarge the original? Maybe this would be an option. The other one is blocking some of the intakes if needed.
Thank you!
Best regards,
Nickolay
Hide Signatures
       Post #: 956
RE: Extreme Flight Vanquish 2m Build Thread - 6/23/2012 2:33 AM
Flyer88
Score: 100
Status: offline
Cleaned up the battery leads with grommets to keep them from falling down under the battery tray.
Just need some Velcro straps. Can anyone tell me the approx max forward location of the batteries.
< Message edited by Flyer88 -- 6/25/2012 12:44 AM >
Hide Signatures
(in reply to dando)
       Post #: 957
RE: Extreme Flight Vanquish 2m Build Thread - 6/23/2012 2:38 AM
danamania
Score: 105
Status: offline
quote:
...Can anyone tell me the approx max forward location of the batteries.
FWIW the aft end of my batteries are more or less between your regulator switch and where you have those wires coming up from below.  Hope that helps.  Nice airfield you got there!
Good Flying! Dana
4449NSRC AMA
Hide Signatures
       Post #: 958
RE: Extreme Flight Vanquish 2m Build Thread - 6/23/2012 3:21 AM
Flyer88
Score: 100
Status: offline
I'll take that info to the bank !
Thanks for nothing
Hide Signatures
(in reply to danamania)
       Post #: 959
RE: Extreme Flight Vanquish 2m Build Thread - 6/23/2012 6:37 AM
Flyer88
Score: 100
Status: offline
Painted spinner
< Message edited by Flyer88 -- 6/23/2012 7:15 AM >
Hide Signatures
       Post #: 960
RE: Extreme Flight Vanquish 2m Build Thread - 6/23/2012 7:17 AM
cygnet
Score: 100
Status: offline
What no flying today? Great day to practice we had the whole place to our selves.
Hide Signatures
       Post #: 961
RE: Extreme Flight Vanquish 2m Build Thread - 6/23/2012 7:21 AM
Flyer88
Score: 100
Status: offline
Working !
Started painting houses for a couple builders, with a buddy of mine.
Gonna be busy hope I have time to get away.
Was just starting to feel good on the controls, since I went to the tray.
Hide Signatures
       Post #: 962
RE: Extreme Flight Vanquish 2m Build Thread - 6/23/2012 11:51 AM
danamania
Score: 105
Status: offline
quote:
ORIGINAL: Flyer88
Thanks for nothing
You are most welcome.  There is a contest today and the Vanquish was already loaded in the car last night so my apologies for the brief reply which was not of value to you.
Good luck with your maiden, please let us know how you like the model and your set-up.  Please also post your CG for comparison, there are not many flying these who report back.
Good Flying! Dana
4449NSRC AMA
Hide Signatures
       Post #: 963
RE: Extreme Flight Vanquish 2m Build Thread - 6/23/2012 11:58 AM
Flyer88
Score: 100
Status: offline
Why is it that all of the photos Ive seen have the batts sitting close with the front edge of the the landing gear.
< Message edited by Flyer88 -- 6/23/2012 1:42 PM >
Hide Signatures
       Post #: 964
RE: Extreme Flight Vanquish 2m Build Thread - 6/23/2012 12:36 PM
Flyer88
Score: 100
Status: offline
Final finished weight with batteries Zippy 10s 5000 20c is 10.8 lbs or 4.898 kg's according to my digital scale.
< Message edited by Flyer88 -- 6/23/2012 2:08 PM >
Hide Signatures
       Post #: 965
RE: Extreme Flight Vanquish 2m Build Thread - 6/23/2012 2:00 PM
Flyer88
Score: 100
Status: offline
quote:
ORIGINAL: dando
Hello, guys!
Thank you!
Best regards,
Nickolay
Sorry have not heard of this method before. I use the method from Eflite.
And the reputable people Ive talked to about baffling the inlet said it was not required. I was told to leave it as it is. Ive never had issues with air intakes on my dozens of electrics Ive owned in the past. I dont know why it would be an issue now.
Cheers
Hide Signatures
(in reply to dando)
       Post #: 966
RE: Extreme Flight Vanquish 2m Build Thread - 6/24/2012 3:03 AM
danamania
Score: 105
Status: offline
quote:
ORIGINAL: Flyer88
Good question!  I had a brief conversation today with another Vanquish owner at a pattern contest whose packs are farther forward than mine.  One possibility is difference in batches.  Mine is from last year and it has a different rudder/fin configuration than this year's batches.  Who knows what other changes were made since last year?  And then there is the weights of the materials themselves. Perhaps the woods used changed with supply variations to the factory.  At the end of the day, what matters is the resulting CG and wing incidence chosen for one's flying style.  Could also be that I prefer the CG a bit further aft than others on the Vanquish. Say, what is your CG and wing incidence settings of choice?  Anyway, all the best wishes for your maiden and trim flights.
Good Flying! Dana
4449NSRC AMA
Hide Signatures
       Post #: 967
RE: Extreme Flight Vanquish 2m Build Thread - 6/24/2012 3:30 AM
Flyer88
Score: 100
Status: offline
quote:
ORIGINAL: danamania
quote:
ORIGINAL: Flyer88
Im sorry but I took it as a misrepresentation, specially when you see the differences in setups. I didnt realize that your setup was so far aft compared to others Ive seen.
Im aware that everyones setup is going to vary a bit according to placement and differences in equipment...etc.
Im looking forward to the maiden and will post my experiance if anyone cares to listen.
My posts were not to influence anyone in anyway just to share my build style with others .
Ive learned from others and I hope someone would have picked up something in my build that they may find useful.
It's all good stuff. What could be bad about building planes to fly , share and enjoy.
Happy landings
Flyer88
Hide Signatures
       Post #: 968
RE: Extreme Flight Vanquish 2m Build Thread - 6/24/2012 3:31 AM
Flyer88
Score: 100
Status: offline
quote:
ORIGINAL: cygnet
How was the scale event at the field today ?
Hide Signatures
       Post #: 969
RE: Extreme Flight Vanquish 2m Build Thread - 6/24/2012 3:38 AM
cygnet
Score: 100
Status: offline
Don't know didn't go anywhere near the place,to dangerous for a pattern flyer.
Hide Signatures
       Post #: 970
RE: Extreme Flight Vanquish 2m Build Thread - 6/24/2012 9:12 PM
Flyer88
Score: 100
Status: offline
Size difference between the Helios 90 and the Vanquish
It's interesting to see the evolution of the designs.
< Message edited by Flyer88 -- 6/25/2012 12:42 AM >
Hide Signatures
       Post #: 971
RE: Extreme Flight Vanquish 2m Build Thread - 6/25/2012 2:04 PM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: danamania
Dana,
I suspect that Jim's set-up is a bit nose heavy. I think he said that he was still trying to determine best position for his battery. His flying weight is only 4600 grams and that weight allows a little more latitude in setup
Your set-up felt ok to me at least for the one flight I took in calm conditions. Doesn't mean a little tweeking might not get a better flying model.
Regards,
MattK
Hide Signatures
       Post #: 972
RE: Extreme Flight Vanquish 2m Build Thread - 6/25/2012 2:13 PM
RC Accessory
Score: 105
Last Login: 3/31/2013
Status: offline
I agree with the statements about batches of the kit. I am using a Dualsky 6360-12 which is nearly 2 oz heavier than the Torque motor. My tailwheel is the F3A Unlimited tail wheel assembly which is epoxied in place. Even if I used 10 grams of epoxy, that far back would result in needing more nose weight. My 1700 LiFe rx pack is as far forward as it can be and I still moved my batteries forward to get the CG about 180mm. I plan on pulling the 1700 for a 850 LiFe, saving 1.5 oz and maybe the Falcon v2 prop which would save 2 oz over the APC 20x13E prop, but then the batteries would have to be moved even more forward to compensate. I do not know if the weight issue is caused by the tailwheel installation or the new rudder/fin configuration, but none the less I would be very tail heavy if I had used a lighter weight motor. Any weight savings I can incorporate or change equipment would be up front so I am not happy about the situation. If I have to change the motor for example, I would be forced to use heavier batteries.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to MTK)
       Post #: 973
RE: Extreme Flight Vanquish 2m Build Thread - 6/25/2012 2:47 PM
cmoulder
Score: 106
Last Login: 5/16/2013
Status: offline
IMHO that doesn't look too bad!
Some of the older e-conversion models (such as Brio) had the main packs almost touching the motor case. In full-composite birds the additional stab weight also requires a significantly farther forward placement of batteries to achieve CG.
I would be very happy with what you have there.
Bob
Hide Signatures
(in reply to RC Accessory)
       Post #: 974
RE: Extreme Flight Vanquish 2m Build Thread - 6/25/2012 3:15 PM
J Lachowski
Score: 100
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: RC Accessory
Lookin at your picture, I would move the flight pack forward and put the Rx pack behind the flight pack. I can't tell if you have clearance for the flight pack further forward from the picture.
As far as Rx battery goes, knock on wood, I have been using one 730ma 2 cell lipo with a voltage regulator for a good 5 years now. You can even use a dual regulator with a pair of 350ma 2 cell lipos if you wanted
Joe Lachowski
NSRCA 330
Hide Signatures
       Post #: 975
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.000RCU1
