which ignition Jodi?
Was checking out the rcexl ignitions you sell. I assume the 10mm CM6 is the right one for the DLE 30,55. Also how important is the spring in the cap? I have a fairly new DLE 55 thats been had starting, and surges when it starts. sometimes it runs fine sometimes not. Have rebuilt the carb, changed ignitions, made sure battery is charged, changes the plugs, checked fuel system and dont see an obvious problem. Thanks
H
H
RE: which ignition Jodi?
ORIGINAL: Tired Old Man
DLE, RC Exl, same ignition.
Don't need to trash one to see the difference. A timing light can be used to see the different advance curves. The DLE20 and rear carbed DLE30 have unique timing curves and modules, they are not the same as a DLE55, they are all made by Rcexl.
DC
I find it amusing that the best model airplane ignition on the planet was made for many years with the best electronic control ever made was copied by a Chinese company who now can't get it right...
The original Syncro Spark made by ED Vollmer and used by Bill Carpenter was just fine for ALL model airplane engines until some people who can't tune their carbs forced Xu Liang to make an advance curve that overcompensates for bad tuning...
Some of you people deserve what you now have....
There is no sound reason to have electronic advance on a small gasser, 28 BTDC works just fine with no retard for starting, there isn't enough kick back to need it...Before I could get the Syncro Spark circuit all my conversions of the G26 had fixed timing..No one ever complained....Larger engines needed some retard for starting, so mechanical advance was used by making a link to the throttle...100% linear advance from 4 BTDC to full advance at WOT....Still arguably the best system, but easier and now cheaper to just get an ignition from Xu Liang...I would bet most users couldn't even tell the difference except for the kick back when starting...
Too bad Bill and Ed no longer make the best ignitions, victims of the new plug and play mentality and in Bill's case some bad health...[&o]
VA
If the original side carburetor on the DLE-30 was replaced with the rear-carburetor kit, will the original RC EXL ignition work just fine?
ORIGINAL: jedijody
ORIGINAL: Antique
ORIGINAL: Antique
ORIGINAL: ggraham500
ORIGINAL: jedijody
Unless a minor flaw in tuning will destroy the engine, I can't imagine why having an electronic advance to smooth out the rough edges is a bad thing.
ORIGINAL: captinjohn
I sure wish Rcexl would produce a ignition with no advance too. Then you could make your own custom mechanical advance (like Antique did) for bigger engines, or you could just use it on about any small engine right out of the box. Capt,n
It's not quite that easy.
As for making a zero advance ignition, all one has to do is burn the chip appropriately. Sensor passes magnet and coil goes bang. To make a custom curve requires that a lot of experimentation with running engines be performed, using a special tool that's user programmable in real time, to develop a curve to fit the application. From there some interfaces between programs has to be created that will permit the digital exchange of information in a compatible format. Then the chip gets burned again. Neither the tool nor the programs are openly available.
I've designed a few ignition curves and it requires the investment of a lot of time and labor.
RC Exl could easily do as good a job with their products as CH did but you have the usual cost reduction issues typical of copied Chinese products. If there's a way to shave a couple cents off the productin cost they will make use of it, even if it reduces the quality of the product. It's all about profit to price. Call it (generously) an 80% rule. If they can make a product that works 80% of the time while increasing profitability 50%-100%, that's what the customer will get.
Note that RC Exl hit the market and established their customer base by selling an ignition for less than half of what the industry standard, epitome in relibiality sold for. They weren't better OR more reliable but they were cheaper. Others later followed the same path but have been even less reliable or functional than RC Exl. CH/Vollmers have been heavily copied but never equalled.
ORIGINAL: Whistling Death
My expeiences have shown those relationships to be a combination of science, math, art, and magic.
DC
RC EXL ignition circuits with no advance curve are available from Xu Liang if someone wants to make their own mechanical advance...
It requires some linkage from the throttle shaft to a moveable sensor...
Most plug and play people don't want the hassle...
For those into serious performance, the mechanical advance method is as good as things can get. Auto advance units all trade off performance in areas that mechanical control to a much higher performance level.
This is real old news and was beat to death after a couple of major name players started advertising auto advance ignitions as the "new standard, and superior" in engine ignitions and timing. Those new standards took performance down a couple of notches but it made for good advertising copy to sell more engines. Sort of like the multi bolt prop hub....
Regarding the difference between ignitions with the DLE 20-30 and 55. The 55 ignition would work with all of them but you would have to run premium grade gas with the 20 and 30. An alternative would be to alter the static timing a little to the negative position.
I'm not going to bother explaining why. It's all been covered before with discussions on compression ratios, RPM, and timing.
DC
Don't think anyone does, but I order the circuits from Xu Liang to use with my conversions...They are just bare circuits and require a spark coil and are put inside the mount....
