RE: Extreme Flight Vanquish 2m Build Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> RE: Extreme Flight Vanquish 2m Build Thread
Page: <<   < prev  45 46 [47] 48 49 50 51 52 53 54   next >   >>
Login
RE: Extreme Flight Vanquish 2m Build Thread - 7/6/2012 12:35 AM
strattac
Score: 100
Last Login: 4/24/2013
Status: offline
You guys think the 3m nylon canopy bolts(thumbscrews) will hold the canopy on the Vanqush?
Hide Signatures
(in reply to danamania)
       Post #: 1151
RE: Extreme Flight Vanquish 2m Build Thread - 7/6/2012 12:48 AM
danamania
Score: 105
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: strattac
Yup. Or use 3mm cap screws. I've used both with no worries.
_____________________________
Good Flying! Dana
4449NSRC AMA
Hide Signatures
(in reply to strattac)
       Post #: 1152
RE: Extreme Flight Vanquish 2m Build Thread - 7/6/2012 1:17 AM
KenChoo
Score: 100
Last Login: 5/21/2013
Status: offline
Hi guys,
Need some help with the elevator servos. I've got JR3421's that are supposed to fit but I'm having trouble getting them in due to the grommet/servo wire. It looks like the opening in the stab rib is 'just' big enough to fit the stab case, and there's only a narrow slot to allow for the servo wire. May I ask how people have slotted in their servos (i.e. what process you used to get your servo in there)?
Ken
Hide Signatures
       Post #: 1153
RE: Extreme Flight Vanquish 2m Build Thread - 7/6/2012 1:18 AM
Flyer88
Score: 100
Last Login: 5/9/2013
Status: offline
I used Hitecs but had to file the wood just a little to get them in.
Why is there never enough time to do it right, but always enough time to do it over ?
Hide Signatures
(in reply to KenChoo)
       Post #: 1154
RE: Extreme Flight Vanquish 2m Build Thread - 7/6/2012 3:08 AM
KenChoo
Score: 100
Status: offline
Hi guys,
Solved...just had to sand about 0.5 - 0.75 mm. It was on the verge of clearing anyway, looks like.
Ken
Hide Signatures
(in reply to Flyer88)
       Post #: 1155
RE: Extreme Flight Vanquish 2m Build Thread - 7/6/2012 1:13 PM
jetmech43
Score: 100
Status: online
I use a canopy latch with mine,quicker
smooth pass
Hide Signatures
       Post #: 1156
RE: Extreme Flight Vanquish 2m Build Thread - 7/6/2012 11:58 PM
g_mkoch
Score: 100
Last Login: 5/22/2013
Status: offline
After a couple months I had the guys at tru-turn make me this
Click to see fullsize image.
Click for fullsize
Kenobi - I think we lost something.
Skywalker - Not to worry, we are still flying half a ship.
Hide Signatures
(in reply to jetmech43)
       Post #: 1157
RE: Extreme Flight Vanquish 2m Build Thread - 7/7/2012 12:39 AM
BHolsten
Score: 100
Status: offline
Thats Kooool!
bholsten
Hide Signatures
(in reply to g_mkoch)
       Post #: 1158
RE: Extreme Flight Vanquish 2m Build Thread - 7/7/2012 2:24 AM
Flyer88
Score: 100
Status: offline
Why such a long time ......2 months ? their just anodized ?
Very nice ........😊
< Message edited by Flyer88 -- 7/8/2012 5:24 AM >
Hide Signatures
(in reply to BHolsten)
       Post #: 1159
RE: Extreme Flight Vanquish 2m Build Thread - 7/7/2012 2:06 PM
strattac
Score: 100
Status: offline
Anyone know what control arm is being used for the futaba 9650 on the elevator?
Hide Signatures
       Post #: 1160
RE: Extreme Flight Vanquish 2m Build Thread - 7/9/2012 7:01 AM
mxcop114
Score: 100
Last Login: 5/6/2013
Status: offline
quote:
ORIGINAL: strattac
Use the Dubro Super Strength arms, I used the shortest arms and that is what we recommend in the manual, you may have to open up the holes in the stab a little when using the short arms.
Here's a link to them: http://www.horizonhobby.com/products/super-strength-standard-servo-arms-fut-DUB673
Lee
Team EXTREME FLIGHT RC-Team Horizon Hobby-Team Castle Creations-Thunder Power RC-Desert Aircraft
Hide Signatures
       Post #: 1161
RE: Extreme Flight Vanquish 2m Build Thread - 7/9/2012 1:09 PM
rcpattern
Score: 100
Status: offline
quote:
ORIGINAL: mxcop114
quote:
ORIGINAL: strattac
Lee
I personally have not good luck with the dubro arms as they seem to have some slop on the Futaba servos. I've been using the Futaba aluminum arms available from Tower.
Arch
Team Futaba, Castle Creations, Tech Aero Designs, Hacker Motors, F3A Unlimited, Team BJ Craft,
Hide Signatures
(in reply to mxcop114)
       Post #: 1162
RE: Extreme Flight Vanquish 2m Build Thread - 7/12/2012 7:38 AM
xrboss
Score: 100
Last Login: 5/19/2013
Status: offline
Is anyone using the brake setting in the ESC of the castle HV80?
Does the plane require the brake setting for the down lines?
Hide Signatures
(in reply to rcpattern)
       Post #: 1163
RE: Extreme Flight Vanquish 2m Build Thread - 7/12/2012 12:15 PM
mxcop114
Score: 100
Status: offline
quote:
ORIGINAL: xrboss
I'm not, I feel the plane actually flies a slow downline without it, it's easy to maintain consistant speed with the Vanquish. I'll be interested in seeing what others have to say about this.
Lee
Hide Signatures
(in reply to xrboss)
       Post #: 1164
RE: Extreme Flight Vanquish 2m Build Thread - 7/12/2012 12:38 PM
danamania
Score: 105
Status: offline
I have an idle up which I activate before take-off. This usually stays on throughout most of the Sportsman sequence. Sometimes I activate the esc brake with idle down and throttle off, if I need to slow a downline. Idle down and esc brake are most useful to me for landings if the approach is steep or fast on final (or unfavorable winds). Nice to have on a switch if needed, and fine to leave off for most downlines, I guess it depends on what schedule you are flying and prop choice. The brake is 25% btw and the Himax motor comes with some recommendations about esc settings too.
Good Flying! Dana
4449NSRC AMA
Hide Signatures
       Post #: 1165
RE: Extreme Flight Vanquish 2m Build Thread - 7/12/2012 1:25 PM
rcpattern
Score: 100
Status: offline
I think a lot of it depends on your flying style. If you fly faster and larger, you might want a brake. I personally used the brake on my Vanquish, but it is a personal preference. I know others that don't use it, that don't have an issue. I think it is a personal feel thing. Try it and see if you like it. I would not run more than 30% though as you will start to get the squeal from the ESC above 30%.
Archie
Hide Signatures
       Post #: 1166
RE: Extreme Flight Vanquish 2m Build Thread - 7/14/2012 5:37 AM
Si-F3a
Score: 100
Last Login: 2/22/2013
Status: offline
Hi,
Just finished my vanquish & have put 4 flights on it using some
Old TP 10s 5000 packs. Am running the torque motor with a schulze
32.8 esc that ran fine till I tried a new pack tonight (nanotech 2x5s 5000)
Running up on ground from 3/4 throttle up the motor made screeching
Noises that make me think the timing is off. Is this possible when going
From an old to new pack & does anyone know what switch to change on he
Schulze if it is a timing issue. Put 1 flight in withe the old pack tonight
Before running the new one & it ran fine.
Simon
Hide Signatures
       Post #: 1167
RE: Extreme Flight Vanquish 2m Build Thread - 7/19/2012 1:32 PM
strattac
Score: 100
Status: offline
Bad problem, the threads for one of the set screws in the horizontial stabilizer were bad and would not accept the screw. Repeated efforts to install the screw damaged the threads beyond repair and I have managed to get the set screw stuck wit the head flush to the horizontial stab. I'm hoping Extreme flight will sell me another stab but was hoping maybe someone knew the name of this part ( the aluminum set screw assembly) and where to purchase it. I think I could remove some of the sheeting on the stab and replace it if I could find one.
Hide Signatures
(in reply to Si-F3a)
       Post #: 1168
RE: Extreme Flight Vanquish 2m Build Thread - 7/21/2012 3:33 PM
Flyer88
Score: 100
Status: offline
A little tip I use.
Always pre-run bolts into blindnuts prior to mounting. That way you will have no suprises, in case a blind nut is cross threaded or screwed up. It happens.....
Its easy to cross thread those bolts because you dont have much room under the stab, specially if your hex driver has a fat handle.
I ground off one of the handles on a hex driver for the bolts to the landing gear, I couldn't reach them.
You might have to get creative too. Anyway..good luck thats a toughy.
Hide Signatures
       Post #: 1169
RE: Extreme Flight Vanquish 2m Build Thread - 7/24/2012 3:11 AM
strattac
Score: 100
Status: offline
Anyone know where to buy the aluminum stab adjusters used in the Vanquish. I tried the gators but the diameter has to be at least 1/4" to fit over the tubing and the gators were too small. I've had no luck locating the ones used in the Vanquish.
Hide Signatures
       Post #: 1170
RE: Extreme Flight Vanquish 2m Build Thread - 7/24/2012 1:37 PM
jetmech43
Score: 100
Status: online
You could call extreme flight they might can tell you the size
smooth pass
Hide Signatures
       Post #: 1171
RE: Extreme Flight Vanquish 2m Build Thread - 7/24/2012 2:12 PM
strattac
Score: 100
Status: offline
Any one with a stab for sale maybe due to an unfortunate experience or even the stab adjusters out of it?
Hide Signatures
       Post #: 1172
RE: Extreme Flight Vanquish 2m Build Thread - 7/24/2012 3:26 PM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: strattac
Can you take a photo of the problem? Maybe we could come up with a viable solution to your specific problem. Can the stab half in question be removed from the plane?
Is the set screw an allen head? And did that strip out as well as you attempted to remove it? If it isn't stripped yet, try heating the steel screw with the tip of a soldering iron. Heat should transfer to the ally adjuster and expand the hole ever so slightly more than the screw. It might free up. If that doesn't work, you may drill the screw; if you can get the drill bit to bite, it just might turn the screw all the way down into the adjuster opening. I haven't seen how the adjusters are set up so I may be speaking out of school on this.
One reason why I tend to make my adjusters from phenolic stock rather than aluminum. Ally will gall if given the chance
Regards,
MattK
Hide Signatures
       Post #: 1173
RE: Extreme Flight Vanquish 2m Build Thread - 7/24/2012 5:05 PM
gaRCfield
Score: 156
Status: offline
quote:
ORIGINAL: strattac
Anyone know where to buy the aluminum stab adjusters used in the Vanquish. I tried the gators but the diameter has to be at least 1/4'' to fit over the tubing and the gators were too small. I've had no luck locating the ones used in the Vanquish.
You can try posting a separate thread, stating that you're looking for them - someone might have a set they're not using.
Joe Marri
Enjoying all things aviation.
Hide Signatures
       Post #: 1174
RE: Extreme Flight Vanquish 2m Build Thread - 7/24/2012 6:57 PM
strattac
Score: 100
Status: offline
Thanks guys, the screw is a set screw (no head) into an aluminum adjuster. The screw siezed just as the head became flush with the stab.Repeated efforts to remove the screw damaged the adjuster severly, (drilling etc). I didn't think of heating with the soldering iron which may have worked in the beginning of the problem.The problem is the only stab adjuster I can locate are the gators and the diameter for the tube is too small, the vanquish has a 1/4" tube that the stab adjust on. I thinking maybe I can modify a gator wing adjuster by cutting a block out of hard plastic (cutting board) or maybe even a hard wood and tapping it to achieve an adjustable mount with a movable center section. Extreme RC says they have stab replacements on order but no delivery date. They have no idea of the location of a replacement adjuster. Plane is ready to fly...less one stab
Hide Signatures
(in reply to gaRCfield)
       Post #: 1175
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.594RCU1
