RE: Extreme Flight Vanquish 2m Build Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> RE: Extreme Flight Vanquish 2m Build Thread
Page: <<   < prev  49 50 [51] 52 53 54 55 56 57 58   next >   >>
Login
RE: Extreme Flight Vanquish 2m Build Thread - 12/20/2012 9:04 AM
xrboss
Score: 100
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: xrboss
Finally had the maiden flight on Sunday. Very uneventful, zero trim change from my bench setup, not one click of trim change.
Setup much like many here in this thread.
HiMax 210
APC 20.5 X 14
CC HV80 ESC 30% Brake
2x5s5000mAh FlightMax 20C
2xs9650 Elevators
2xDS831 Ailerons
DS8715 Rudder
Stabs 0 degree
Wing 0.5 degree
Some pics from today.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to xrboss)
       Post #: 1251
RE: Extreme Flight Vanquish 2m Build Thread - 12/21/2012 1:39 AM
JonPa
Score: 100
Last Login: 4/18/2013
Status: offline
I have noticed that many people using futaba servos (9650s for eles; 9551 for ailerons; 9156 for rudder) are using different arms such as the Dubro super strength or aluminum arms. Is there any reason not to use the supplied arms, especially given that generally low rates are used on this plane? I like using the X-type arms so you can rotate it on the servo in order to make sure the arm is perfectly perpendicular to the servo. Just wondering if there is any problem with the supplied arms that I cant think of.
Jon
Hide Signatures
       Post #: 1252
RE: Extreme Flight Vanquish 2m Build Thread - 12/21/2012 1:45 PM
jetmech43
Score: 100
Last Login: 5/25/2013
Status: offline
you can use them, they may not be long enough if you use them on the elevators
_____________________________
smooth pass
Hide Signatures
(in reply to JonPa)
       Post #: 1253
RE: Extreme Flight Vanquish 2m Build Thread - 12/21/2012 2:39 PM
nonstoprc
Score: 110
Status: online
There is also the neat factor and maybe slightly weight advantage.
Where facts are few, experts are many.
Perfection is God''''s business.
Hide Signatures
(in reply to jetmech43)
       Post #: 1254
RE: Extreme Flight Vanquish 2m Build Thread - 12/21/2012 3:54 PM
can773
Score: 105
Status: online
quote:
ORIGINAL: JonPa
Jon
I always use the stock arms on Futaba servos, unless they are not long enough. Otherwise there is nothing wrong with using them, they also make getting a perfect 90 deg from the servo to the linkage much easier than an aftermarket single horn.
Chad Northeast
Hide Signatures
(in reply to JonPa)
       Post #: 1255
RE: Extreme Flight Vanquish 2m Build Thread - 12/21/2012 4:16 PM
Flyer88
Score: 100
Last Login: 5/9/2013
Status: offline
Hey Chad
How many oz's you running on rudder and at what voltage ?
And what the length of the horn.
Thx
Why is there never enough time to do it right, but always enough time to do it over ?
Hide Signatures
(in reply to can773)
       Post #: 1256
RE: Extreme Flight Vanquish 2m Build Thread - 12/21/2012 6:09 PM
can773
Score: 105
Status: online
quote:
ORIGINAL: Flyer88
Hey Chad
Thx
Running this one,
http://www.gpdealera.com/cgi-bin/wgainf100p.pgm?I=FUTM0731
At 7.2V. The arm on the rudder is the big Dubro HD one, but I will go back to the large Futaba wheel as I needed to ATV back the rudder a bit since the large Dubro was too much throw.
I am also going to try one of these, but not sure it will make much difference.
http://www.gpdealera.com/cgi-bin/wgainf100p.pgm?I=FUTM0735
Chad Northeast
Hide Signatures
(in reply to Flyer88)
       Post #: 1257
RE: Extreme Flight Vanquish 2m Build Thread - 12/21/2012 8:40 PM
Flyer88
Score: 100
Status: offline
Do any Futaba servos use Magnetic Induction for positioning yet.
I know the only Hitec is the 7990m at 630oz .... Kinda overkill for these planes.
Hide Signatures
       Post #: 1258
RE: Extreme Flight Vanquish 2m Build Thread - 12/21/2012 9:13 PM
can773
Score: 105
Status: online
quote:
ORIGINAL: Flyer88
Not that I am aware of.
Chad Northeast
Hide Signatures
       Post #: 1259
RE: Extreme Flight Vanquish 2m Build Thread - 12/22/2012 10:05 PM
pvogel
Score: 100
Last Login: 5/24/2013
Status: offline
quote:
ORIGINAL: Flyer88
Several of the JR WV series brushless servos use hall sensing for positioning, but they are a little large + heavy for anything but rudder and maybe aileron.
Peter+
Hide Signatures
       Post #: 1260
RE: Extreme Flight Vanquish 2m Build Thread - 12/22/2012 10:23 PM
Flyer88
Score: 100
Status: offline
That's where I was kind of excited about these Hobby King servos because they're fairly lite and very accurate and obviously very affordable.
< Message edited by Flyer88 -- 12/23/2012 2:20 AM >
Hide Signatures
(in reply to pvogel)
       Post #: 1261
RE: Extreme Flight Vanquish 2m Build Thread - 12/22/2012 11:59 PM
cygnet
Score: 100
Status: offline
Glen buy them and let us know how they work that way it will save us crashing
Hide Signatures
       Post #: 1262
RE: Extreme Flight Vanquish 2m Build Thread - 12/23/2012 12:07 AM
Flyer88
Score: 100
Status: offline
Not out to prove anything
Just sharing info.
Merry Christmas Dennis
Hide Signatures
(in reply to cygnet)
       Post #: 1263
RE: Extreme Flight Vanquish 2m Build Thread - 12/27/2012 9:45 PM
g_mkoch
Score: 100
Status: offline
can someone provide me with the correct lenght and thread size to install a Himax 210
Happy Landings
Kenobi - I think we lost something.
Skywalker - Not to worry, we are still flying half a ship.
Hide Signatures
       Post #: 1264
RE: Extreme Flight Vanquish 2m Build Thread - 12/29/2012 5:44 PM
JonPa
Score: 100
Status: offline
Just wondering if people are crossing the rudder pull-pull cables or not? For some reason I cant find any comments on this topic.
Hide Signatures
(in reply to g_mkoch)
       Post #: 1265
RE: Extreme Flight Vanquish 2m Build Thread - 12/29/2012 5:50 PM
pvogel
Score: 100
Status: offline
Mine are crossed
Hide Signatures
(in reply to JonPa)
       Post #: 1266
RE: Extreme Flight Vanquish 2m Build Thread - 12/29/2012 6:26 PM
JonPa
Score: 100
Status: offline
Thanks for the information. Are you also using an offset servo arm?
Jon
Hide Signatures
       Post #: 1267
RE: Extreme Flight Vanquish 2m Build Thread - 1/1/2013 5:44 AM
pvogel
Score: 100
Status: offline
You only need an offset servo arm if the rudder control points aren't directly over the hinge line, since they are, you don't need an offset.
Peter+
Hide Signatures
(in reply to JonPa)
       Post #: 1268
RE: Extreme Flight Vanquish 2m Build Thread - 1/11/2013 9:52 PM
Walfam
Score: 100
Last Login: 5/18/2013
Status: offline
HI Arch,
I am working on my vanquish and I have a question. What is the trick of getting the pull pull wires up thru the fusilage? It that one place in the back was not there it would be easy. Up here in the NW the vanquish has been very popular. Also, this was an excellent build thread I fly intermediate (just moved up) and looking forward to getting this puppy in the air.
Thanking you in advance
Wayne Lovett
District 8
Hide Signatures
(in reply to rcpattern)
       Post #: 1269
RE: Extreme Flight Vanquish 2m Build Thread - 1/11/2013 10:22 PM
JonPa
Score: 100
Status: offline
quote:
ORIGINAL: Walfam
HI Arch,
Wayne Lovett
District 8
Wayne,
I just used a piece of stiff music wire that I taped to the tip of the pull pull cable. Then I routed it from the back through the slot in the fuselage. You only need to push it about 1-1.5 feet through to be able to grab the cable from the front and pull it through. Not as hard as it looks.
Jon
Hide Signatures
(in reply to Walfam)
       Post #: 1270
RE: Extreme Flight Vanquish 2m Build Thread - 1/11/2013 10:45 PM
jetmech43
Score: 100
Status: offline
I got my girl to fish it through for me she has skinnier arms and better eye sight
smooth pass
Hide Signatures
(in reply to JonPa)
       Post #: 1271
RE: Extreme Flight Vanquish 2m Build Thread - 1/12/2013 11:26 AM
flier1
Score: 100
Status: offline
Just about to start my build, have people used the mylar hinges or replaced them with pinned hinges, never been a great fan of them and only used them on small planes in the past. Thanks Keith.
Hide Signatures
       Post #: 1272
RE: Extreme Flight Vanquish 2m Build Thread - 1/12/2013 4:05 PM
jetmech43
Score: 100
Status: offline
I used radio south pro hinges, never had a failure
smooth pass
Hide Signatures
(in reply to flier1)
       Post #: 1273
RE: Extreme Flight Vanquish 2m Build Thread - 1/12/2013 9:04 PM
SteveRoss
Score: 100
Last Login: 5/21/2013
Status: offline
I just got my Vanquish. It came with Robart style hinges. Anyone using them? I was also going to use a Hacker A60-7s but it does not fit - too long and the x mount is too large and the holes do not match those supplied on the fuse. I don't want to start modifying the nose. Any suggestions?
Steve
Hide Signatures
       Post #: 1274
RE: Extreme Flight Vanquish 2m Build Thread - 1/12/2013 10:32 PM
jetmech43
Score: 100
Status: offline
the plane is designed around the fury torque motor, im useing the eflite power 160 in mine and it fits with only have to move one of the holes in the fire wall I know people have used other motors, im not sure what you have to do to get your hacker to fit, I wouldnt want to modify the nose.
smooth pass
Hide Signatures
(in reply to SteveRoss)
       Post #: 1275
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.734RCU1
