RE: Mig 15 With Jetcat P20 Build Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Mig 15 With Jetcat P20 Build Thread
Page: <<   < prev  1 2 3 4 [5] 6 7   next >   >>
Login
RE: Mig 15 With Jetcat P20 Build Thread - 6/22/2011 4:44 AM
rastus21
Score: 100
Last Login: 10/16/2011
Status: offline
Nice one bro, she looks the goods. After I seen ya post that HK had the red one in stock I also immediatly ordered one. Mine will be EDF, 8s set up approx 3.3 kw.
Got my first turbine waiting for me when I get home from the Sim, exciting times.
Matt
Hide Signatures
(in reply to bigplumbs)
       Post #: 101
RE: Mig 15 With Jetcat P20 Build Thread - 6/22/2011 12:18 PM
bigplumbs
Score: 120
Last Login: 12/20/2011
Status: offline
quote:
ORIGINAL: rastus21
Matt
It will be a squeeze getting 2 4 cell packs in her as the ducting is so big. You might be better upping the KV of the motor/Fan and going 6 cells. Wait till you get it and you will see what I mean
Dennis
_____________________________
It ain''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''
Hide Signatures
(in reply to rastus21)
       Post #: 102
RE: Mig 15 With Jetcat P20 Build Thread - 6/22/2011 12:24 PM
bigplumbs
Score: 120
Status: offline
Thrust Pipe
The thrust pipe I am using is the one I got with my Habu 32 kit in the sports kit. It is just the right length. You have to fix the belmouth on however and fix on some front mounting pieces. I used offcuts from an old pipe I had. The Habu 32 sports kit comes with a rear mounting metal and outer wooden ring and screws and I used this to mount the pipe at the rear by the bulkhead next to the rear bottom Hatch.
This whole job was a bit of a pain and took me about 2.5 hours. I always hate mounting thrust pipes. It has finished up very solid though and I have managed to add very little weight.
At the top mounting you will see I have had to drill a hole in the rear of the canopy to clear the bolt head
Dennis
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 103
RE: Mig 15 With Jetcat P20 Build Thread - 6/22/2011 12:33 PM
bigplumbs
Score: 120
Status: offline
Hey Dave the midget............. Havn't you got any work to do I can see You
Dennis
Hide Signatures
       Post #: 104
RE: Mig 15 With Jetcat P20 Build Thread - 6/22/2011 12:44 PM
bigplumbs
Score: 120
Status: offline
Rear Hatch
The rear bottom hatch is held in place by 4 preapplied magnets. Mine was quite a poor fit as can be seen in the pics below. All I did was push on it to splay it out and stuck it with selotape front and back. You should always have a dit of selotape on all planes I recon.................Oh and an elastic band
Dennis
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 105
RE: Mig 15 With Jetcat P20 Build Thread - 6/22/2011 1:04 PM
Henke Torphammar
Score: 100
Last Login: 5/23/2013
Status: offline
I scanned through the thread but did find if you weighed the bare kit? empty weights are always intresting
/Henke
www.youtube.com/henke2
Swist F5D, Lambert Kolibri T25 - 310mph 2012
Hide Signatures
       Post #: 106
RE: Mig 15 With Jetcat P20 Build Thread - 6/22/2011 1:10 PM
bigplumbs
Score: 120
Status: offline
Well as I have never had any instructions I am now pondering the CG. I have 2 other Mig 15's which both fly well see below. I have an Alfa and a J Perkins or OK Mig.
On the Alfa the length of the wing root is 210 mm and the CG is 123 mm from the front = a Percentage of 58 %
On the OK Mig the wing root is 225 mm and the CG is 143 mm back = a percentage of 63 % back.
If I therefore use a Percentage of say 60 % on the P20 Mig and the Wing root is 290 mm this gives me a CG of 174 mm.
To be on the safe side I think I will set it at 170 mm from the leading edge.
This has come out about 23 mm in front of the centreline of the main wheels which would seem correctish
Dennis
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 107
RE: Mig 15 With Jetcat P20 Build Thread - 6/22/2011 1:12 PM
bigplumbs
Score: 120
Status: offline
quote:
ORIGINAL: Henke Torphammar
I never did weigh her but she was quite light. When I get a moment I will weigh the red one
Dennis
Hide Signatures
(in reply to Henke Torphammar)
       Post #: 108
RE: Mig 15 With Jetcat P20 Build Thread - 6/22/2011 1:46 PM
bigplumbs
Score: 120
Status: offline
I am quite pleased because to balance her at 170 mm from the leading edge at the root I have only got to add 65 g of lead which for a Mig 15 is quite good as they are notoriously tail heavy
Dennis
Hide Signatures
       Post #: 109
RE: Mig 15 With Jetcat P20 Build Thread - 6/22/2011 2:17 PM
bigplumbs
Score: 120
Status: offline
Well I have finished the Mig.... Here are a couple of pics of her on the floor. The all up dry weight is 2.8 KG which is 6.16 lbs. I think the P20 at 5.25 lbs of thrust should be just about right. I just hope the silver colour is ok to see.
The fuel will add about another 1.8 lbs but should not be there for landing .
Now on to my RC Paraglider
Dennis
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 110
RE: Mig 15 With Jetcat P20 Build Thread - 6/22/2011 3:01 PM
Jgwright
Score: 101
Status: online
Dennis
See you tonight for the maiden then.
John
John Wright
Hide Signatures
       Post #: 111
RE: Mig 15 With Jetcat P20 Build Thread - 6/22/2011 3:07 PM
bigplumbs
Score: 120
Status: offline
quote:
ORIGINAL: Jgwright
Dennis
John
But it is raining like mad and blowing a hoolie. I will bring it along however
Dennis
Hide Signatures
(in reply to Jgwright)
       Post #: 112
RE: Mig 15 With Jetcat P20 Build Thread - 6/22/2011 4:33 PM
Jgwright
Score: 101
Status: online
Dennis
It is sunny here now and the wind has dropped a little. Forecast is not that bad for 7 pm. At least you could start it up and drive it about a bit!
John
John Wright
Hide Signatures
       Post #: 113
RE: Mig 15 With Jetcat P20 Build Thread - 7/6/2011 5:25 AM
lrb75
Score: 100
Status: offline
I received a copy of the instructions from KMP. They list the CG as 5.75in back from the leading edge of the wing where it mates to the fuse. I think I attached the pic.
Click for fullsize
Hide Signatures
       Post #: 114
RE: Mig 15 With Jetcat P20 Build Thread - 7/6/2011 3:42 PM
cdnbob
Score: 100
Last Login: 5/28/2012
Status: offline
any way you can share the plans? I never received any with my plane
Hide Signatures
(in reply to lrb75)
       Post #: 115
RE: Mig 15 With Jetcat P20 Build Thread - 7/7/2011 12:02 AM
lrb75
Score: 100
Status: offline
I posted the word doc file I received from KMP on hobbyking's site where they are still selling these jets.
Hide Signatures
(in reply to cdnbob)
       Post #: 116
RE: Mig 15 With Jetcat P20 Build Thread - 7/13/2011 4:58 PM
bigplumbs
Score: 120
Status: offline
quote:
ORIGINAL: lrb75
The Mig I have built is not the KMP one however it is Pro EDF.............. I am not sure that these are the same planes
Hide Signatures
(in reply to lrb75)
       Post #: 117
RE: Mig 15 With Jetcat P20 Build Thread - 7/14/2011 12:38 AM
lrb75
Score: 100
Status: offline
It is the same plane made by Pro EDF and it was distributed by KMP.
Hide Signatures
       Post #: 118
RE: Mig 15 With Jetcat P20 Build Thread - 7/17/2011 9:20 PM
bigplumbs
Score: 120
Status: offline
quote:
ORIGINAL: lrb75
Many thanks
Dennis
Hide Signatures
(in reply to lrb75)
       Post #: 119
RE: Mig 15 With Jetcat P20 Build Thread - 7/21/2011 8:07 PM
bigplumbs
Score: 120
Status: offline
Success
Well today I thought I would start the engine and give the Mig a Taxi test. Well she ended up being flown and I was very pleased indeed. My trusty test pilot 3dFlip did the honors.
The takeoff run was quite long and we used half flap and the P20 had plenty of power to lift her off. The plane flew a dream and needed next to no trim. The CG was perhaps a little nose heavy but if it is pushed further back I think it would give a few issues on the ground. The landing was good also with a very small bounce and she also landed quite slowely. The pilot reported that the flaps caused next to no trim change and we managed to fly fo 4.25 minutes and only used one of the 2 tanks. So an 8 minute flight is easily acheivable.
All in all I was very pleased indeed. For those interested in this model I would say to get the red one as she was a little difficult to see against a grey sky.
The thing that most impressed me was how quiet the P20 was and also how easy it was to start...... This is a lovely little engine
The power in the climb was excellent and vertical was no problem at all. In my view now that she has flown I would say that this airframe is a perfect partner for the P20...
I feel like I need another P20
Thanks to 3DFlip for another excellent test flight.
Hide Signatures
       Post #: 120
RE: Mig 15 With Jetcat P20 Build Thread - 7/21/2011 8:18 PM
Jgwright
Score: 101
Status: online
Well done Dennis and pilot.
It would be nice to see it fly next time you plan to go, as I am always interested in airframes of this size.
John
John Wright
Hide Signatures
       Post #: 121
RE: Mig 15 With Jetcat P20 Build Thread - 7/21/2011 8:29 PM
siclick33
Score: 125
Status: offline
This little engine is so addictive that I've just sold one of my bigger turbines to buy another one. I'm so pleased with the ease of use of the little Jetcat that the bigger turbine will eventually be replaced with a P100 when they become available.
Good to see you have success with the Mig. Now we need video
It was all going really well, then I suddenly ran out of talent!
Hide Signatures
       Post #: 122
RE: Mig 15 With Jetcat P20 Build Thread - 7/21/2011 8:36 PM
3d flip
Score: 100
Last Login: 5/22/2013
Status: offline
Thanks Dennis for letting me play with the P20 I was very impressed with how it ran and how quiet it was ( I think its time to buy one )
I don't think I have ever seen Dennis look so nerves. The Mig Flew very well, I am looking forward to seeing Dennis fly it.
John
Hide Signatures
       Post #: 123
RE: Mig 15 With Jetcat P20 Build Thread - 7/22/2011 8:30 AM
Henke Torphammar
Score: 100
Status: offline
Very nice :-) good with some options beside the Habu32 that has the looks too :-)
/Henke
Hide Signatures
(in reply to 3d flip)
       Post #: 124
RE: Mig 15 With Jetcat P20 Build Thread - 7/22/2011 8:46 AM
marc s
Score: 110
Status: offline
Dennis, good to hear it all went well, and enjoy the little Mig especially on those long dreamy summer evenings we are having here in the UK
marcs
Hide Signatures
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.906RCU1
